AI-1 Dreadnought - Preliminary Results
  • ben62670
    edited January 2009
    Yep it is one winding on the secondaries on the 555 center tapped, and yes I have the diagrams to set it at 120 or 240. On the secondary the resistance is just under 1 ohm, and with the primaries tied it is 1.1ohm.
    Ben
  • Systems
    edited January 2009
    ben62670 wrote: »
    Tied in series or parallel?If its parallel and the DCR's are that close the inductance should be similar so it might be usable.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    parallel
    Ben
  • Systems
    edited January 2009
    ben62670 wrote: »
    parallel
    Cool,the DCR is a smig higher than recommended but it might do the trick.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    I just realized that using the A1 parallels the inductor that the SDA uses which is why Polk recommends a high inductance transformer. I don't think mine will work well:(
    Ben
  • Systems
    edited January 2009
    ben62670 wrote: »
    I would expect a beefy 700-800va transformer to have high inductance as there is a lot of copper wound around that core. Find someone with an LCR meter and check both inductance of the Prim and sec.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    I have an inductance meter, but it reads real low inductance. I don't get it. I used a coil I have to check to make sure that it wasn't reading wrong:confused:
    Ben
