2 Channel and HT in one?
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2008
    If I get rid of the 2 channel can I use my Benchmark DAC with the receiver?
    There you go GF.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited July 2008
    Ricardo wrote: »
    Yes; you can use any of the analog inputs in your receiver.
    That wouldn't defeat the purpose?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • obieone
    obieone Posts: 5,077
    edited July 2008
    This suggestion may be a little late, but, look at the Pioneer VSX-92TXH.
    It's got zone2 & zone3 outputs. What I've been thinking about doing is use the zone 2 preouts for a 2 channel amp. No need for a seperate preamp.
    It's rated @ 130wpc. The 94 model is 140wpc.
    Check Tweeter, & BB(Magnolia) for clearance deals.
  • MKZ
    MKZ Posts: 1,068
    edited July 2008
    I found Pioneer VSX-91TXH for $499.88 at Vann's with free shipping and speakers.
  • wingnut4772
    edited July 2008
    MKZ wrote: »
    That's where I got mine.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • MKZ
    MKZ Posts: 1,068
    edited July 2008
    How does it sound? I am looking at VSX-92.
  • obieone
    edited July 2008
    MKZ wrote: »
    With my very brief listening session, they made some tv peakers sound very sweet.:D I just wish I had bought the friggin thing when I had the chance.:(
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2008
    Going back to the OP's question,
    If I understand correctly, you can connect all your 2ch sources to the 2 channel pre, and all your HT sources to the HT pre/AVR. When listening to 2ch, the HT pre is not in the signal chain; however, when listening to a HT source, the signal has to go through the AVR and the 2ch pre?
    That should work fine, IMO. I may be wrong though...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • tcrossma
    tcrossma Posts: 1,301
    edited July 2008
    appadv wrote: »
    This is mostly correct. The AVR has to be connected to the 2-channel pre because the front speakers are connected only to the 2-channel Preamp.
    On a preamp that has an HT bypass you simply enable the bypass and the signal is routed directly from the AVR to the speakers. On a preamp without a bypass you need to select the appropriate input (i.e. AUX) on the preamp and then manually set the volume to some precalibrated level.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Serendipity
    edited July 2008
    tcrossma wrote: »
    Thanks for the explanation.
    BTW, I'm currently running a 2-channel HT and it works great:
    http://www.polkaudio.com/forums/showthread.php?t=70062
