RTi upgrade: 8 to 10.
2michaud
2michaud Posts: 132
edited December 2008 in Speakers
Hey guys,
With the system in my signature, I am looking for less localized bass. The velodyne is awesome, but has trouble reach the middle of the room, which is where I sit when on my computer. What would be the difference in upgrading to RTi10's? My system is 40% video games, and 60% bassy techno music. Would I notice a large loss in midrange? Would the bass from the 10's mix well with the bass from the 12" velodyne?
I think Bananas are awesome fruit.
HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
http://www.polkaudio.com/forums/showcase/view.php?userid=81835
____________________
  • nm4710
    nm4710 Posts: 97
    There are some folks who think that the 10s lack midrange...as an owner of 10s and 8s I don't believe this is true. The 10s are an enormous upgrade, worth every penny IMHO. Midrange and bass are better on the 10s in my opinion. The improvement in bass is simply unfathomable..in fact the 10s dig deeper than some subs. My 10s blend in well with my Kef sealed sub and I am very picky about bass localization. The 8's always left me wanting in that regard...they are now in the bedroom.
  • leroyjr1
    leroyjr1 Posts: 8,785
    You might want to look into a second subwoofer .
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    nm4710 wrote: »
    I 2nd this. I have 10s 8s and a KEF PSW2150 I use for movies. I actually hooked the 10s and 8s up to an A/B AVR to see if I could tell the difference. Could tell a big difference (test done blind using GF for helper). For most music, I think the 10s dig deep enough on their own, but sometimes, when I want to shake the walls, I crank up the sub too.
  • Peter Fleming
    Peter Fleming Posts: 49
    I recently sold my RTi10's - I hated them!! The midrange is very underwhelming, the highs are too high, and the bass while deep can be booming. Soundstage, also very underwhelming!! RTi10's require good amplification if you want the bass to fire up. The Rti8's are a better music speaker due to better midrange and clarity, a bit lighter in the bass yes but still better. If you want strictly home theatre the RTi10s are okay, but beyond that you can do a lot better for your money. Listen to a set of B&W 684's, about the same price range, and you will understand where I'm coming from. Good luck with your selection.
  • Kchill
    Kchill Posts: 262
    I like the rti10's for a punch of bass when you turn up the bass control on your reciver. Sometimes I have heard the 10's overpower the sub and i run 2 subs with the 10's.
    If you can still pick them up under 400 bucks I think its a good upgrade.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • 2michaud
    2michaud Posts: 132
    Thanks for all your input everyone.
    I'm seeing some disputing documentation about the driver complement...is the midrange a 6 1/2 or 5 1/4?
    They're not exactly under $400 dollars...up here in Canada we don't have reasonably priced speaker retailers. No Fry's, no Tweeter's etc. $1500 for a brand new set at Future Shop, or $750 from a local classified website. I wish I could find them cheaper. :(
    I'm worried I'll pick them up, and find the bass to be boomy and I'll miss the midrange. I really like a lot of bass in my music, but boomy bass tires me out.
  • ZOOPDOOP22
    ZOOPDOOP22 Posts: 158
    1 6.5 mid crossed over low at 125 hz high at 2.7 kHz. This is from polks product page
  • curved
    curved Posts: 664
    Agree with Lee, buy another sub...
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • Kchill
    Kchill Posts: 262
    Bass is not boomy with me, without a sub I think the bass is tight, not ground shaking but a tight punch.
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
  • nm4710
    nm4710 Posts: 97
    Peter, as the owner of a set of RTi8s and RTi10s, i'm wondering if something was wrong with your 10s or if you had them set up correctly. My 10s have it all over my RTi8's. I've run both off of my emotiva LPA-1 in the same positions... the 10s have much better midrange to me - much more natural, smoother. The 8's woofers are tasked with reproducing the midrange AND bass...and they really don't do a great job of either IMHO. As for the highs being too high well the 8's have the same tweeter...so they should sound pretty similar.
    As for comparing the B&Ws, most of us bought a pair of RTi10s for under $600...I've yet to see a comparable pair of B&Ws at that price.
    To the OP, I think the 10s would be a stellar upgrade. Please remember that everything is in the tuning and tweaking...so what sounds good for one person might not sound good for another. That said, if you want better bass localization I think the RTi10s will get you there.
  • 2michaud
    2michaud Posts: 132
    This is some really good input - thanks a bunch all.
    I'm not sure what I will decide in the end, I think they might just be too expensive here in Canada for the time being. We're still getting ripped off.
    Maybe boxing day will bring me some luck. :)
  • daboyz
    daboyz Posts: 5,207
    Kex wrote: »
    Although I would expect that I would absolutely love your harman/kardon receiver, I would not expect you to find a big improvement when using it with the RTi10 when compared with the RTi8 with the AVR247 as a power source. It might be a better investment to investigate adding two sealed subwoofers to your system instead. Just a suggestion, to add to the mix.
    +1 or +2 whichever.
    The HK is a good receiver but you really should have an amp to really see if there is that great of a difference.
