Can you "Y" from a preamp to a poweramp and sub?
Erik Tracy
Erik Tracy Posts: 4,673
I'm thinking of putting together a 2-channel rig using an older/used preamp that has no sub/rca out to a separate power amp.
But I also wanted to use the SVS PB-10 Sub - because of size and budget.
Can you use "Y" adapters off of a preamp to drive both a power amp and a sub?
Thanks,
Erik
Post edited by Erik Tracy on
  • George Grand
    George Grand Posts: 12,258
    edited September 2008
    Yup. You can also use a Tape Monitor Out but the signal will be fixed, not controlled by the volume control.
  • Erik Tracy
    Thanks!
    Is there such a thing as an 'audiophile' quality "Y" adapter? :D
    Erik
  • mantis
    mantis Posts: 17,374
    Check out Audioquest, they make nice Y splitters. They are Audiophile quality allday.
    Don't use the tape monitor, use left and right.
    Dan
  • Erik Tracy
    Thanks to all!
