2 Channel and HT in one?
wingnut4772 wrote: »If I get rid of the 2 channel can I use my Benchmark DAC with the receiver?
There you go GF.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Yes; you can use any of the analog inputs in your receiver.
That wouldn't defeat the purpose?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
This suggestion may be a little late, but, look at the Pioneer VSX-92TXH.
It's got zone2 & zone3 outputs. What I've been thinking about doing is use the zone 2 preouts for a 2 channel amp. No need for a seperate preamp.
It's rated @ 130wpc. The 94 model is 140wpc.
Check Tweeter, & BB(Magnolia) for clearance deals.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I found Pioneer VSX-91TXH for $499.88 at Vann's with free shipping and speakers.
That's where I got mine.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
How does it sound? I am looking at VSX-92.
With my very brief listening session, they made some tv peakers sound very sweet.:D I just wish I had bought the friggin thing when I had the chance.:(I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Going back to the OP's question,
If I understand correctly, you can connect all your 2ch sources to the 2 channel pre, and all your HT sources to the HT pre/AVR. When listening to 2ch, the HT pre is not in the signal chain; however, when listening to a HT source, the signal has to go through the AVR and the 2ch pre?
That should work fine, IMO. I may be wrong though...polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
This is mostly correct. The AVR has to be connected to the 2-channel pre because the front speakers are connected only to the 2-channel Preamp.
On a preamp that has an HT bypass you simply enable the bypass and the signal is routed directly from the AVR to the speakers. On a preamp without a bypass you need to select the appropriate input (i.e. AUX) on the preamp and then manually set the volume to some precalibrated level.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Thanks for the explanation.
BTW, I'm currently running a 2-channel HT and it works great:
http://www.polkaudio.com/forums/showthread.php?t=70062polkaudio RT35 Bookshelves
