DIY Super Center Channel
1356
  • Systems
    Systems Posts: 14,872
    edited November 2008
    Early B. wrote: »
    Ben & GV --
    What do you think about this driver --
    http://www.madisound.com/catalog/product_info.php?products_id=834
    Not bad but won't dig real deep and the xmax is not even close to the Dayton I linked to.I use a variant of this in my mains crossing it over at 60 and 300.hz
    Sensitivity may only be 88db but using 2 will add 6 db.
    Testing
    Testing
    Testing
  • Systems
    ben62670 wrote: »
    I looked at that driver, and yuck! What a bumpy road:eek:
    Which one?If you are reffering to the coax's response shown in the datasheet then yes the tweeters response is a bit rough but this is the raw response without the crossover.With the xover the response will be substantially smoother.
    Several years ago I built a pair of speaks ( even had an article printed in a Speaker Builder ) using the first generation of the SEAS coax.It has a number of benfits that make it a good choice for center channel usage.
    Testing
    Testing
    Testing
  • Early B.
    Early B. Posts: 7,900
    megasat16 wrote: »
    And also high efficiency driver with good sound (Fs) is very hard to achieve at this price point. It's like you gotta make a trade off between efficiency and sounds quality and decides what favors you. You can hardly get the best of both world under strict budget.
    Agreed.
    So what are tradeoffs? Perhaps my speakers won't go as low as I want them to. I can live with that. Maybe the speakers aren't high efficiency. I can live with that, too. But sound quality is the most important factor here, so that's where I need to focus my attention.
    I agree with Ben's view of the ribbon tweeter. Yeah, vertical dispersion may be an issue, but it is not enough to rule it out, IMO. The VMPS center channel I sold yesterday was the best one I've owned and it had a ribbon tweeter and a ribbon midrange, but from what I could ascertain from the sitting position, vertical dispersion was never an issue. This center channel will sit even higher.
    "God grooves with tubes."
  • Systems
    Early B. wrote: »
    How long were the ribbons in it?It's less of an issue with shorter ribbons.
    Ah OK, I initially thought it would be sitting very low.
    Testing
    Testing
    Testing
  • Early B.
    GV#27 wrote: »
    The proposed ribbon tweeter will be 3".
  • tryrrthg
    tryrrthg Posts: 1,896
    My advice, build a proven design like the WTMW design built with the Dayton Reference Series drivers. Two 8 inch drivers.
    summarized in these two threads
    http://www.htguide.com/forum/showthread.php4?t=15323
    http://www.htguide.com/forum/showthread.php4?t=22393
    or there is the Statement center channel that uses a ribbon tweet, but only 6.5" mids.
    http://www.htguide.com/forum/showthread.php4?t=27552
  • Systems
    tryrrthg wrote: »
    I have read through some of those threads previously and there are some excellent choices amongst those designs.
    Testing
    Testing
    Testing
  • tryrrthg
    GV#27 wrote: »
    Yep, those guys know their ****. I wish I was that knowledgeable about speaker design.
  • ben62670
    ben62670 Posts: 15,969
    I am thinking the RS 7" 4's would be a good option. The Dayton's seem to be a little more honest with their ratings than some of the brand names. They are pretty flat too:)
    Or a wmtmw
    http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-374&ctab=2#Tabs
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-376
    Ben
  • ben62670
    http://www.htguide.com/forum/showthread.php4?t=27552 I like some of the speaker designs in the avitars;)
    Love the limited edit feature:rolleyes:
    Ben
  • tryrrthg
  • Early B.
    The Statement is cool, but not big enough. What I want is essentially a large floorstanding speaker for a center channel. Hell, I even thought about using one of my VMPS speakers as a center channel (16x16x44).:p
  • Early B.
    This center channel comes closest to what I'm trying to do. Check the specs:
    http://www.sierraaudio.com/loludspeakers/spc.html
  • Systems
    Here ya go.It even has the ever popular ring radiator tweet. http://clearwaveloudspeaker.googlepages.com/dynamic4ccpictures
    He sells a parts kit(no box) including all drivers and crossover parts for $452.
