Monster Sub Cable?
I'm looking for the shortest possible.
All I really need is 3-4ft...do they make such a thing?
Shortest I see around is 6ft!
I have a small room so my sub is pretty darn close to the reciever.
My understanding is the shorter the better on cables due to signal loss.
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
Get the 6 and you're fine. Generally people don't put subs that close to the equipment..........
I don't know about distance per se with regard to subs, but I had an 18' once and there were no issues.comment comment comment comment. bitchy. -
If you use a properly built sub cable, especially if it's of coax design, it can run for about 100 feet easy without signal loss. The frequency is only 80hz and down. So not much signal to push. Use the 6 footer, it will be perfectly fine.I'm looking for the shortest possible.
My understanding is the shorter the better on cables due to signal loss.Dan
No choice!
I might be up for a trade....got a 12ft coming in a deal....too long for my needs.
Phones: Sennheiser HD280 Pro -
I just picked up a 13 foot Monster Cable 850 sub cable complete with a Y adapter for $29 shipped from e-bay. Got it the next day. I have to say that cable is really a monster. It looks like a snake it's so fat. If you want a good deal I suggest checking for the cable on e-bay. I can't imagine a little extra length will cause any loss with this cable, and if you ever decide to move things around a bit you can. Just a thought.
Do not use monster cable over priced radio shack cables!!HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Looks like Signal cable is using the monster ends. I hate those effin connectors.
DanDan
I'd go with this over MC. Good price and a length that fits your needs Motzart.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
Anyone else here have/use this Cable?
Looks like for under $6 shipped I can get one!
$12 a foot!!! Holy **** that's expensive!!! :eek:
$36 for the 3ft I want.......woooofff :eek::eek:
Dan
I have a confession-- my cable's to sub are .........rockfish :eek::eek: got um at best buy
bad fossy bad -
I think you are mistaken - it is $25 for a 2 foot cable and $3 per foot after that. (the $25 pays for cable, ends and construction - the Additional $3 pays for cable and additional tecflex to cover it)
Not that bad a price for a decent quality cable. 4' cable (to allow you to move the sub around a little) would be $31.Mains.............Polk LSi15 (Cherry)
IIRC, Blue Jeans Cable and Signal use the same Belden wire in construction of their cables.
Signal's is just made a bit more fancier and uses, like Dan pointed out, a Monster type turbine RCA connector.
You have to be careful with that connector. It will rip off the Negitive of your female RCA.
Belden is a custom wire of choice among Professionals. Like Liberty solid construction and design correctly for it's job.
DanDan
Look at Belkin's stuff on amazon. It's pretty inexpensive and I've used their stuff before and not really had any problems with them.comment comment comment comment. bitchy.
You can add a little deoxit to the cable ends if you're concerned about breaking anything.
IMO, locking RCA's are the way to go, I wish more brands would offer it. I find BJC's termination too loose on some RCA's and Signal's too tight on others."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I've got a 50' from Monoprice run up and down walls to my HSU sub and it moves the room. Everything I've gotten from Monoprice has been top notch! All the cable/wire I've ran in wall for all my speakers as well as connectors and plates has come from there for about the price of a Monster sub cable.
- Onkyo TX-SR805
- Polk RTi8's Main L/R's
- Polk CSi A6 Center
- Polk FXi3 Surrounds/Rear Surrounds
- HSU VFT-2 MK3
