Monster Sub Cable?
Motzart
Motzart Posts: 1,075
edited November 2008 in Speakers
I'm looking for the shortest possible.
All I really need is 3-4ft...do they make such a thing?
Shortest I see around is 6ft!
I have a small room so my sub is pretty darn close to the reciever.
My understanding is the shorter the better on cables due to signal loss.
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
  • brettw22
    brettw22 Posts: 7,623
    Get the 6 and you're fine. Generally people don't put subs that close to the equipment..........
    I don't know about distance per se with regard to subs, but I had an 18' once and there were no issues.
  • mantis
    mantis Posts: 17,487
    Motzart wrote: »
    If you use a properly built sub cable, especially if it's of coax design, it can run for about 100 feet easy without signal loss. The frequency is only 80hz and down. So not much signal to push. Use the 6 footer, it will be perfectly fine.
    Dan
  • Motzart
    brettw22 wrote: »
    No choice! :(
    I might be up for a trade....got a 12ft coming in a deal....too long for my needs.
  • Graboid
    Graboid Posts: 43
    I just picked up a 13 foot Monster Cable 850 sub cable complete with a Y adapter for $29 shipped from e-bay. Got it the next day. I have to say that cable is really a monster. It looks like a snake it's so fat. If you want a good deal I suggest checking for the cable on e-bay. I can't imagine a little extra length will cause any loss with this cable, and if you ever decide to move things around a bit you can. Just a thought.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Do not use monster cable over priced radio shack cables!!
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • mantis
    fossy wrote: »
    Looks like Signal cable is using the monster ends. I hate those effin connectors.
    Dan
    Dan
  • Motzart
    Keiko wrote: »
    I'd go with this over MC. Good price and a length that fits your needs Motzart.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
    Anyone else here have/use this Cable?
    Looks like for under $6 shipped I can get one!
  • Motzart
    fossy wrote: »
    $12 a foot!!! Holy **** that's expensive!!! :eek:
    $36 for the 3ft I want.......woooofff :eek::eek:
  • fossy
    fossy Posts: 1,378
    mantis wrote: »
    Dan
    I have a confession-- my cable's to sub are .........rockfish :eek::eek: got um at best buy
    bad fossy bad
  • McLoki
    McLoki Posts: 5,231
    Motzart wrote: »
    I think you are mistaken - it is $25 for a 2 foot cable and $3 per foot after that. (the $25 pays for cable, ends and construction - the Additional $3 pays for cable and additional tecflex to cover it)
    Not that bad a price for a decent quality cable. 4' cable (to allow you to move the sub around a little) would be $31.
  • mantis
    Keiko wrote: »
    IIRC, Blue Jeans Cable and Signal use the same Belden wire in construction of their cables.
    Signal's is just made a bit more fancier and uses, like Dan pointed out, a Monster type turbine RCA connector.
    You have to be careful with that connector. It will rip off the Negitive of your female RCA.
    Belden is a custom wire of choice among Professionals. Like Liberty solid construction and design correctly for it's job.
    Dan
    Dan
  • brettw22
    Look at Belkin's stuff on amazon. It's pretty inexpensive and I've used their stuff before and not really had any problems with them.
  • Face
    Face Posts: 14,340
    You can add a little deoxit to the cable ends if you're concerned about breaking anything.
    IMO, locking RCA's are the way to go, I wish more brands would offer it. I find BJC's termination too loose on some RCA's and Signal's too tight on others.
  • J_Kennedy
    J_Kennedy Posts: 138
    I've got a 50' from Monoprice run up and down walls to my HSU sub and it moves the room. Everything I've gotten from Monoprice has been top notch! All the cable/wire I've ran in wall for all my speakers as well as connectors and plates has come from there for about the price of a Monster sub cable. :D
    - Onkyo TX-SR805
    - Polk RTi8's Main L/R's
    - Polk CSi A6 Center
    - Polk FXi3 Surrounds/Rear Surrounds
    - HSU VFT-2 MK3
