Whole-house audio system?
Serendipity
Anyone here have experience with installing a whole-house audio system like the NetStreams Musica or Elan/Crestron/AMX, etc. systems?
This is one of those projects I'd like to do someday and I'd like some tips to get started...
P.S. I like the Polk RC85 and RC65i inwall speakers, they sound great!!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Would just like to add...
I already removed all the drywall on the ceiling of my basement, so I'd like to run speaker wire inside there first before closing up the ceiling. I would assume that most distributed audio systems use Cat5e cabling and standard speaker wire, so I'll try to run that first.
But I have no experience with whole-house audio systems so I'd like to know what I need to do this myself and any pointers to do this right.
Thanks!polkaudio RT35 Bookshelves
Just standing by to learn perhaps on this one, but if needed will add something for ya.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I guess I can try running the in-wall rated speaker wire and the Cat5e first. But having never installed one of these systems, I'd like to know more before I prewire and make sure I understand all the details before I start taking out a drill and hammer
Maybe Jstas or one of the other network guys could chime in?polkaudio RT35 Bookshelves
I thought there was another cable out that had more connections than cat5e now?
BTW, I found a 250' roll of AQ14/4 CL3 rated cable at Tweeter for cheap money on clearance page. Might want to check the local ones, see if you can find a deal.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Can you explain? I thought Cat5e was the industry standard.polkaudio RT35 Bookshelves
When I want whole house audio, I just turn it up a little more
DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I THOUGHT I saw a comm cable with a higher numerical designation than 5, last time I walked thru Home D. Like 6 or something. Not trying to push my neurosis on you, just don't want to see you close up the walls with a comm cable that may be obsolete in the near future:oI refuse to argue with idiots, because people can't tell the DIFFERENCE!
Are you referring to a Cat6 cable? Most distributed audio systems seem to use the ethernet cable only for volume control/source selection/transport control, so I would think Cat5e would work fine. But like I said, I'm new to all this so I'm wondering if someone with experience installing these systems can chime in?
The problem I see here is that you haven't picked a brand to work with or know how there stuff works.
I think there's systems which work with Cat5 cable for local control where the speaker wires go back to source with control Cat5 cable.
There's systems which control some with Cat5 but volume local so speakers are wired to local control then speakers wiring goes back to source.
This type above is what I installed in my house. So I feel is very flexible as I could always connect speaker wiring together behind local control to have it like the other style if needed. But since I did it with Niles controls, I don't knew if something else would need something else as in wiring needs.
Also not a fan of 2 pair wiring unless it's just back to source from local control, as to speakers you alway would have one pair shorter then the other. I know others say it doesn't matter, but it my $.02 that's all.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I thought they would be standardized so all you have to run is one Cat5 cable from the controller to every room, and a pair of speaker wire from the source to every room.
But I guess this is not the case, so I'll have to pick out a system beforehand and then do the wiring.
I'm mostly interested in the NetStreams Musica, Niles, and A-Bus systems. I like the A-Bus because you can use an Onkyo/Integra A-Bus receiver and then use that as a control center.polkaudio RT35 Bookshelves
Word...
If you need to have a system through the house, your system is weak;)
J/K - I have done it on a reasonably small scale. Few different zones, centralized control. Nothing real high tech. -
Word...
What kind of system did you install? And what brand controller did you use? I'm planning on something with 8-12 zones and centralized control so that you can pick an XM radio station, change CD tracks, or access a music server from any room in the house.polkaudio RT35 Bookshelves
No, when I say centralized, I mean control from one point. Source was switching was from one point and was global output. The volume was controlled in the rooms, but that's it.
And I did it while the house was gutted. Basically I made it so music could be heard all through the house with out cranking the system (it wasn't my house, see above;)) I had speakers in the kitchen, formal living room, dining room, master bedroom, master bath, and on the patio.
I used a Niles 12 channel amp Like this one, and I set all of the outputs to 75% gain to protect the speakers. 14 ga UL wire to a volume control Like this in each zone/room, then to the speakers. Source was taken from the HT I put in for them, but was it's own animal.
You're looking for remote controlled source switching, which is different. That can be done, but it's ALOT more complicated. And alot more expensive. It's not hard to figure out, though. you would need to run extra cable, unless you use RF remote. -
Yeah. I want to be able to change FM radio stations, pick a song from a CD, or browse a music collection on a music server/HTPC from any room in the house. I know this is possible, since I've seen this kind of stuff at shows like CES, it's just more complicated to install.
What would you recommend?polkaudio RT35 Bookshelves
Niles.
You know who probably would have some good input to this is Mantis. I'm sure he's done a few...
Is he a Polk custom installer? I'd like to know what installs he's done in the past before and their details. That would help a lot as I'm pretty much clueless about distributed audio systems and since I'm still a teenager, I'm on a budget here
No, he works for Tweeter.
