Speaker choices - anyone has any opinion on either of these? BW 800 Diamonds or SF Strads.
Joey_V
So I'm looking for my next pair of speakers, narrowed it down to really just 2.
Either I go with B&W 800 diamonds or Sonus Faber Stradivari.
2 camps to this thought:
1. B&W 800 diamonds are current cream of the crop for B&W, they appear to be very transparent to the source to my ears. However, cons for me are the excessively large weight which would make it difficult for me to move up and down the stairs if I need to either sell or move as a secondary speaker in the future, and the fact that there might be a new top shelf B&W speaker in 2016/17.
2. The Strads have been a goal of mine for a while, but I've only heard them once. And while they were very good and sounded fantastic, I thought that they were not as transparent as the BW were. That said, I thought they were even more holographic and 3D. Bass was better too. Other Pros include not as large or bulky as the BW 800 diamonds and would likely be easier to place. Cons to me are that it is old tech, and has been supassed in ranks by other SF speakers though they do not share the same house sound. Another con is that it is more costly as well.
I did think of a 3rd scenario, and probably a compromise. I would entertain the BW 802 Diamonds as a possible compromise. It is smaller, easier to move and mobilize, easier for me to integrate as a 2nd system anchor should the time arise to upgrade. Also it is less costly and would easily allow me to upgrade to the new BW top end speakers should the opportunity present itself in 3 years or so. Plus it will get me a majority of the sound of the 800 diamonds.
Just trying to put my thoughts into words, if anyone has any thoughts or opinions, feel free to share. Thanks!
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Of course, this being a polk forum, I am in the process of getting a bunch of polk speakers for the house. I have need for several in-ceiling speakers and would like to go with the LSiM versions of them... always have a fond place for Polk in my heart.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Have you auditioned the B&W pm1? Beautiful speakers that sound outstanding. Would be easier to move than any of the others.
My vote would be the Sonus Faber Strats. Those would be an end game speaker for me. In my opinion, no such thing as "old tech" when it comes to good sound. Either it sounds good to your ears or it doesn't.
Not a huge fan of the Diamond series for B&W.HT SYSTEM-
lsi 9's -
Yeah we shall see. Diamonds for me with the right pairing just sounded nearly out of this world. Pair it with Rotel and you got yourself a crappy sounding speaker.
Sometimes a speaker that sounds good all the time is not so much a speaker as it imparts it own sonic signature. A more transparent system, on the other hand, may be harder to pin down correctly, but very rewarding in th send.
Cary and 800 diamonds are just sublime.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Yeah man, forgot you had the SLP O5 in house. I can see that pairing doing well.
lsi 9's -
Tony
Heard the diamonds on a full rotel system - sounded terrible. Heard the diamonds on all mac system - sounded OK. Heard the diamonds (802) with my CARY 05 preamp in an otherwise mac system - sounded frickin' phenomenal.
That's how I know the speakers are good, if they can sound bad with other components.
Hey DSkip -
What have I ruled out -
1. Wilsons Alexia, Wilsons Sasha 2, Wilsons Sophia 3.
2. Rockport Avior, Rockport Atria
3. Martin Logan Summit X
4. Magnepan 20.7, 3.7
5. TAD Reference 1
6. SF Olympica III
7. Vandersteen 5Carbon
8. Klipsch RF7ii
Right now, I have the Cary 05 preamp and the Cary 211 FE monoblocks - the new ones. For source, I was looking at the Esoteric K01, but wouldn't mind saving some dough on perhaps the MAC MCD
1103.
Budget is approximately 20-30K for speakers, lower number is better obviously.
Sound I'm after is basically something that gets me to feel like I'm not listening to a pair of speakers and that I'm at the event. Something with good back to front soundstage depth and where there is holographic vocals. I really got this sense when I listened to the 802 diamonds with my Cary 05 pre in an otherwise Mac SS system.
Room is dedicated, 17x14.5 with sloped ceiling front to back, 8ft front and 9ft back with furdowns along the side. Treated. No open hallways anywhere to mess with the sound. Symmetric room otherwise.
A few things I havent listened to but also have no local access to - Vivid Audio Giyas, Focal Utopias.
Yep, heard the PM1. We plugged it side by side against the 805 Diamond and there was really no contest in that regard. The Diamond had less sizzle up top though the PM1 on its own was a great speaker... I like the PM1 so much that I have been planning on getting it as a speaker for the family room.
Great little guy for sure and the price is not absurd for a monitor. They image very very well. Near point source in my view.
This was on a Mac integrated.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
I say go with the bw 800 and if you cant find em cheap enough just buy some polk rti8 as they sound very similar.
polkfarmboy wrote: »I say go with the bw 800 and if you cant find em cheap enough just buy some polk rti8 as they sound very similar.
Yeah, that's what I was thinking. I think I'm going with the Diamonds, but will really ponder if I want to go 800 or 802. Going for a 2nd listen to the Strads coming up. Have to fly out just to hear them unfortunately since they are difficult to find.
Idiotic statement.
I hear ya Joey. You want a more emotional connection with the music without the laid back sound. Another one to audition is the Acoustic zen Crescendo's, if you can find a hi-fi shop that carries them. Seem a tad over priced though imho.
You know me Joey, I'm a Legacy fan boy to some extent and wouldn't mind having a set of these sitting around staring at me...
http://legacyaudio.com/products/view/aeris/HT SYSTEM-
lsi 9's -
Any opportunity to get your ears on some Magicos? The S3s fall in your price range depending on the finish you go with...
And S5s can occasionally be found for similar pricing as new S3s...
