Speaker wire question.
Shannon W.
Shannon W. Posts: 568
Ok guys Here it goes. Right now I'm using (I KNOW) Monster Cable 12ga speaker wire that I tinned then ends running under the floors of my house to go from floor plate to floor plate. I noticed that my floor plates can use coax type cable ends. would it be better to use like RG6u instead of the monster that I have now. (I only have monster cables because I bought all off them for penny's on the dollar, I've never paid retail for any of them) I have used RG6 before on some installs that I have done for family members subs but never thought about using it for all the mains.
Thanks for all your help!
Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Post edited by Shannon W. on
    F1nut Posts: 52,298
    edited June 2008
    RG6 is not speaker cable.
  • Shannon W.
    edited June 2008
    Thanks for that clarification. I was just wondering.
    Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • orgthtogod
    orgthtogod Posts: 41
    edited June 2008
    How do you like your 7.2 configuration? I've been toying with this idea as my pre-amp/av receiver is set up for this if I wanted. Currently I'm using it with a 5.2 config.... and it's SHWEET!!!
    I'm just curious how much of a difference the 2 extra surrounds make? Could you please give me you .02?
    Thanks,
    David
  • skevill
    skevill Posts: 38
    edited July 2008
    I know RG-6 is not speaker wire, but on the recommendation of someone else I also used RG6 for running my sub (505) when finishing my basement. The drywall is not up, so should I replace it now (and with what) or will I be ok?
    THanks for your help.
    CS400 For Sale
  • Face
    Face Posts: 14,340
    edited July 2008
    skevill,
    RG-6 is fine for what you're using it for.
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2008
    If it is a low-level connection (RCA) to your sub, your fine. I wouldn't use RG6 for speaker cable--will it work? Yeah, but it's too small of gauge and not ideal for speaker connections.
  • skevill
    skevill Posts: 38
    edited July 2008
    Thanks for the replies. Makes me feel better. I used the RG6 for the sub with RCA connections and in-wall speaker wire for everything else.
    Thanks Again.
    CS400 For Sale
