Whole-house audio system?
Serendipity
Serendipity Posts: 6,975
edited February 2009 in DIY, Mods & Tweaks
Anyone here have experience with installing a whole-house audio system like the NetStreams Musica or Elan/Crestron/AMX, etc. systems?
This is one of those projects I'd like to do someday and I'd like some tips to get started...
P.S. I like the Polk RC85 and RC65i inwall speakers, they sound great!!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
«134
  • Serendipity
    edited June 2008
    Would just like to add...
    I already removed all the drywall on the ceiling of my basement, so I'd like to run speaker wire inside there first before closing up the ceiling. I would assume that most distributed audio systems use Cat5e cabling and standard speaker wire, so I'll try to run that first.
    But I have no experience with whole-house audio systems so I'd like to know what I need to do this myself and any pointers to do this right.
    Thanks!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2008
    Just standing by to learn perhaps on this one, but if needed will add something for ya.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Serendipity
    edited June 2008
    I guess I can try running the in-wall rated speaker wire and the Cat5e first. But having never installed one of these systems, I'd like to know more before I prewire and make sure I understand all the details before I start taking out a drill and hammer ;)
    Maybe Jstas or one of the other network guys could chime in?
  • obieone
    obieone Posts: 5,077
    edited June 2008
    I thought there was another cable out that had more connections than cat5e now?
    BTW, I found a 250' roll of AQ14/4 CL3 rated cable at Tweeter for cheap money on clearance page. Might want to check the local ones, see if you can find a deal.
  • Serendipity
    edited June 2008
    obieone wrote: »
    Can you explain? I thought Cat5e was the industry standard.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2008
    When I want whole house audio, I just turn it up a little more :D
    DKG999
  • obieone
    edited June 2008
    I THOUGHT I saw a comm cable with a higher numerical designation than 5, last time I walked thru Home D. Like 6 or something. Not trying to push my neurosis on you, just don't want to see you close up the walls with a comm cable that may be obsolete in the near future:o
  • Serendipity
    edited June 2008
    obieone wrote: »
    Are you referring to a Cat6 cable? Most distributed audio systems seem to use the ethernet cable only for volume control/source selection/transport control, so I would think Cat5e would work fine. But like I said, I'm new to all this so I'm wondering if someone with experience installing these systems can chime in?
    Thanks!
  • disneyjoe7
    edited June 2008
    The problem I see here is that you haven't picked a brand to work with or know how there stuff works.
    I think there's systems which work with Cat5 cable for local control where the speaker wires go back to source with control Cat5 cable.
    There's systems which control some with Cat5 but volume local so speakers are wired to local control then speakers wiring goes back to source.
    This type above is what I installed in my house. So I feel is very flexible as I could always connect speaker wiring together behind local control to have it like the other style if needed. But since I did it with Niles controls, I don't knew if something else would need something else as in wiring needs.
    Also not a fan of 2 pair wiring unless it's just back to source from local control, as to speakers you alway would have one pair shorter then the other. I know others say it doesn't matter, but it my $.02 that's all.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Serendipity
    edited June 2008
    I thought they would be standardized so all you have to run is one Cat5 cable from the controller to every room, and a pair of speaker wire from the source to every room.
    But I guess this is not the case, so I'll have to pick out a system beforehand and then do the wiring.
    I'm mostly interested in the NetStreams Musica, Niles, and A-Bus systems. I like the A-Bus because you can use an Onkyo/Integra A-Bus receiver and then use that as a control center.
  • amulford
    amulford Posts: 5,020
    edited June 2008
    dkg999 wrote: »
    Word...
    If you need to have a system through the house, your system is weak;)
    J/K - I have done it on a reasonably small scale. Few different zones, centralized control. Nothing real high tech.
  • Serendipity
    edited June 2008
    amulford wrote: »
    Word...
    What kind of system did you install? And what brand controller did you use? I'm planning on something with 8-12 zones and centralized control so that you can pick an XM radio station, change CD tracks, or access a music server from any room in the house.
  • amulford
    edited June 2008
    No, when I say centralized, I mean control from one point. Source was switching was from one point and was global output. The volume was controlled in the rooms, but that's it.
    And I did it while the house was gutted. Basically I made it so music could be heard all through the house with out cranking the system (it wasn't my house, see above;)) I had speakers in the kitchen, formal living room, dining room, master bedroom, master bath, and on the patio.
    I used a Niles 12 channel amp Like this one, and I set all of the outputs to 75% gain to protect the speakers. 14 ga UL wire to a volume control Like this in each zone/room, then to the speakers. Source was taken from the HT I put in for them, but was it's own animal.
    You're looking for remote controlled source switching, which is different. That can be done, but it's ALOT more complicated. And alot more expensive. It's not hard to figure out, though. you would need to run extra cable, unless you use RF remote.
  • Serendipity
    edited June 2008
    amulford wrote: »
    Yeah. I want to be able to change FM radio stations, pick a song from a CD, or browse a music collection on a music server/HTPC from any room in the house. I know this is possible, since I've seen this kind of stuff at shows like CES, it's just more complicated to install.
    What would you recommend?
