i think i found out my danley subs weakness
  • SlowcarIX
    SlowcarIX Posts: 887
    edited July 2008
    thanks man, very curious whats in them.
    how is measurement speclab done? thru lineout or a mic?
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • speakergeek
    speakergeek Posts: 555
    edited July 2008
    Hi Slo,
    Yeah, you can do it yourself if you have a PC with a sound card. Go to AVS forum and go to the front page of the Movies with waterfalls section. You can download the software right there. There are some set-up suggestions at the front too. Just run your PC's line out back to the line in and you'll get results. It is somewhat tedious to set up (kinda high learning curve).
    I thought the DVD would come in the mail yesterday, but it didn't. Should be in tomorrow.
  • speakergeek
    edited July 2008
    Hi Slo,
    Here is the spectrum off of SD DVD of the first part at around 4:57:
    THere's not too much energy there, a little at 10 Hz, but more in the 35-60 Hz range. The DTS MA version will be considerably hotter, so yeah it could be bottoming your sub if it's rally cranked up.
  • SlowcarIX
    edited July 2008
    SG: thanks for doing that!
    so...the room is not making the noise, both the conquest and the danley make that noise...i think it must be the preamp clipping.
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Keek in mind some movies go into sub bass regions like War of the worlds chapter 13. I broke the cone off a Dayton Titanic III. If you can turn on a subsonic filter you may be in bussiness. My sub also over travels 30-40 hz or so. time to back off a notch if the filter does not cure your ills.
    Ben
    Ben
  • SlowcarIX
    edited July 2008
    i got this amp driving the danley, it does not have subsonic filtering...
    http://www.faceaudio.com/product3,4.html
    it might overdrive the danley...but will it be possible for the conquest to be overdriven too?
    backing off a few notches helps...
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    edited July 2008
    Some sound tracks in DTS are dangerous. It may have a warning on the case like WOW has. Nearly any sub may fail at subsonic reagions.
    Ben
    Ben
  • SlowcarIX
    edited July 2008
    McLoki wrote: »
    It's possible the pre is clipping before the sub is. (so the sub is accurately reproducing the clipped signal it is receiving.)
    Just a thought.
    mike, you might be right that the avp is clipping. i talked to a co-worker who has lots of experience with big auto subs/amps and he thinks that is the symptom of avp running out of steam. i will up the gain on the amp driving the sub and see how that goes...
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited July 2008
    problem fixed!!! :):p:D
    previous setting: avp=+2.5dB, amp =-15dB...clips
    now avp=+12.5dB and amp = -25dB...no more clipping :D
    thanks all!
    my 7.(1x4) HT setup
    Buttkicker
  • MikeC78
    MikeC78 Posts: 2,315
    edited July 2008
    MikeC78 wrote: »
    Just a thought... Could there be an issue with the amp keeping up?
    Hmmm?:p
  • SlowcarIX
    edited July 2008
    MikeC78 wrote: »
    Hmmm?:p
    newbie :o
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited July 2008
    Yeah I was refering to you. I thought you were going to get an SPL meter?
    i got the SPL meter, set it to dBC and kept it on thru the whole rambo movie, some where in the movie, it reached 107.1dB - the AVP's volume control @ 0dB
    my 7.(1x4) HT setup
    Buttkicker
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2008
    isnt that very loud at 0db, I never reach anything louder than -15, is your setup calibrated using the SPL meter?
  • SlowcarIX
    edited July 2008
    the spl meter has data logging capability and peak hold...i set it to peak hold and thats what it peaked somewhere in the movie. thruout the movie, its somewhere between 80-90+dB.
    this is the 1st time i'm putting a spl meter to it
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited July 2008
    Sherardp wrote: »
    where do you calibrate these things at anyways :confused:
    with rambo@0dB on the avp - max is ~107dB
    watching mr/mrs smith @-5dB
    the gasline explosion reached ~110dB
    my 7.(1x4) HT setup
    Buttkicker
  • engtaz
    engtaz Posts: 7,672
    edited July 2008
    Slow reading & C scale is a start.
    engtaz
    engtaz
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2008
    Calibrate everything at 75dbs, sub at 72dbs. Usually this is at -10 on the AVRs MV, but with separate amps, the gain can get wonky (I calibrate at 75dbs at -25). Reference level is 85dbs average with 20db peaks above 120hz and 30db peaks in the LFE range. With your subs, you should be seeing close to reference level peaks, I do (115db), without clipping. If calibrated correctly and you're not getting there, then it's probably cancellation issues in your square room.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • SlowcarIX
    edited July 2008
    i measured the output of each speaker at listening position, audyssey puts all of them right at 75dB@0dB on the volume knob
    looks like the PS3 is putting out a really high signal?
    my 7.(1x4) HT setup
    Buttkicker
  • engtaz
    engtaz Posts: 7,672
    edited July 2008
    Yes, The PS3 amps there signal. It about blows you away when switching input. It is probably the same volume increase as commercials.
    engtaz
    engtaz
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    The way around that is to get an Avia or DVE (digital video essentials) disk. DVE is available in an HD version, I am not sure about Avia...
    Anyway - they have test tones that are calibrated so you set your preamp to 0db and calibrate to 75db (with DVE) or 85db (with Avia) and your system will be calibrated to reference level.
    Dolby reference level is (roughly) 85db (average volume) per channel with 105db peaks. The sub (when all speakers are set to small) will be required to output 115db peaks. DTS tracks are often 5-10db hot from these peak averages...
    Since the test tones are run from a DVD, they take your entire system into account when setting the levels. I would say DVE or Avaya is required to truely calibrate a system. On either disk there is alot of information that will help calibrate and set up your display as well.
    Michael