You'd have to ask him.
As far as the money, it ain't cheap. If you do go cheap, you'll regret it.... -
I did something like what Anthony did, but I can control it with a IR remote from the local control locations. I just a single zone as if XM is being played out by the pool, if the other zones are on in the other areas of the house it must also hear XM. I also like the fact the local controls can be set to go on with in auto off so if the back end of house is listen to CD's from the changer, it did go on all over house. This feature as saved my a$$ with my neighbors as my system was being turned on by some IR noise from the outside controller and if it was playing I don't think my neighbors would live with that at 3am.
BTW I'm using a Niles system also.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Well, like said before, I'm on a teenager budget but I still want something that works well. I've installed my own alarm system on a budget, remodeled my room on a budget, and did a HT on a budget too. So I think something like this is possible without spending thousands of $$$.polkaudio RT35 Bookshelves
That's why I went with the ones I did. -
That sounds like a cool feature, I don't think my neighbors would be too happy either if my music was blasting at 3am...polkaudio RT35 Bookshelves
Well I did like the ones I did because wish not to run around house turning them off if I didn't wish that section on. But I like the IR repeater function which I found more ways to use in the house like for a TiVo which has an output feed to a local in house channel. The IR repeater allows control of this TiVo from the local locations around house.
But the auto off of the speakers are a must IMHO.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Yes I do,
I have done from basic speaker selector boxes running off the B side of receivers to full Crestron systems.
Basically you have to lay down your goals/needs/wants. How many rooms you want to do this in and then build a system that matches your needs.
You can't build a multiroom on the cheap. No matter how you do it, the price adds up. A simple speaker selctor box, wire, inwall volume controls and speakers will run you a few grand depending on how many rooms you do.
Crestron is for people who have alot of extra cash. There system start well over 10k and thats for a completely basic small system. Easy 30 to 50 grand for a nicer small system and the sky is the limit with Crestron. Liv4fam is doing a 1.4 million dollar Install and it's a full Crestron system.
So I can help you but you need to give me some guide lines. Tell me want you wanna do and I'll point you to a Installer in your area. Multiroom systems are not for the Do it Yourself type people. Unless you want to build a very basic system, Leave it to the Pro's on this. The money on labor will be worth it's weight in gold.
DanDan
I was told the same thing when I installed my alarm system - it's too difficult, it's not for the DIY type person, and that I should go with an ADT or other commercially available system.
Well, I decided to go and do it myself and guess what? Aside from a few technical issues, I was able to do it myself, 100%. It also gave me a feeling of satisfaction as I learned that I could get something done that I previously thought impossible. Now I'm a EE major and I'm studying Physics right now, so I believe that I CAN tackle a system like this myself and do a nice install.
What do you think?polkaudio RT35 Bookshelves
But as Anthony stated the more you do with it the more $$ it cost. His volume controller is $45 where mine where like $190 but I saved in the source as I'm using an old pre-amp tuner and amp.
Down the road if I wish I could replace the pre and amp for a Niles 6 zone amp and their better local controller which are wired with Cat5 only. So I wired good either way I go in the future. It all in the options.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Well, I still want to do this even though it's "not for the do it yourself" people. Just look at Trey - he does a lot of stuff around the house and, IIRC, built his own deck. So nothing's impossible.polkaudio RT35 Bookshelves
You'd better start pricing stuff.
Niles 8 source, 6 room
In ceiling Polk RC80i's (your looking at 6 pair)
Or in walls Polk RC85i's or Polk RC65i's(again your looking at 6 pair)
Don't forget some In wall wire (I don't like the gauge, but it would work)
You want to do more than six zones? Add it up.
I'm not being smart, but realistic. I charged those people $10k for their whole house, my labor was only 3k. It ain't cheap. -
You have no idea how much gear you can get for "free" these days. A while back I got an Adcom GFA-535 that was broken. Well, $3 in parts later, I saved it from the dumpster, AND it was working as good as new.
Take a look at this: http://electronics.search.ebay.com/as-is_Home-Audio_W0QQcatrefZC12QQdfspZ32QQfromZR40QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ14969QQsaobfmtsZinsifQQsatitleZasQ2dispolkaudio RT35 Bookshelves
This looks tempting: http://cgi.ebay.com/Onkyo-TX-SR705-7-1-THX-3HDMI-Receiver-AS-IS-FOR-REPAIR_W0QQitemZ220250044859QQihZ012QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also this one: http://cgi.ebay.com/Onkyo-TX-SR702-AS-IS-Parts-Repair_W0QQitemZ120277638351QQihZ002QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have the latter one and it's got 3-zone, multi-source capability. I wonder how well that'll work in a distributed audio setup??polkaudio RT35 Bookshelves