  • leroyjr1
    2michaud wrote: »
    Hey guys,
    Try different sub placements to see which sounds best. (cheapest fix)
    treitz3 Posts: 20,342
    Have you considered researching room acoustics and how your system coincides with it?
    You may have what you want, yet you may not have it in the best situation. Could you provide pics or a general scenario of the room layout?
  • Peter Fleming
    Hi nm, I know what you're saying but I, and others, tried all the tweeks and stuff and I upgraded all the bits around it until it became obvious the speakers were below par. When you consider I was running an Accuphase amp and Rega 3 TT with Ortofon Rhondo Blue MC and it still sounded crap, I can't imagine how bad they would have sounded with average driving equipment. To complete the test I took my amp and TT to several hi-fi stores and confirmed why the RTi10's were below anything I'd heard in the price range. Price wise, I paid $1730.00 AUD for the RTi10's, I paid $1850.00 AUD for the B&W 683's. The RTi10's were also considered a poor speaker by the hi-fi stores who refused to trade them in. I took a big hit ($) selling them privately but I had to move them on because I had stopped listening music as the thought of more than 20 minutes of high pitched agony and struggling to hear the midrange was more than I could bare. As I said though if they're only for HT then no problem, but in my house the kids use the HT and I listen to music.
    nm4710 wrote: »
  • 2michaud
    2michaud Posts: 132
    Well, I'm starting to think along the lines that the RTi8's are the right speakers for me, I just need to do some tweeking as some of you said.
    I'm finally done exams and have some time to spend today. I did a lot of readings on crossover frequencies last night, and contrary to my belief, it does not possibly damage your speakers to set them down to the low end of their range. So I've decided it's stupid to have my RTi'8s at 100hz. -3db limit for these is 40hz. I will likely set them to 60hz to bring some of the bass up front.
    Also, I finally have time to snap some pics and would gladly have your input on my placements although space is extremely limited. :)
  • nm4710
    nm4710 Posts: 97
    Peter, I'm sorry you had such bad luck with your RTi10s. Mine sound fantastic - that's not just me but several of my friends who have nice setups (NHT, B&W) as well. That said, I paid less than 1/3rd for my RTi10s of what you did. I'll agree the B&Ws are better speakers...but certainly not worth the difference I would have to pay. My 10s have great midrange, and with my emotiva amp they don't sound bright either. Best of luck with your B&Ws...sounds like you have an awesome setup.
    As for the Hifi stores, I suspect their issue was with the polk brand rather than the RTi..I have spent quite a bit of time in australia and polk is not as well known there as I'd expect.
    Cheers
    NM
  • 2michaud
    2michaud Posts: 132
    Alrighty so the pictures of my setup are up on my showcase page. Follow the link in miy signature. I know the picutres are terrible - I need a new camera.
    I also adjusted the frequencies today, and I have to say I'm ecstatic with the results! I turned my subwoofer, centre and surrounds off, as I was re-calibrating the levels between my fronts. While I was doing this, I was surprised at how much bass the RTi8's were putting out now.:D
  • Peter Fleming
    Hi nm4710, thanks for your thoughts re the B&W's - I'm very happy! Polk speakers are very well regarded and known in Australia. Unfortunately it has become common knowledge that the recent models of Polk speakers are not in the same league as their earlier generation and are not competative in performance to price ratio. Nobody is more dissappointed about that than I am as I had my Monitor 10b's for 25 years and traded down to the RTi10's! Anyhow, I've vented and now in a happy place, cheers.
    nm4710 wrote: »
    Cheers
    NM
  • dorokusai
    dorokusai Posts: 25,642
    Fanboy.
  • 2michaud
    2michaud Posts: 132
    Well, the flyer for boxing day came out today. I can snag a pair of RTi10's for $500 CAD. I can't believe my luck, online classifieds were the only things sellings RTi's. Where did these come from?? What do you guys think? Good price?
  • 2michaud
    2michaud Posts: 132
    Too true Kex, those are some wise words.
    I've been reading some more reviews and discussions on the RTi10's. They're not looking so spectacular as they were a couple days ago. I think I just have upgraditis now, and after a lot of thought and input from you guys, there really is not a lot of benefit. The crossovers seemed to solve most of the problem, and I would not want to give up the fantastic amount of midrange I currently have.
    Thanks for the input everyone. :)
  • xterra77
    xterra77 Posts: 47
    2michaud wrote: »
    Hey guys,
    Hi
    maybe this will help
    I upgraded from psb to polkaudio rti10's
    My experience was this
    Using thre rti10's with a HK230 I was lacking a lot of bass
    without turning the bass control way up and they were very bright as to hurting the ears,after buying a velodyne dps12 myself it was a great mix, but still I wanted more.
    By reading many many posts here about separate amplification and how it would make a difference,I decided
    to go that route.
    A local shop in montreal had a sale on an Anthem 3 channel amp 180 x3 so I bought it to power the rti10's and csi5.What a big big difference in mid range and bass,I do not use my sub anymore to listen to music alone.Since them aI bought another amp to power my 2 surrounds and my 2 rears.So if you want the max out of the RTi10's
    you will need an amp.
