Speaker wire question.
Shannon W.
Ok guys Here it goes. Right now I'm using (I KNOW) Monster Cable 12ga speaker wire that I tinned then ends running under the floors of my house to go from floor plate to floor plate. I noticed that my floor plates can use coax type cable ends. would it be better to use like RG6u instead of the monster that I have now. (I only have monster cables because I bought all off them for penny's on the dollar, I've never paid retail for any of them) I have used RG6 before on some installs that I have done for family members subs but never thought about using it for all the mains.
Thanks for all your help!
Shannon
Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Post edited by Shannon W. on
RG6 is not speaker cable.Political Correctness'.........defined
President of Club Polk -
Thanks for that clarification. I was just wondering.
Shannon50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
How do you like your 7.2 configuration? I've been toying with this idea as my pre-amp/av receiver is set up for this if I wanted. Currently I'm using it with a 5.2 config.... and it's SHWEET!!!
I'm just curious how much of a difference the 2 extra surrounds make? Could you please give me you .02?
Thanks,
David -
I know RG-6 is not speaker wire, but on the recommendation of someone else I also used RG6 for running my sub (505) when finishing my basement. The drywall is not up, so should I replace it now (and with what) or will I be ok?
THanks for your help.CS400 For Sale -
skevill,
RG-6 is fine for what you're using it for."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If it is a low-level connection (RCA) to your sub, your fine. I wouldn't use RG6 for speaker cable--will it work? Yeah, but it's too small of gauge and not ideal for speaker connections.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks for the replies. Makes me feel better. I used the RG6 for the sub with RCA connections and in-wall speaker wire for everything else.
Thanks Again.CS400 For Sale
