body mass index test
  • hoosier21
    hoosier21 Posts: 4,418
    edited May 2003
    OK I had to take a physical this morning, got a correct weight.
    5-11 and 226lbs. = 31.5
    oh man do I feel better lol
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • faster100
    faster100 Posts: 6,124
    edited May 2003
    Originally posted by Vr3MxStyler2k3
    Faster im probally as big as you are...lol
    I doubt that, but maybe
    im 5' 10" 204lbs, and Italian.. LOL
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited May 2003
    hmm. no taller - just alot *bigger*. Dang....and italian.......sheat........im running....;)
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • TonyPTX
    TonyPTX Posts: 545
    edited May 2003
    Awe yeah....another dago in the house...power in numbers ma man...my family runs north Jersey.
    Damn....8 lines...I've gotta put my sig on a diet now....
  • gshisme
    gshisme Posts: 1,038
    edited May 2003
    my family runs north Jersey. [/B]
    So that is the reason why Jerseyites are flocking to Pa.:D
    suds, suds and more suds!
  • mantis
    mantis Posts: 17,400
    edited May 2003
    34.9
    I work out hard all the time,I train my **** off,I tweak my system and thousands others each and every day,I try my best to eat healthy and man I still need to loose weight.
    Where the chart for big boned muscular people?????
    Dan
  • mantis
    edited May 2003
    Man I don't look nothing like Phuz.......he has his own look as well do I.
    I'm better looking......LOL
    Dan
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2003
    Originally posted by mantis
    34.9
    Man, how can you be HK Fooey at 34.9???? ;)
    This chart SUCKS and is basically WRONG.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2003
    The chart is basically only funcitonal for health care professionals. Its more or less used as a referencing point to determine health risks and dosing guidelines based on studies. I don't think its really intended to tell someone whether or not they should lose weight.
    Most all of us should know whether or not we need to lose weight. Don't really listen to this chart. Just go look in the mirror.
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2003
    I'm scared to, every time I walk down the street people look at me funny...I really do not want to know why!!
  • geekmedic
    geekmedic Posts: 78
    edited May 2003
    Originally posted by RuSsMaN
    (seriously, you have to take those calculations with a grain of salt, by 'the chart' for my height, it 'says' I should weigh about 185. I would look like I was on crack if I weighed 200, much less 185.)
    Keep in mind that those ideal weight charts were based on data from the 60's. People generally were a lot thinner then, probably because of limited money (not to mention lack of a fast food joint on every block).
    BMI's are but one measure of a person's health status. Muscular individuals will have higher BMI's, but with lower body fat percentages.
    Generally, the medical community considers the following:
    BMI <19.5 = underweight
    BMI 20-25 = normal
    BMI 25-30 = overweight (must account for muscle status)
    BMI 30-35 = obese (health risks, possibly even if muscular)
    BMI >40 = morbidly obese
    Anyone with a BMI > 40 usually qualifies for surgical treatment (e.g., gastric bypass surgery).
    Time to hit the gym boys! (I speak from experience on this one!)
    Learn from yesterday, live for today, hope for tomorrow. - Albert Einstein
  • mantis
    edited June 2003
    Russ
    I don't know I just am.............Even us Fooey's need to do some trimming here and there.......;)
    Dan
  • Strong Bad
    Strong Bad Posts: 4,278
    edited June 2003
    I've seen this circulating for some years now.
    The problem is, it doesn't take into consideration the fat to lean bodymass ratio. It just assumes that all people are fat.
    You could be 6' 2", 230 lbs and be fat. You could also be 6'2", 230 lbs and be very lean and muscular.
    I use that because I'm 6'2" and run right around 230lbs. I scored a 29.1, so I'm literally borderline obese according to this. If you saw me in person, you would think otherwise. I would have to be under 200 lbs to be normal, which is freaking skinny for my height.
    It's stuff like this that cause some people to go on those rediculous weight loss diets!
    Ain't nothing like frying your legs on a set of hack-squats to the point where you just want to collapse on the floor and die! Wish I could do regular ones, but I messed my low back up years ago and don't want to risk doing it again.
