AI-1 Dreadnought - Preliminary Results
Yep it is one winding on the secondaries on the 555 center tapped, and yes I have the diagrams to set it at 120 or 240. On the secondary the resistance is just under 1 ohm, and with the primaries tied it is 1.1ohm.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Tied in series or parallel?If its parallel and the DCR's are that close the inductance should be similar so it might be usable.and with the primaries tied it is 1.1ohm.Testing
Testing
Testing -
parallelPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Cool,the DCR is a smig higher than recommended but it might do the trick.parallelTesting
Testing
Testing -
I just realized that using the A1 parallels the inductor that the SDA uses which is why Polk recommends a high inductance transformer. I don't think mine will work well:(Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I would expect a beefy 700-800va transformer to have high inductance as there is a lot of copper wound around that core. Find someone with an LCR meter and check both inductance of the Prim and sec.I just realized that using the A1 parallels the inductor that the SDA uses which is why Polk recommends a high inductance transformer. I don't think mine will work well:(Testing
Testing
Testing -
I have an inductance meter, but it reads real low inductance. I don't get it. I used a coil I have to check to make sure that it wasn't reading wrong
Ben
