SDA design question
I 2nd that, the factory CRS does not have an inner brace but more real estate between drivers. Possibly the CRS wide spacing was to present a wider sound field in smaller rooms perhaps?
For me, the question that remains is if I move the MWs closer, do I need to move the tweeter closer to both MWs in that same proportion?Don't take experimental gene therapies from known eugenicists. -
How far away is the tweeter from the midwoofers in the SDA 1 and 2 line?
I can't think of any reason that closer wouldn't be better. Consider the 3.1TL, where the tweeter baffle actually covers part of the midwoofer above it.
OTOH, I don't know that "in the real world" it's ultra-critical. I wouldn't move the tweeter FARTHER away from the midwoofers than Polk did in the SDA 1 and 2 line, though. -
Braddles63 wrote: »So why does the CRS have the space between the MW's and the tweeter lower and sort of in-between and the SDA2 have the MW's close together with the Tweeter above? What the pros and cons of each layout?I have no doubt that Polk knew the wide-set midwoofers would increase the SDA effect. I have to believe that Polk wanted that enhancement on the CRS, since they could have done narrow-set midwoofers if they'd wanted to--all they needed was to position the tweeter horizontally like they did on the early CRS. This is the "acoustic" reason for wide-set midwoofers on the CRS.
I'm guessing that, since Polk used the same crossover and same SDA drivers for the CRS+ and SDA 2B, but used different stereo drivers, some spacing adjustment for proper time alignment needed to be made.
I'm also guessing that the wider driver spacing on the CRSs was designed to provide a wider sound stage in the smaller rooms, and book shelves, they are most likely to be used in.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »
Other years for the CRS+ and 2B models did use different stereo drivers. Is is possible the schematics for '87 are listed incorrectly? Or perhaps I'm looking at it wrong?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
I would guess that the CRS got the wider spacing simply as being part of the "Reference" series. All the others in that line have the same spacing until the latest 3.1 surfaced.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
For the stereo signal, isn't it ideal to have the tweeter as close to MW as possible for the crossover frequencies to mesh?
The mid bass spacing may in part be a cosmetic consideration since it still provided interaural crosstalk cancelation.Another consideration is that the box needed to have sufficient internal volume to get good bass response and proper tuning with those specific drivers and passive radiator combination. Making the enclosure wider was maybe the prefered design choice to hit the required volume vs making it deeper or taller?
You know a lot more than I about this stuff that I do but it seems that theory might be not be plausible. The schematics you posted here in the forum for the '87 CRS+ and the '87 2B, (both pin/blade), use the same crossovers, same 6511 SDA drivers and same 6503 Stereo drivers. The schematics actually have the same drawing number and date.
I was speaking of the 1989 CRS+ and 2B. I wasn't even thinking of the earlier CRS+, which I should have also addressed.
I don't think there are mistakes in the 1987 schematics. I took electrical measurements of one of my spare MW6503s and one of my spare MW6510s. The results are tabulated below.
The MW6510's lower figures for Qts, Qes, and Qms indicate higher mechanical and electrical damping. Q is the inverse of damping factor and driver damping has an effect on driver time alignment. It appears that Polk came to believe that the MW6510 was a better match for the BE1807-B crossover in the CRS+'s much smaller enclosure.
@KennethSwauger please ask Stu (Polk's VP of engineering) to comment on this topic. Thanks.Proud and loyal citizen of the Digital Domain and Solid State Country! -
My 2 cents for the CRS is the wider spacing fit for the desired cabinet dimensions. I don't know for sure, but I'd speculate the cabinets are symetrical which becomes a cost savings. Aesthetics may play a part too.
All the different tweeter locations, roll offs, output, and arrangements are what I find very confusing. I'd love to hear all the versions in a controlled environment.
There can be lobing issues depending on driver locations, and people also talk about time alignment when tweeters and drivers are offset for non-SDA speakers. Some people claim to hear the differences and say when things are out of alignment accuracy is lost. Then there are speakers that use drivers in multiple locations, and people rave about there sound.
