Turntables - what makes the biggest difference?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2008
    Well I think just like a 2 ch or HT rig improvements are cumulative it's the same with a TT. There are some tweaks on a TT that make dramatic differences/improvements; e.g. VTA/SRA, azimuth & zenith adjustments; just to name a few.
    But that voodoo that I do can also be called do-do.:D
    mhardy6647 Posts: 35,180
    edited August 2008
    ... There are some tweaks on a TT that make dramatic differences/improvements; e.g. VTA/SRA, azimuth & zenith adjustments; just to name a few.
    Yeah, but those are freebies!
  • hearingimpared
    edited August 2008
    Not necessarily.;)
  • RutgersFTW
    RutgersFTW Posts: 458
    edited August 2008
    I'm trying to figure out what it is you're discussing and what it costs - what's the purpose of this speed controller? Isn't that what a strobe/pitch control setting is for?
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • strider
    strider Posts: 2,568
    edited August 2008
    RutgersFTW wrote: »
    Pro-ject makes a speed control box called the Speed Box, one version costs about $129 and the upgraded one is around $500, IIRC. The two tables mentioned don't have captive power cords, but a wall wart power supply. When you use the Speed Box, it plugs in between the 'table and the wall wart, regulating the power supply to the table. Neither of the 2 Pro-ject 'tables have a strobe/pitch control.
    Wristwatch--->Crisco
  • hearingimpared
    edited August 2008
    RutgersFTW wrote: »
    The purpose of the speed controller is to set the speed at exactly 33 1/3 or 45 rpm so that the pitch of the music is just right.
    Most tables except some the '80s tables like Technics don't have a strobe on them. Some do come with a pitch control but you have to have your own strobe wheel to do the adjustment. There are several companies that make after market strobe wheels and testers. VPI & KAB are two that come to mind.
    billbillw Posts: 7,727
    edited August 2008
    Technically, these speed controllers are only used with turntables that have AC synchronous motors. That means the motor runs off 60Hz (50Hz in Europe) AC power. The speed of the motor is determined by the frequency of the AC. In North America, there is very little fluctuation of that 60Hz frequency, so turntable motors (the AC sync type anyway) are pretty darn close to the right speed without any speed control whatsoever. They spin at whatever RPM their design was for (600 RPM is common) and the pulleys are sized to give you 33.5 RPM at the platter. These type turntables usually have a separate pulley for 45RPM playback.
    Most Tables that you see with speed/pitch controls built into the table are using DC motors, which are a totally different design.
    Now, enter the external speed controller. It basically uses a circuit to recreate an adjustable AC frequency output to feed the motor. If your turntable is running a little slow (maybe from a slipping belt), then you can up the frequency to say 60.5Hz or whatever it takes to give you 33.5 RPM at the platter. You can also up the speed of the motor to do 45RPM without changing the belt to the second pulley.
    Some swear by them, others say the improvement is marginal. It probably depends on the stability of the AC frequency in your area.
  • hearingimpared
    edited August 2008
    billbillw wrote: »
    Great explaination Bill. That is why mine is called a "Power Line Conditioner" and it has two pots; one for 33 1/2 and one for 45 rpms. I swear by mine as just not a tweak.
    edited August 2008
    IMHO, it takes a high end setup like yours to really benefit from these speed controllers. Its that last piece of the puzzle so to speak.
    I still need to step up to the SAMA on mine, but with the almost negligible use my VPI has seen in the last year, its not a priority right now. Someday though, when I can setup my system properly again...
  • RutgersFTW
    edited August 2008
    billbillw wrote: »
    That's a great answer. Thanks!
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
    SCompRacer Posts: 9,121
    edited August 2008
    I got one just in case your in the 'hood someday and stop in. ;) Mine has only one knob though. I gotta change the belt groove for 45. OK, it does help or I would have got rid of it.
    I snagged a used KAB Speedstrobe over a year ago and highly recommend it.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2008
    I just want to listen to music, on the hi-fi ;)
    I'm trying to make this turntable thing as simple as possible! The reason I am going with Pro-ject is that both dealers I have a long relationship with will take care of any setup, check-ups on setup, change a cartridge for me and re-setup the table/tonearm, etc! I wish I had time to learn all about the setup and adjustments, get the tools to do it myself, etc, but I don't.
    But I have to admit, this thread has provided a great education! My thanks to all!
    DKG999
  • shack
    shack Posts: 11,154
    edited August 2008
    dkg999 wrote: »
    I think you will be just fine. I'm currently using an entry level Goldring TT with a "better than the price would indicate' tone arm and cartridge. As I understand they are worth more that what the entire table sold for.
    I don't have to tweek it at all. I clean the LP if it needs it, a quick sweep with the CF brush, drop the arm and enjoy. I am enjoying the hell out of it. Simplicity at its best (at least in vinyl circles).
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2008
    shack wrote: »
    I utilized this technique with great success during many high school dates.;)
    If you don't think playing records is about sex then you have not had enough therapy.
    RT1
  • shack
    shack Posts: 11,154
    edited August 2008
    And since the the high school days....your technique is......?
  • reeltrouble1
    edited August 2008
    same thing, never mess with anything that works..........
    RT1
  • shack
    shack Posts: 11,154
    edited August 2008
    So getting them to "loosen up" with some PGA punch in the back seat of the Galaxie parked on a dead end road should still work....:D
  • dkg999
    dkg999 Posts: 5,647
    edited August 2008
    The 1970 Torino fastback had the best back seat! A Bread 8 track tape in the deck, drop the arm, and you're in :D
    DKG999
  • shack
    shack Posts: 11,154
    edited August 2008
    Better than a 1965 Ford Galaxie 4 door? I don't think so. Slide the front seat all the way forward...well...lets just say there was ample room to "stretch out" and "recline". ;)
  • hearingimpared
    edited August 2008
    Sorry guys but you are wrong. The '72 Riviera's back seat area was so large there was an echo back there.:eek:
    edited August 2008
    I can fold down the rear seats in our minivan and inflate a double size airbed...beat that ;)
  • rayslifecycle
    rayslifecycle Posts: 511
    edited August 2008
    Great Explanations by all in this post - quite an enjoyable read.........
    but I have to say that the Volvo 240 wagon with the back seat down makes a 6'3"long flat deck.....fits the air mattress, gets better fuel economy then the minivan when driving to make-out point, has lots of room to "drop the arm" - and nothing says sexy like borrowing moms station wagon.....
    edited August 2008
    shack wrote: »
    I had a '68 Galaxie 4 door! (The guy ordered it with a front bench seat, 390 and a 4 speed. My hand could slip while getting 2nd and 4th.:D) More room in the back, much better than my '68 Mustang fastback!!!!
    edited August 2008
    dkg999 wrote: »
    Me too. Really! I don't have best VTA setting written on all my LP's like Joe.:D
