i think i found out my danley subs weakness
thanks man, very curious whats in them.
how is measurement speclab done? thru lineout or a mic?my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Hi Slo,
Yeah, you can do it yourself if you have a PC with a sound card. Go to AVS forum and go to the front page of the Movies with waterfalls section. You can download the software right there. There are some set-up suggestions at the front too. Just run your PC's line out back to the line in and you'll get results. It is somewhat tedious to set up (kinda high learning curve).
I thought the DVD would come in the mail yesterday, but it didn't. Should be in tomorrow. -
Hi Slo,
Here is the spectrum off of SD DVD of the first part at around 4:57:
THere's not too much energy there, a little at 10 Hz, but more in the 35-60 Hz range. The DTS MA version will be considerably hotter, so yeah it could be bottoming your sub if it's rally cranked up. -
SG: thanks for doing that!
so...the room is not making the noise, both the conquest and the danley make that noise...i think it must be the preamp clipping.my 7.(1x4) HT setup
Buttkicker
Keek in mind some movies go into sub bass regions like War of the worlds chapter 13. I broke the cone off a Dayton Titanic III. If you can turn on a subsonic filter you may be in bussiness. My sub also over travels 30-40 hz or so. time to back off a notch if the filter does not cure your ills.
Ben -
i got this amp driving the danley, it does not have subsonic filtering...
http://www.faceaudio.com/product3,4.html
it might overdrive the danley...but will it be possible for the conquest to be overdriven too?
backing off a few notches helps...my 7.(1x4) HT setup
Buttkicker
Some sound tracks in DTS are dangerous. It may have a warning on the case like WOW has. Nearly any sub may fail at subsonic reagions.
Ben -
It's possible the pre is clipping before the sub is. (so the sub is accurately reproducing the clipped signal it is receiving.)
Just a thought.
mike, you might be right that the avp is clipping. i talked to a co-worker who has lots of experience with big auto subs/amps and he thinks that is the symptom of avp running out of steam. i will up the gain on the amp driving the sub and see how that goes...my 7.(1x4) HT setup
Buttkicker
problem fixed!!!
:D
previous setting: avp=+2.5dB, amp =-15dB...clips
now avp=+12.5dB and amp = -25dB...no more clipping
thanks all!my 7.(1x4) HT setup
Buttkicker
my 7.(1x4) HT setup
Buttkicker
speakergeek wrote: »Yeah I was refering to you. I thought you were going to get an SPL meter?
i got the SPL meter, set it to dBC and kept it on thru the whole rambo movie, some where in the movie, it reached 107.1dB - the AVP's volume control @ 0dBmy 7.(1x4) HT setup
Buttkicker
isnt that very loud at 0db, I never reach anything louder than -15, is your setup calibrated using the SPL meter?Shoot the jumper.....................BALLIN.............!!!!!
the spl meter has data logging capability and peak hold...i set it to peak hold and thats what it peaked somewhere in the movie. thruout the movie, its somewhere between 80-90+dB.
this is the 1st time i'm putting a spl meter to itmy 7.(1x4) HT setup
Buttkicker
where do you calibrate these things at anyways
with rambo@0dB on the avp - max is ~107dB
watching mr/mrs smith @-5dB
the gasline explosion reached ~110dB
my 7.(1x4) HT setup
Buttkicker
Slow reading & C scale is a start.
engtazengtaz
Calibrate everything at 75dbs, sub at 72dbs. Usually this is at -10 on the AVRs MV, but with separate amps, the gain can get wonky (I calibrate at 75dbs at -25). Reference level is 85dbs average with 20db peaks above 120hz and 30db peaks in the LFE range. With your subs, you should be seeing close to reference level peaks, I do (115db), without clipping. If calibrated correctly and you're not getting there, then it's probably cancellation issues in your square room.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
i measured the output of each speaker at listening position, audyssey puts all of them right at 75dB@0dB on the volume knob
looks like the PS3 is putting out a really high signal?my 7.(1x4) HT setup
Buttkicker
Yes, The PS3 amps there signal. It about blows you away when switching input. It is probably the same volume increase as commercials.
engtazengtaz
The way around that is to get an Avia or DVE (digital video essentials) disk. DVE is available in an HD version, I am not sure about Avia...
Anyway - they have test tones that are calibrated so you set your preamp to 0db and calibrate to 75db (with DVE) or 85db (with Avia) and your system will be calibrated to reference level.
Dolby reference level is (roughly) 85db (average volume) per channel with 105db peaks. The sub (when all speakers are set to small) will be required to output 115db peaks. DTS tracks are often 5-10db hot from these peak averages...
Since the test tones are run from a DVD, they take your entire system into account when setting the levels. I would say DVE or Avaya is required to truely calibrate a system. On either disk there is alot of information that will help calibrate and set up your display as well.
