body mass index test
OK I had to take a physical this morning, got a correct weight.
5-11 and 226lbs. = 31.5
oh man do I feel better lolDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Originally posted by Vr3MxStyler2k3
Faster im probally as big as you are...lol
I doubt that, but maybe
im 5' 10" 204lbs, and Italian.. LOLMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
hmm. no taller - just alot *bigger*. Dang....and italian.......sheat........im running....;)Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Awe yeah....another dago in the house...power in numbers ma man...my family runs north Jersey.Damn....8 lines...I've gotta put my sig on a diet now.... -
my family runs north Jersey. [/B]
So that is the reason why Jerseyites are flocking to Pa.:Dsuds, suds and more suds! -
34.9
I work out hard all the time,I train my **** off,I tweak my system and thousands others each and every day,I try my best to eat healthy and man I still need to loose weight.
Where the chart for big boned muscular people?????Dan
Man I don't look nothing like Phuz.......he has his own look as well do I.
I'm better looking......LOLDan
Originally posted by mantis
34.9
Man, how can you be HK Fooey at 34.9????
This chart SUCKS and is basically WRONG.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
The chart is basically only funcitonal for health care professionals. Its more or less used as a referencing point to determine health risks and dosing guidelines based on studies. I don't think its really intended to tell someone whether or not they should lose weight.
Most all of us should know whether or not we need to lose weight. Don't really listen to this chart. Just go look in the mirror. -
I'm scared to, every time I walk down the street people look at me funny...I really do not want to know why!! -
Originally posted by RuSsMaN
(seriously, you have to take those calculations with a grain of salt, by 'the chart' for my height, it 'says' I should weigh about 185. I would look like I was on crack if I weighed 200, much less 185.)
Keep in mind that those ideal weight charts were based on data from the 60's. People generally were a lot thinner then, probably because of limited money (not to mention lack of a fast food joint on every block).
BMI's are but one measure of a person's health status. Muscular individuals will have higher BMI's, but with lower body fat percentages.
Generally, the medical community considers the following:
BMI <19.5 = underweight
BMI 20-25 = normal
BMI 25-30 = overweight (must account for muscle status)
BMI 30-35 = obese (health risks, possibly even if muscular)
BMI >40 = morbidly obese
Anyone with a BMI > 40 usually qualifies for surgical treatment (e.g., gastric bypass surgery).
Time to hit the gym boys! (I speak from experience on this one!)Learn from yesterday, live for today, hope for tomorrow. - Albert Einstein -
RussMan, how can you be HK Fooey at 34.9????
I don't know I just am.............Even us Fooey's need to do some trimming here and there.......;)Dan
I've seen this circulating for some years now.
The problem is, it doesn't take into consideration the fat to lean bodymass ratio. It just assumes that all people are fat.
You could be 6' 2", 230 lbs and be fat. You could also be 6'2", 230 lbs and be very lean and muscular.
I use that because I'm 6'2" and run right around 230lbs. I scored a 29.1, so I'm literally borderline obese according to this. If you saw me in person, you would think otherwise. I would have to be under 200 lbs to be normal, which is freaking skinny for my height.
It's stuff like this that cause some people to go on those rediculous weight loss diets!Time to hit the gym boys! (I speak from experience on this one!)
Ain't nothing like frying your legs on a set of hack-squats to the point where you just want to collapse on the floor and die! Wish I could do regular ones, but I messed my low back up years ago and don't want to risk doing it again.
John
JohnNo excuses! -
I use weight training to compliment my Kung fu training.
If you have injuries then I suggest Tai chi.Yoga as well.Dan
I'm 6'2", 205 pounds. I could lose maybe 10 pounds of fat, which would put me at 195 and smack dab at the top of the normal category.
I have a medium frame and maybe 15% body fat with decent muscle density and tone.
Since I have 3 levels fused in my spine along with 12 titanium parts worth $18,000 bolted to my spine, the only exercise I do is brisk walking and bench press with my legs raised and crossed so I don't cheat.
I taught Tai Chi locally a few years back and that helps too.
I do three sets of 12 with 140 pounds three or four times per week - not exactly earth shattering but enough to keep my chest and arms strong and fairly muscular and enough to help me draw my hunting bow at 65-70 pounds.
Doc"What we do in life echoes in eternity"
SVS -
I love the mushy feeling when you can barely walk after a good leg workout!! I've literally had my legs to give out when I was trying to walk down a set of stairs one time. Maybe I'm sadistic, but it was an awesome feeling.
I can't do squats anymore either. My knees have taken quite an abuse over the past few years from all the jumps I've done (I'm a skydiver). They never hurt after a jump, and I'm landing correctly, but apparently they're getting microtears in my ligaments, ACL, etc. Lovely. Oh well, there's nothing like jumping out of a perfectly good airplane at 13,500 feet... not even a good workout can compare to that.Learn from yesterday, live for today, hope for tomorrow. - Albert Einstein -
Ought to conbine this and your fire arms training... might even be a video there...Originally posted by Dr. Spec
"Doc's Pistol Packin' Tai Chi Workout"...
BTW, 29.8 here, but definitely not the same 29.8 I was 20 years ago...More later,
Tour...
Vox Copuli
The only firearms I'll be firing anytime soon would be .22 LR rimfire, possibly the .223 Rem centerfire. In other words, no appreciable recoil. Don't want to break my spine into several small pieces.....
I should be ready for the .44 Magnum revolver by deer season, but the 12 gauge slug gun will have to remain the exclusive domain of Edith this season. She is a very good shot; took a large doe last season at 110 yards with a perfect quartering away double lunger. I couldn't have been prouder.
SVS -
Gravity does have a way of redistributing the wealth, doesn't it tour?
SVS -
Doc
Jesus,
I know whose house I WON'T try and break into....:D
Originally posted by TroyD
Jesus,
BDT
C'mon Troy, I'm sure you know your way around an M16, no?
SVS -
Yeah, excepting that I swear my legs are getting smaller as well... If it were gravity, I'd expect to have a pair of 20 lb. ankles...
BTW... I think Troy was talking about Edith's house...
More later,
Tour...
Vox Copuli
Doc
Heh, heh....I've seen one once or twice.
At 33yrs I get a 24.8. Hey, finally somebody thinks I'm normal. It's not the size, but how you use it. I do alot of physical work (when at work), but it's mostly 25-40lb loads. My buddy (who does no physical work) would be considered obese. Then again his biceps are the size of my oversized calfs.Make it Funky!
34.9
I go to the gym, I work out hard yada yada yada....man, be effin honest for once. Your FAT because you don't do anything but eat effin Krispy Kremes and whack off in front of your B&K receiver.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