    Testing
    Testing
    Testing
  • ben62670
    GV#27 wrote: »
    Now those speakers are hot!
    Ben
  • Early B.
    GV#27 wrote: »
    Hell, yeah!!!! That's what I'm talking about!!!!
    Ben -- change of plans. Let's do this one.
    Thanks, GV.
  • ben62670
    Nope. Not doing it.
    Ben
  • Systems
    Early B. wrote: »
    Yeah it looks like it has the potential to give you a good kick in the berries with appropriate sound tracks.;):D
    Thanks, GV.
    Your welcome.Here is a link to his home page.http://clearwaveloudspeaker.googlepages.com/home
    Testing
    Testing
    Testing
  • Systems
    ben62670 wrote: »
    Nope. Not doing it.
    :eek:
    Testing
    Testing
    Testing
  • Early B.
    Nevermind...
  • ben62670
    I'll do it:) I was just kidding:D It does place it over budget, but that has to be one of the baddest centers I have seen. The TB mids are great performers from what I read. it does drop at about 75 pretty fast. The Dayton 8"er wants a huge box as in 8.5 feet to go low.The 7" Dayton kicks its butt all over the place. Also the 8" Silver flute romps it. Both will go to 40 3db down with a 4.5cf box.
    Ben
  • Systems
    ben62670 wrote: »
    He states with that measurement he didn't slice in the ports response,thats why the apparent drop in level below 75hz.He claims response into the 30s.:)
    All in all a nice little CC.
    Testing
    Testing
    Testing
  • ben62670
    I did model that Dayton, and the model agrees with his graph. The 7's would be able to drop down low, but the 8's can not pull it off. I would rather see 2 8's. It would not look as impressive, but the bass would be better. I just modeled 2 8's, and a 4 foot box tuned to 33hz with 2 3" vents 6.5 inches long would be flat to 40hz, and drop 3db at 30hz. 2 8's save $110, and he will be able to listen to all but the lowest notes on a pipe organ:D
    Ben
  • Early B.
    It's only 9" tall. Crazy question, but I gotta ask -- can we make it 12" without 'effing up the design? If not, I'll find a way to boost it by 3" once it's built so my TV will be centered at eye level.
  • ben62670
    real rough figure is 50.5x14x16
    Edit:I'm Also thinking some 5.5's for the mids to keep the power handling up. The tang bands don't like high power. I know:o
    Ben
  • Early B.
    ben62670 wrote: »
    Huh? Once I buy the kit, that's it.
    Ben -- what's the estimate on the cost of the cabinet? I'm waayyy overbudget.
  • ben62670
    Early B. wrote: »
    If you get the kit you still need to build the box, and finish it. Also you will not reach you design goals. I am thinking wmtmw. This would not only save money, but you will reach your goals. Who is going to finish the cab? I can veneer it for you, but you will stain, and clear coat it?
    Ben
  • Systems
    Early B. wrote: »
    The crossover was optimised for the 9" baffle but being as it is horzontal it likely won't affect response that much going to 12".However you do have to keep the internal volume the same so you can reduce the cabinet depth.
    ben62670 wrote: »
    Using 2 of them and crossing them over at what looks like around 350hz,PH shouldn't be an issue.
    Testing
    Testing
    Testing
  • ben62670
    2 8's $110
    2 5.5's $25
    http://www.madisound.com/catalog/product_info.php?manufacturers_id=150&products_id=844
    1 nippled tweeter $50
    http://www.madisound.com/catalog/product_info.php?manufacturers_id=153&products_id=1181
    I was thinking the double magnet Vifa, but the cheaper one should be a better match. It is 91.5 VS 92.7db. I would like to keep a resistor out of the tweetercuircuuit if possible. Also I prefer the Silver Flute 8's to the Dayton's. They are also cheaper, and go low.
    The drivers would be less than $200:)
    Ben
  • Systems
    ben62670 wrote: »
    How does it not reach his design goals?:confused:
    ben62670 wrote: »
    2 8's $110
    2 5.5's $25
    But with the kit you have an expertly designed crossover that according to the measurements does an excellent job of blending the drivers.The xover is the most important part.
    Testing
    Testing
    Testing
