Damn, my SVS just died...
polrbehr
polrbehr Posts: 2,842
edited October 2008 in The Clubhouse
... and I have no idea why.
I just emailed SVS' cust. svc., described what happened (pretty much nothing),
now I'm waiting for a response from them. Stay tuned.
Post edited by polrbehr on
  • ohskigod
    ohskigod Posts: 6,505
    edited September 2008
    details my man,
    amp just die? does it turn on, make noise? whats the dillio
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • shadowofnight
    shadowofnight Posts: 2,735
    So no fire and brimstone...just up and quit working ? During heavy use or just when you tried to use it ?
    The first rule of Fight Club is you don't talk about Fight Club
  • Pauly
    Pauly Posts: 4,519
    from the way i read it. pretty much nothing...
    Life without music would
    treitz3 Posts: 19,974
    Check the circuit breaker if it's on a different circuit. If that ain't it, we'll see if their customer service is on par with Polks CS.
  • wingnut4772
    wingnut4772 Posts: 7,519
    My two are shaking now. Good luck.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Face
    Face Posts: 14,340
    Sorry to hear it. Bring it over tomorrow, I'll take a look at it for you. :)
  • polrbehr
    Just some quick fill-in info, it's an SVS PB12-NSD/2, purchased in May '07.
    Sub worked fine yesterday (watched some WOTW...again;), but with the volume on my AVR set to -20db, nothing major, IMO). Circuit OK, fuse OK too.
    Went to watch another DVD today, and nothing at all. The green LED comes on (always set to Auto, BTW), just no output. Settings on sub as follows> Gain set to about 10 O'clock, Auto-on enabled, Subsonic filter at 25Hz (no plugs used), Crossover disabled, Phase at 0.
    Settings on Denon AVR> Sub set to LFE +Main, crossed at 80Hz, all speakers set to small.
    Am I hearing the echoes of "Taps " in the distance?
  • Joe08867
    Joe08867 Posts: 3,919
    Does the speaker move or is it frozen?
    Have you tried powering it all the way down unplugging it and starting over?
    Sorry for your Loss.
  • Face
    Face Posts: 14,340
    There are two cones.
    Harry, push on each one to make sure they're not frozen. I'm betting it's the amp though.
  • shadowofnight
    Somehow, I didnt think subwoofers when I read that ;)
  • ohskigod
    I was so gonna go there, glad you beat me to it..LOL
  • goingganzo
    goingganzo Posts: 2,793
    put your fingeracross the end of the rca cable that is pluged in to the dennon that leads to the sub. if it makes noise it is your dennon not working.
  • polrbehr
    OK, quick update, got an email from SVS, gave me some detailed instructions on how to
    proceed from here. Pretty fast response time too, IMO. So far, so good.
  • McLoki
    McLoki Posts: 5,231
    If you plug the RCA jack into the left or right out rather than the sub out - do you get anything?
  • polrbehr
    McLoki wrote: »
    I didn't try that, but I did hook up a piece of speaker wire from my right main to the inputs on the sub, still nothing.
    I am getting the feeling that the amp is toast, though.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Is it still under warranty?
  • polrbehr
    It's supposed to be, per their website.
    This was purchased from SVS in May '07 (b-stock, but still covered).
    They have been excellent with everything so far, I don't see any problems here.
  • ohskigod
    polrbehr wrote: »
    you did turn the crossover on the amp to its lowest setting when you did that right? if the crossover setting on the amp is higher than your recievers setting, it is concievable that the sub would play nothing when you hooked up the speaker wire.
    I would take the rca out for the mains and go right into the sub and see if it plays. this would immediatly rule out any wierd reciever setting that could be causing this (part of me says if you have that green light on the amp, it shouldnt be fried.
    maybe pop the criver and see if a speaker wire from the amp to the speaker popped off (although that happenning on 2 drivers might be a stretch, still gotta rule it out.)
  • polrbehr
    OK, so far, so bad... it looks like one of the drivers is n/g?
    After flipping the thing over (and wearing out the battery on my cordless driver taking the thing apart), one of the drivers works OK, the other seems dead. Looks fine, all connections were solid, just no sound out of it.
    I am in agreement with you OSkiG, I do not believe the amp is fried after all, since the drivers are wired in series; if one dies they both die. Maybe that's to protect the other driver or the amp itself?
    Well, I sent the above info off to SVS' CS Dept., now just waiting to see what to do.
  • ohskigod
    well, if the driver dies the right way, pos or neg signal wont go to driver number 2, therefore driver 2 = no sound right along with driver # 1.
    kinda makes it an easy fix....jjst hinges on the hopes SVS will give you the driver gratis as opposed to paying for it. other than that......she'll be rumbling your **** soon either way :)
  • Serendipity
    Serendipity Posts: 6,975
    So the sub works fine with just one driver hooked up to the amp?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • m00npie
    m00npie Posts: 697
    What is the turn around time for getting the drivers back?
    Do you need mine since it's just sitting in a box right now?
    Let me know.
  • polrbehr
    m00npie wrote: »
    Let me know.
    Good question, probably a few days, I would think.
    Nah, it's all good. Moving mine around was plenty for me :D (and yours is heavier!!)
  • polrbehr
    OK, here's the deal.
    Got an email back from SVS CS this afternoon, they are going to replace the defective
    driver under warranty.
    I had the option of sending the defective one back first, or paying for a new one to be shipped to me right away, then sending back the bad one for a 100% credit ( I chose the latter).
    Either way, I have to pay for shipping the woofer back to them, fair enough.
    It's strange, because I wasn't really driving the thing too hard that day, and it's not like it just cut out while it was playing.
    At any rate, I think they did an excellent job responding to my emails, and for providing
    detailed instructions on how to proceed; I am not in the least bit surprised by this.
    We shall see how their shipping dept. is soon ;).
    Oh, and thanks for the help everyone!
  • Serendipity
    you got a PM ;)
  • Face
    Face Posts: 14,340
    polrbehr wrote: »
    That's pretty lame. Whatever happened to shipping a new one first so you don't have to wait? Prepaid return shipping would have been nice too.
  • Serendipity
    Face wrote: »
    Most companies require you to ship back the defective part before they ship out a new one. Well, at least that's been my experience with Palm and HP products.
  • dorokusai
    dorokusai Posts: 25,576
    This isn't any different from paying a core charge to get aftermarket parts modded on a vehicle. It's business, plain and simple. I'm sure he'll live before, during and after the process.
  • polrbehr
    Face wrote: »
    They are sending me a new one first...
  • Serendipity
    Can you take pics of the failed driver? I'm interested as to what went wrong...
