Lsi25 and reciever or amps
13»
  • Whadyasay
    Whadyasay Posts: 300
    edited January 2009
    eclimax13 wrote: »
    about 3 months ago...when i realized after a year of apartment living, my home theater and guitars where being abused.....by not being abused...and the girl and i are SICK of white walls
    I've had my sound system up MUCH louder than my guitar playing, but it's the guitar playing that's gotten the complaints. Didn't think my playing was THAT bad, but sometimes I'm changing pickups or finishing an amp build in the wee hours, so they have to be tested.
    As for placement, if the right speaker is right smack in the corner it can be an issue, but you may not be able to do anything about that as of now. Center speaker in a boxy cabinet isn't the most desirable either, but if you can't mount it above then you just can't.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited January 2009
    Speaker placement. They should be a fair distance from the back wall, and side walls. Also, they probably should be farther apart.
    I'm sure someone smarter will chime in soon.
  • eclimax13
    eclimax13 Posts: 168
    edited January 2009
    hmm...6 feet apart and the right one is over a foot away from the wall...this is not good enough?
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • eclimax13
    edited January 2009
    well i hate to be "that guy" but i need further advise...i talked to denon, polk, and rotel and every one told me i would not notice a difference at my playing levels...as my denon is pushing about 180-200 at 4 ohms already...they all said my amp was actually pretty decent for my speakers...now...should i look at maybe 300 wpc?...or is it still going to be the same result?
  • Whadyasay
    edited January 2009
    At lower volumes, again, not much difference either way...but once you start pushing it up it's very apparent. So if there's no way that you'll listen at, say, -15 to -11 on volume, don't worry about it until you move.
  • eclimax13
    edited January 2009
    well i got a chance to listen to a rotel 1075 and a/b'd with a receiver of similar power...at my listening levels i did hear a difference...parts of the music had more detail and the voice that sounded a little muffled with the receiver, became clearer and more enjoyable to hear...soundstage also opened up...so i guess ill be looking for a good deal on one of these babies
