i think i found out my danley subs weakness
SlowcarIX
SlowcarIX Posts: 887
Eragon DTS-HDMA
Chp1 4:57
Chp5 19:19
i normally set vol @-10 or -8dB
i went 0dB and when it hit those 2 - it sounded awful...like it bottoms out or something :eek:
anyone knows what frequency range those are in?
found nothing here: http://www.avsforum.com/avs-vb/showthread.php?t=755493
"Eragon" DTS Blu-ray DTS-HD:MA
1. Chap 4 (0:15:03) 20Hz
2. Chap 6 (0:22:16) 25Hz
3. Chap 7 (0:28:57) 25Hz
4. Chap 9 (0:35:58) 20Hz
5. Chap 10 (0:40:55) 25Hz
6. Chap 13 (0:51:49) 20Hz
7. Chap 14 (0:57:53) 10 & 32Hz (Loudest)
8. Chap 15 (1:01:53) 20Hz
9. Chap 19 (1:21:42) 24Hz
10. Chap 21 (1:25:16) 20Hz
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2008
    Everything has it's limits. If you didn't hear the CLACK of a bottom, it was probably distortion. Do you know where Audessey calibrates reference level ? -0 maybe way above reference. I have mine calibrated to 75dbs @ -25, so -15 is reference. When I demo at reference it's almost enough to drive you out of the room. Most movies I watch are in the -25 to -20 range.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • MikeC78
    MikeC78 Posts: 2,315
    edited June 2008
    I would think it was bottoming out, that would be some insane distortion to be experiencing at those levels.
    Just a thought... Could there be an issue with the amp keeping up?
  • dkg999
    dkg999 Posts: 5,647
    edited June 2008
    I would just turn it down a few notches, get another glass of wine, and enjoy the rest of the movie :confused:
    DKG999
  • speakergeek
    speakergeek Posts: 555
    edited June 2008
    What was happening in that scene? Are you running at or above reference there (85 dB)?
  • SlowcarIX
    edited June 2008
    Ron Temple wrote: »
    i should be able to persuade the environmental/health/safety guys at work to let me take their dB meter home for a day. i guess i need a test dvd too? never tried sound level measurement b4...
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited June 2008
    They're pretty cheap at Radio Shack, and you will probably use it more than once.
  • SlowcarIX
    edited June 2008
    this is so annoying....so i got the conquest out and hooked it up and cranked it up to 0dB, it made that awful sound too! i think its something in the room is making the noise, or house is falling apart :eek:
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    Face wrote: »
    i need a test disc too?
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    er...the kid shot the deer and there was a flash of light and the 2nd one, the soccerer(sp??) was creating the razzak (sp??).
    i got no idea how loud it is...:confused:
    my 7.(1x4) HT setup
    Buttkicker
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2008
    Note to self........don't buy used subs from SC9;)
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited June 2008
    Have you tried any of the other disc from the AVS list in the OP? I've tried both of the Eragons scenes you posted, and while both get pretty low, my SVS didn't seem to have any trouble with it, maybe you have a bad disc, alot of earlier BD's where know to have little audio and video quirks.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    Keep in mind reference level is for a dolby track. DTS is often as much as 5-10db hot by comparison.
    Turn it down a little and go on with your life.... If push comes to shove - hook the conquest back up and run dual subs until it is sold....
    Michael
  • SlowcarIX
    edited June 2008
    lol...hope not too many ppl read this
    or my conquest will be on the FS section for a long time :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    this is the 1st time i notice it. i never play it at such head splitting level before - since its happening on both the conquest and the danley, either coming from the room or something else other than the subs
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    McLoki wrote: »
    Michael
    have to do that or i might have to increase 1dB every month due to hearing problems :o
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited June 2008
    Do you have your PC hooked up to your rig? Just download some test tones and play them till you find the frequency and/or level that's wrecking your foundation or bottoming out the driver. :D
  • SlowcarIX
    edited June 2008
    LOL
    nope no pc hooked up...
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    It's possible the pre is clipping before the sub is. (so the sub is accurately reproducing the clipped signal it is receiving.)
    Just a thought.
  • SlowcarIX
    edited June 2008
    its definitely not the poweramps clipping for sure- the dts20 has a 2000w bridged amp driving it, the conquest a 1000w. it doesnt seem to sound "electronic"...sounds mechanical/wooden come to think of it - the sounds is so non-directional, seems like the limit the dry walls can take ?...i'll track it down in the day time
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    Didn't say the amp - I was thinking the preamp before it sent the signal to the amp. Could also just be something in the house that resonates at that frequency / volume. (heck - could even be the DAC clipping)
    Either way, it does not sound like it is the sub...
  • Face
    Face Posts: 14,340
    edited June 2008
    Is the limiter on the amp disabled? Does the clipping light illuminate when this happens?
  • SlowcarIX
    edited June 2008
    nope no clipping light
    the limiter is en-abled. the guy that sold me the sub/amp told me that your amp company :) says that it will not affect the performance and its good to keep it there just to make sure it does not take out the sub ...
    i'm starting to believe its something in the room thats causing it
    my 7.(1x4) HT setup
    Buttkicker
  • Ron Temple
    edited June 2008
    Michael may be on the right track, could be the disk. Get a SPL meter...at least you'll know where you're at.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dholmes
    dholmes Posts: 1,136
    edited June 2008
    Are you guys talking about turning your avr volume to 0 & setting the sub level to 75 db with a spl meter?
    My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
  • speakergeek
    edited July 2008
    dholmes wrote: »
    Any SPL meter results yet?
    VR3 Posts: 29,610
    edited July 2008
    When I was running dual subs I ran an amp with a limiter ---
    When the limiter kicked in, the subs made the most horrendous sound. I kept them off and the headroom was greatly increased...
    Sometimes an amps gotta clip when an amps gotta clip... its important that it dosnt clip to long though :)
  • SlowcarIX
    edited July 2008
    who...me or him?
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited July 2008
    what does the limiter on the amp limit?
    my 7.(1x4) HT setup
    Buttkicker
  • speakergeek
    edited July 2008
    SlowcarIX wrote: »
    who...me or him?
    Yeah I was refering to you. I thought you were going to get an SPL meter?
  • speakergeek
    edited July 2008
    SlowcarIX wrote: »
    Eragon DTS-HDMA
    Chp1 4:57
    Chp5 19:19
    Hi Slo,
    I have the SD DVD version coming in the mail from NetFlix. I'll do a waterfall with SpecLab and see if thre is anything there.