    John
    John
    No excuses!
  • mantis
    edited June 2003
    I use weight training to compliment my Kung fu training.
    If you have injuries then I suggest Tai chi.Yoga as well.
    Dan
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2003
    I'm 6'2", 205 pounds. I could lose maybe 10 pounds of fat, which would put me at 195 and smack dab at the top of the normal category.
    I have a medium frame and maybe 15% body fat with decent muscle density and tone.
    Since I have 3 levels fused in my spine along with 12 titanium parts worth $18,000 bolted to my spine, the only exercise I do is brisk walking and bench press with my legs raised and crossed so I don't cheat.
    I taught Tai Chi locally a few years back and that helps too.
    I do three sets of 12 with 140 pounds three or four times per week - not exactly earth shattering but enough to keep my chest and arms strong and fairly muscular and enough to help me draw my hunting bow at 65-70 pounds.
    Doc
    SVS
  • geekmedic
    geekmedic Posts: 78
    edited June 2003
    I love the mushy feeling when you can barely walk after a good leg workout!! I've literally had my legs to give out when I was trying to walk down a set of stairs one time. Maybe I'm sadistic, but it was an awesome feeling. :D
    I can't do squats anymore either. My knees have taken quite an abuse over the past few years from all the jumps I've done (I'm a skydiver). They never hurt after a jump, and I'm landing correctly, but apparently they're getting microtears in my ligaments, ACL, etc. Lovely. Oh well, there's nothing like jumping out of a perfectly good airplane at 13,500 feet... not even a good workout can compare to that.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited June 2003
    Ought to conbine this and your fire arms training... might even be a video there...
    "Doc's Pistol Packin' Tai Chi Workout"... :D
    BTW, 29.8 here, but definitely not the same 29.8 I was 20 years ago...
    More later,
    Tour...
    Vox Copuli
  • Dr. Spec
    edited June 2003
    The only firearms I'll be firing anytime soon would be .22 LR rimfire, possibly the .223 Rem centerfire. In other words, no appreciable recoil. Don't want to break my spine into several small pieces.....
    I should be ready for the .44 Magnum revolver by deer season, but the 12 gauge slug gun will have to remain the exclusive domain of Edith this season. She is a very good shot; took a large doe last season at 110 yards with a perfect quartering away double lunger. I couldn't have been prouder.
    Doc
    SVS
  • Dr. Spec
    edited June 2003
    Gravity does have a way of redistributing the wealth, doesn't it tour? :o
    SVS
  • TroyD
    TroyD Posts: 13,124
    edited June 2003
    Doc
    Jesus,
    I know whose house I WON'T try and break into....:D
    BDT
  • Dr. Spec
    edited June 2003
    Originally posted by TroyD
    Jesus,
    BDT
    C'mon Troy, I'm sure you know your way around an M16, no?
    Doc
    SVS
  • Tour2ma
    edited June 2003
    :lol: Yeah, excepting that I swear my legs are getting smaller as well... If it were gravity, I'd expect to have a pair of 20 lb. ankles...
    BTW... I think Troy was talking about Edith's house... :D
    More later,
    Tour...
    Vox Copuli
  • TroyD
    TroyD Posts: 13,124
    edited June 2003
    Doc
    Heh, heh....I've seen one once or twice.
    BDT
  • gidrah
    gidrah Posts: 3,049
    edited June 2003
    At 33yrs I get a 24.8. Hey, finally somebody thinks I'm normal. It's not the size, but how you use it. I do alot of physical work (when at work), but it's mostly 25-40lb loads. My buddy (who does no physical work) would be considered obese. Then again his biceps are the size of my oversized calfs.
    Make it Funky! :)
  • RuSsMaN
    edited June 2003
    34.9
    I go to the gym, I work out hard yada yada yada....man, be effin honest for once. Your FAT because you don't do anything but eat effin Krispy Kremes and whack off in front of your B&K receiver.
    Cheers,
    Russ