I'd love to know about the science behind it, but I have a feeling for SDA, as WMG said, there is likely a zone the works. There likely was some basic math and rules for rough locations, but then once a general spacing was picked, it came down to tooling and manufacturing, and then making sure it sounded "good". -
From the chart above the lower Q values for the 6510 would indicate a stronger magnet thus higher sensitivity. Generally higher Q drivers require larger enclosures assuming the other T/S parameters are similar.
Great responses and conversation here.
From the schematics, it looks like Mr Polk changed to a lower ohm MW to accomodate the large sub drive inductor?
A question for maybe WMG is since he installs the lower ohm steel laminate inductors, would it be feasable to revert back to a higher ohm MW?
That Inductor only affects the dimensional woofer(s) on the 3rd, 4th and 5th generation, from around 150 Hz downward. It will increase the output, regardless of which driver was used, 6503, 6509, 6510 or 6511.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Forgive me, you are referring to "It" as the laminated steel version correct?
If so, where do I procure a set?
I didn't go rogue and omit the PR at your behest...ahem. But I am changing the RDO tweeter plate design however.Don't take experimental gene therapies from known eugenicists. -
Never mind, I found it. You are unwinding an Erse via LCR. Thanks again WMG
I'll hold off as my cabs have a touch more volume and go from there.
Looking at the SW102, I wondered if anyone ever tried inverting it to achieve more volume.Don't take experimental gene therapies from known eugenicists. -
What is the crossover frequencies of the stereo MW and tweeter of the 1989 CRS? I assume they were SL2000s from factory?Don't take experimental gene therapies from known eugenicists.
Cool thread! Soundstage of the 1989 CRS+ has always been one of the things I admire most about them.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Anyone know the crossover Hz?...
Bueller....Bueller....?Don't take experimental gene therapies from known eugenicists. -
WMG for the assist....once again.
And how do you measure ohm load of each speaker once everything hooked up? At terminals and no interconnect cable between?Don't take experimental gene therapies from known eugenicists. -
There's a whole section in the SDA Handbook for checking DCR.Home Theater/2 Channel:
I notice the separation distance of the CRS drivers are very similar with the SDA SRS 2"s isn't the srs 2's cross over identical to the SDA 1 B's ?.
Essentially yes Sean. There's one resistor that's different, and I believe the woofers might be. The 87' SRS 2 and 1C are also nearly identical, except for the sub-bass drive Inductor.Home Theater/2 Channel:
What exactly is the sub-bass inductor doing? I inadvertently uplugged the left channel inductor lead and it definitely had lower bass volume on that side.
From schematics it looks like it is sending signal to ground.Don't take experimental gene therapies from known eugenicists. -
It's explained in detail, in the SDA Handbook. It allows the dimensional driver(s) to operate in-phase with the stereo drivers below about 150 Hz. Without it, the dimensional woofers would either be out of phase or just sit there flapping like an additional PR.Home Theater/2 Channel:
Where's the link to the handbook here?
I'm experimenting with the Power-Port adapter plate and the coil has to be connected for the bass to hit deep as well... The adapters allow me to install different length ports quickly.
Copious amounts of bass with them right against back wall hehe.
Think of the inductor as a "filter". Music signal below a certain frequency is sent to ground, music signal above that frequency is sent to the SDA drivers in the other speaker cabinet.
By allowing the low frequencies to go to ground, the current moves the drivers, and you have additional low bass. The higher frequencies allow the SDA system to work it's magic in the other cabinet.
I'm sure it's more complex than that, but you get the idea.Where's the link to the handbook here?I'm experimenting with the Power-Port adapter plate and the coil has to be connected for the bass to hit deep as well... The adapters allow me to install different length ports quickly.
Not my first choice. The BR serves the same function as a port. I have NO idea how you'd tune the port and the BR to work together and not step all over each other. -
There's either one or the other, not both, with a simple plate that bolts in place of the PR.Don't take experimental gene therapies from known eugenicists.
Does a port have any advantage over a bassive radiator? I thought the bassive was the preferred method as there's no port turbulence. The bassive radiator was the "premium" version of designing a ported/vented/bass-reflex cabinet.
Port is cheaper
Does a port have any advantage over a bassive radiator?Copious amounts of bass with them right against back wall hehe.