  • amulford
    edited June 2008
  • amulford
    edited June 2008
    You know who probably would have some good input to this is Mantis. I'm sure he's done a few...
  • Serendipity
    edited June 2008
    amulford wrote: »
    Is he a Polk custom installer? I'd like to know what installs he's done in the past before and their details. That would help a lot as I'm pretty much clueless about distributed audio systems and since I'm still a teenager, I'm on a budget here :)
  • amulford
    edited June 2008
    No, he works for Tweeter.
    You'd have to ask him.
    As far as the money, it ain't cheap. If you do go cheap, you'll regret it....
  • disneyjoe7
    edited June 2008
    I did something like what Anthony did, but I can control it with a IR remote from the local control locations. I just a single zone as if XM is being played out by the pool, if the other zones are on in the other areas of the house it must also hear XM. I also like the fact the local controls can be set to go on with in auto off so if the back end of house is listen to CD's from the changer, it did go on all over house. This feature as saved my a$$ with my neighbors as my system was being turned on by some IR noise from the outside controller and if it was playing I don't think my neighbors would live with that at 3am.
    BTW I'm using a Niles system also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Serendipity
    edited June 2008
    amulford wrote: »
    Well, like said before, I'm on a teenager budget but I still want something that works well. I've installed my own alarm system on a budget, remodeled my room on a budget, and did a HT on a budget too. So I think something like this is possible without spending thousands of $$$.
  • amulford
    edited June 2008
    That's why I went with the ones I did.
  • Serendipity
    edited June 2008
    That sounds like a cool feature, I don't think my neighbors would be too happy either if my music was blasting at 3am...
  • disneyjoe7
    edited June 2008
    amulford wrote: »
    Well I did like the ones I did because wish not to run around house turning them off if I didn't wish that section on. But I like the IR repeater function which I found more ways to use in the house like for a TiVo which has an output feed to a local in house channel. The IR repeater allows control of this TiVo from the local locations around house.
    But the auto off of the speakers are a must IMHO.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mantis
    mantis Posts: 17,408
    edited June 2008
    appadv wrote: »
    Yes I do,
    I have done from basic speaker selector boxes running off the B side of receivers to full Crestron systems.
    Basically you have to lay down your goals/needs/wants. How many rooms you want to do this in and then build a system that matches your needs.
    You can't build a multiroom on the cheap. No matter how you do it, the price adds up. A simple speaker selctor box, wire, inwall volume controls and speakers will run you a few grand depending on how many rooms you do.
    Crestron is for people who have alot of extra cash. There system start well over 10k and thats for a completely basic small system. Easy 30 to 50 grand for a nicer small system and the sky is the limit with Crestron. Liv4fam is doing a 1.4 million dollar Install and it's a full Crestron system.
    So I can help you but you need to give me some guide lines. Tell me want you wanna do and I'll point you to a Installer in your area. Multiroom systems are not for the Do it Yourself type people. Unless you want to build a very basic system, Leave it to the Pro's on this. The money on labor will be worth it's weight in gold.
    Dan
    Dan
  • Serendipity
    edited June 2008
    mantis wrote: »
    I was told the same thing when I installed my alarm system - it's too difficult, it's not for the DIY type person, and that I should go with an ADT or other commercially available system.
    Well, I decided to go and do it myself and guess what? Aside from a few technical issues, I was able to do it myself, 100%. It also gave me a feeling of satisfaction as I learned that I could get something done that I previously thought impossible. Now I'm a EE major and I'm studying Physics right now, so I believe that I CAN tackle a system like this myself and do a nice install.
    What do you think?
  • disneyjoe7
    edited June 2008
    appadv wrote: »
    But as Anthony stated the more you do with it the more $$ it cost. His volume controller is $45 where mine where like $190 but I saved in the source as I'm using an old pre-amp tuner and amp.
    Down the road if I wish I could replace the pre and amp for a Niles 6 zone amp and their better local controller which are wired with Cat5 only. So I wired good either way I go in the future. It all in the options.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Serendipity
    edited June 2008
    Well, I still want to do this even though it's "not for the do it yourself" people. Just look at Trey - he does a lot of stuff around the house and, IIRC, built his own deck. So nothing's impossible.
  • amulford
    edited June 2008
    You'd better start pricing stuff.
    Niles 8 source, 6 room
    In ceiling Polk RC80i's (your looking at 6 pair)
    Or in walls Polk RC85i's or Polk RC65i's(again your looking at 6 pair)
    Don't forget some In wall wire (I don't like the gauge, but it would work)
    You want to do more than six zones? Add it up.
    I'm not being smart, but realistic. I charged those people $10k for their whole house, my labor was only 3k. It ain't cheap.
  • Serendipity
    edited June 2008
    You have no idea how much gear you can get for "free" these days. A while back I got an Adcom GFA-535 that was broken. Well, $3 in parts later, I saved it from the dumpster, AND it was working as good as new.
    Take a look at this: http://electronics.search.ebay.com/as-is_Home-Audio_W0QQcatrefZC12QQdfspZ32QQfromZR40QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ14969QQsaobfmtsZinsifQQsatitleZasQ2dis
  • Serendipity
    edited June 2008
