DIY Super Center Channel
Not bad but won't dig real deep and the xmax is not even close to the Dayton I linked to.I use a variant of this in my mains crossing it over at 60 and 300.hzBen & GV --
What do you think about this driver --
http://www.madisound.com/catalog/product_info.php?products_id=834
Sensitivity may only be 88db but using 2 will add 6 db.Testing
Testing
Testing -
Which one?If you are reffering to the coax's response shown in the datasheet then yes the tweeters response is a bit rough but this is the raw response without the crossover.With the xover the response will be substantially smoother.I looked at that driver, and yuck! What a bumpy road:eek:
Several years ago I built a pair of speaks ( even had an article printed in a Speaker Builder ) using the first generation of the SEAS coax.It has a number of benfits that make it a good choice for center channel usage.Testing
Testing
Testing -
And also high efficiency driver with good sound (Fs) is very hard to achieve at this price point. It's like you gotta make a trade off between efficiency and sounds quality and decides what favors you. You can hardly get the best of both world under strict budget.
Agreed.
So what are tradeoffs? Perhaps my speakers won't go as low as I want them to. I can live with that. Maybe the speakers aren't high efficiency. I can live with that, too. But sound quality is the most important factor here, so that's where I need to focus my attention.
I agree with Ben's view of the ribbon tweeter. Yeah, vertical dispersion may be an issue, but it is not enough to rule it out, IMO. The VMPS center channel I sold yesterday was the best one I've owned and it had a ribbon tweeter and a ribbon midrange, but from what I could ascertain from the sitting position, vertical dispersion was never an issue. This center channel will sit even higher.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
How long were the ribbons in it?It's less of an issue with shorter ribbons.
Ah OK, I initially thought it would be sitting very low.This center channel will sit even higher.Testing
Testing
Testing -
The proposed ribbon tweeter will be 3".HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
My advice, build a proven design like the WTMW design built with the Dayton Reference Series drivers. Two 8 inch drivers.
summarized in these two threads
http://www.htguide.com/forum/showthread.php4?t=15323
http://www.htguide.com/forum/showthread.php4?t=22393
or there is the Statement center channel that uses a ribbon tweet, but only 6.5" mids.
http://www.htguide.com/forum/showthread.php4?t=27552Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I have read through some of those threads previously and there are some excellent choices amongst those designs.My advice, build a proven design like the WTMW design built with the Dayton Reference Series drivers. Two 8 inch drivers.
http://www.htguide.com/forum/showthread.php4?t=27552Testing
Testing
Testing -
Yep, those guys know their ****. I wish I was that knowledgeable about speaker design.I have read through some of those threads previously and there are some excellent choices amongst those designs.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I am thinking the RS 7" 4's would be a good option. The Dayton's seem to be a little more honest with their ratings than some of the brand names. They are pretty flat too:)
Or a wmtmw
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-374&ctab=2#Tabs
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-376Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
http://www.htguide.com/forum/showthread.php4?t=27552 I like some of the speaker designs in the avitars;)
Love the limited edit feature:rolleyes:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yep, the Statements look bad ****.
http://www.geocities.com/cc00541/Statements.html
http://www.htguide.com/forum/showthread.php4?t=28728Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
The Statement is cool, but not big enough. What I want is essentially a large floorstanding speaker for a center channel. Hell, I even thought about using one of my VMPS speakers as a center channel (16x16x44).:pHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
This center channel comes closest to what I'm trying to do. Check the specs:
http://www.sierraaudio.com/loludspeakers/spc.htmlHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Here ya go.It even has the ever popular ring radiator tweet. http://clearwaveloudspeaker.googlepages.com/dynamic4ccpictures
He sells a parts kit(no box) including all drivers and crossover parts for $452.Testing
Testing
Testing -
Now those speakers are hot!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Hell, yeah!!!! That's what I'm talking about!!!!
Ben -- change of plans. Let's do this one.
Thanks, GV.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Nope. Not doing it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yeah it looks like it has the potential to give you a good kick in the berries with appropriate sound tracks.;):DHell, yeah!!!! That's what I'm talking about!!!!
Your welcome.Here is a link to his home page.http://clearwaveloudspeaker.googlepages.com/homeThanks, GV.Testing
Testing
Testing -
Testing
Testing
Testing -
Nevermind...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I'll do it:) I was just kidding:D It does place it over budget, but that has to be one of the baddest centers I have seen. The TB mids are great performers from what I read. it does drop at about 75 pretty fast. The Dayton 8"er wants a huge box as in 8.5 feet to go low.The 7" Dayton kicks its butt all over the place. Also the 8" Silver flute romps it. Both will go to 40 3db down with a 4.5cf box.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
He states with that measurement he didn't slice in the ports response,thats why the apparent drop in level below 75hz.He claims response into the 30s.:)it does drop at about 75 pretty fast.
All in all a nice little CC.Testing
Testing
Testing -
I did model that Dayton, and the model agrees with his graph. The 7's would be able to drop down low, but the 8's can not pull it off. I would rather see 2 8's. It would not look as impressive, but the bass would be better. I just modeled 2 8's, and a 4 foot box tuned to 33hz with 2 3" vents 6.5 inches long would be flat to 40hz, and drop 3db at 30hz. 2 8's save $110, and he will be able to listen to all but the lowest notes on a pipe organ:DPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It's only 9" tall. Crazy question, but I gotta ask -- can we make it 12" without 'effing up the design? If not, I'll find a way to boost it by 3" once it's built so my TV will be centered at eye level.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
real rough figure is 50.5x14x16
Edit:I'm Also thinking some 5.5's for the mids to keep the power handling up. The tang bands don't like high power. I know:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Huh? Once I buy the kit, that's it.
Ben -- what's the estimate on the cost of the cabinet? I'm waayyy overbudget.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
If you get the kit you still need to build the box, and finish it. Also you will not reach you design goals. I am thinking wmtmw. This would not only save money, but you will reach your goals. Who is going to finish the cab? I can veneer it for you, but you will stain, and clear coat it?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The crossover was optimised for the 9" baffle but being as it is horzontal it likely won't affect response that much going to 12".However you do have to keep the internal volume the same so you can reduce the cabinet depth.It's only 9" tall. Crazy question, but I gotta ask -- can we make it 12" without 'effing up the design?
Using 2 of them and crossing them over at what looks like around 350hz,PH shouldn't be an issue.
Edit:I'm Also thinking some 5.5's for the mids to keep the power handling up. The tang bands don't like high power.Testing
Testing
Testing -
2 8's $110
2 5.5's $25
http://www.madisound.com/catalog/product_info.php?manufacturers_id=150&products_id=844
1 nippled tweeter $50
http://www.madisound.com/catalog/product_info.php?manufacturers_id=153&products_id=1181
I was thinking the double magnet Vifa, but the cheaper one should be a better match. It is 91.5 VS 92.7db. I would like to keep a resistor out of the tweetercuircuuit if possible. Also I prefer the Silver Flute 8's to the Dayton's. They are also cheaper, and go low.
The drivers would be less than $200:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
How does it not reach his design goals?Also you will not reach you design goals.
But with the kit you have an expertly designed crossover that according to the measurements does an excellent job of blending the drivers.The xover is the most important part.2 8's $110
2 5.5's $25
The drivers would be less than $200:)Testing
Testing
Testing