Dangit...I may drag my SLP-03 in to my buddy's shop and see how it sounds with the S5s or Q1s..."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Even the discontinued V2s are one sexy sounding speaker and pop up from time to time well under your budget...
http://app.audiogon.com/listings/full-range-magico-v2-demo-awesome-speaker-2015-02-09-speakers-94608-emeryville-ca"Some people find it easier to be conceited rather than correct."
I guess the bottom line here is, if Joey already heard the Diamonds on the same pre he has and digs it, then start looking for a deal on the Diamonds.HT SYSTEM-
lsi 9's -
A friend of my wife's (who has rapidly become one of mine since I met him) has a pair of Lawrence Mandolins on D'Agostino gear...even in his incredibly **** room (he is remodeling his basement to include a dedicated 2 channel room but for now has his gear set up in his open to the rest of the house dining room), they sound amazing.
Probably in my top 5 speakers I have actually heard list (which is topped by Magico Q5s on Boulder gear)"Some people find it easier to be conceited rather than correct."
Have not heard magicos but they seem to be next level pricing for me. Thought about going to the big boys but wife put the foot down, Q7 would've been possible had I been still single.
But yeah, enough dreaming. Maybe next round of speakers.
I have toyed with the idea of getting a pair of used Magico Mini II for the gameroom to see what the hoopla was about, but not sure yet and I want to focus on the main 2ch first. I have been told to listen to some YG but impossible to find nearby.
Alexia? Wanted to like them and was prepared to shell the dough, but the convergent synergy tweeter was too tame and honestly sounded colored and muted even on Boulder electronics.
Didn't get any goosebumps with the TAD Ref 1 either and those were a steal for me had I bought them as a demo pair. Retail on those is 78 and the dealer who was closing down offered it to me for 29. Wanted to like it but couldn't do it.
800 diamonds gave me goosebumps. But the Strads almost made me cry. So that's why I gotta listen again to the Strads. See if it was like a one time fling or if it was legit.
No worries about other brands. When I'm through, I want to have 3 different speaker brands in the house. Not to mention I'm looking forward to installing all my Polk in ceilings.
One day maybe the BW, SF, and maybe a pair of Logans or Magico can be found in 1 spot. Better to diversify than keep to a single house sound I think.
For now, gotta focus on the 2ch. The rest will come over the next couple of years.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Yeah... Tough to find a deal on the 800 diamonds. Very tough.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Magico, Evolution Acoustics, YG Audio, Usher Be series. I really want to get my ear on the Lawrence speakers.
I'm a bit surprised that you discounted the Wilson Alexia honestly. That speaker absolutely blew me away. The setup I heard had TOTL ARC and Shunyata powering it.
Thought about Evolution, but can't fit the MM3 in my room. Usher, no dealer.
Focal utopia... That's one I'm interested in.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
I sort of felt the same way about the TAD Ref1s and the CR1s. It was a whole lot of "Meh...they sound good but they don't move me.""Some people find it easier to be conceited rather than correct."
Have you heard the PSB Imagine T3? I found the highs a bit smoother vs the 800 D's but still kept full detail and the up front sound like the b&w plus I found the bass a bit faster. Also for that size room you might be able to get away with the T2 if you find you like the PSB sound. Any dealers in your area that let you do a weekend in home trial?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Your Cary monoblocks may not be the best match for the B&W 800 though. Have you considered Dynaudio C4 ?
Thanks guys, good discussion.
I sent the impedance graph of the BW 800 diamonds to Cary and they told me to use the 4 ohm taps and that there was enough to power it and that they recommended the 211 FE monoblocks. This was their biggest and most powerful with the new direct-tech technology so it has enough gusto for my midsized room. If that doesn't work, I'll be back here and we will be talking amps. Not opposed to getting similar level solid state amplification like the Mcintosh 1.2kw monoblocks or what.
Could just be bad pairings. Everything at that level is going to be very sensitive to the upstream products. Since you have heard the B&W with your pre, that does solidify it more for your situation. I'd imagine that pairing it with the SF will tame the highs too much if you like what it did for the Diamond tweeters. I still think you owe it to yourself to try and find a pair of diamond series Ushers to listen to. I haven't had a chance to hear the big boys, but I almost bought a pair of AC-10 from Florida about a year ago. The Be series is supposed to be a pretty big improvement over the AC.
Regarding bad pairings, possible. But I heard Alexia's and Sasha 2 on arc, d'agostinos, and boulder. Don't get me wrong they sound good... But not "that money" good for me.
Will keep that in mind... Never heard of psb t2. Is that a full range speaker? I have other rooms for a bookshelf in mind.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Exactly my friend... Exactly.
And I heard them in gear that were out of my budget. Pass xs360 quad monoblocks, etc... If I didn't connect at that level at that price point of upstreams, my gear at home had no chance.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
What about something like the Harbeth / Monitor 40.1's ?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Bingo....but since the man likes his Cary gear, why risk changing all that to pair up with yet another speaker ? He likes the Diamonds with his Cary gear, then all he needs to do is shop around.
Joey, we can throw speaker suggestions at ya all day, just too damn many out there really pal. Get your ears on as much as possible, this isn't your first rodeo. Trust your own judgment, we here are just shootin' in the dark. Seems to me your ears and judgment have worked out just fine for you over the years.
lsi 9's -
The Imagine t2 and Imagine T3 are both floor standing.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Just a FYI for those who don't know Joey, I believe he's rockin' the ML Summits right now so any suggestions has to be a vast improvement for him to consider. Joey can correct me if I'm wrong or if he has moved on to something else.HT SYSTEM-
lsi 9's -
True tony, I have a preference for the sound I want to hear. I've heard enough during this demo period but clearly not enough because of logistics. One of these days I will make a pilgrimage to LMC in Arizona and hear some real gear. If anyone wants to come and join.
Also I plan going to RMAF this year.Could just be bad pairings. Everything at that level is going to be very sensitive to the upstream products.
