DIY Super Center Channel
12346»
  • Early B.
    Early B. Posts: 7,900
    edited November 2008
    OK, I made contact with the designer and pulled the trigger on the Dynamic 4CC kit! He said he'll build the crossover this weekend and ship everything out on Monday:D:D
    "God grooves with tubes."
  • zingo
    zingo Posts: 11,258
    Early B. wrote: »
    That thing is the monster you've been looking for! Good luck with putting it together and I'm sure it will sound as awesome as it looks!
  • ben62670
    ben62670 Posts: 15,969
    Sweet:)
    Ben
  • Systems
    Systems Posts: 14,872
    Excellent,can't wait to see the build thread for that little beauty.
    Testing
    Testing
    Testing
  • megasat16
    megasat16 Posts: 3,521
    Awesome! Did you get the Full Kit? What's the difference between the two offering?
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Early B.
    megasat16 wrote: »
    Nope. Just ordered the drivers and assembled crossover. I purchased everything else myself from Parts Express. The difference in cost was about the same, but by doing it myself, I chose a couple of different items and I already had some other items. For instance, instead of using the el cheapo PE hook-up wire, I ordered a few feet of bulk AudioQuest cable.
    Once I eyeball the crossover, I may decide to upgrade the Dayton/Solen caps on the midrange and highs. We'll see...
  • Early B.
    The kit arrives on Monday...
  • zingo
    zingo Posts: 11,258
    Early B. wrote: »
    Que evil laugh...
  • Early B.
    edited December 2008
    The kit arrived yesterday. The fun begins this weekend. I'll start another thread to showcase the build. Ben is gonna help me assemble it.
    But just to whet your appetite, the crossover weighs 4.2 pounds!!!:cool:
    I'll snap some pics of it this week.
  • ben62670
    Early said I can't post in his thread till he spends some time with...
    HaHa Early I posted in your thread:p
    Ben
  • Doug_D
    Doug_D Posts: 15
    I'm not sure if you guys figured it out but the reason that Jed's FR dips so much at 50hz and gets a little weird below 50hz is because of room interference. It happens quite a bit down that low so generally you can't pay attention to that area :) They play down flat well below 50hz I can assure you that and I'm sure you've experienced.
  • Conradicles
    Conradicles Posts: 6,419
    I am going to try and build one much smaller.
    I searched "DIY Polk Center Channel" on Google and.............Early B yours was the 1st in line. You are now officially famous.
    Nice speaker by the way...
  • Doug_D
    Doug_D Posts: 15
    Well Jed sells a kit for a smaller version as well that just uses 2 woofers instead of 4.
    http://clearwaveloudspeaker.googlepages.com/home
