which is better, epik conquest or danley dts-20
SlowcarIX
which is a more capable sub:
http://www.epiksubwoofers.com/C2.pdf
vs.
http://www.danleysoundlabs.com/pdf/Danley%20DTS-20%20Spec%20Sheet_r3.pdf
vs.
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
I'm thinking you need to pair the Danley with some Growlers
. Seriously, the Danley probably has a bit more SPL, but once you get to this level of bass, the tradeoffs in capability are very subjective. Unless you have a room that can handle 125dbs + of course.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
there is one FS in austin....:eek:
http://www.avsforum.com/avs-vb/vbclassified.php?do=ad&id=5233
i should check it out
my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Ron Temple wrote: »I'm thinking you need to pair the Danley with some Growlers
going to check it out tomorrow morning...if all goes well, i can regain the use of the front door...the dts-20 has a 18"x20" footprint
my 7.(1x4) HT setup
Buttkicker
lets see which one stays...my 7.(1x4) HT setup
Buttkicker
You have officially lost your mind, lol!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
there is really no better way of testing it out than in your own listening room...
hey check out this pic
my 7.(1x4) HT setup
Buttkicker
True about testing them out in your own listening room. I just feel bad for the foundation of your house.
LOL @ the amp picture. Crap, I'll have to think of another name when I start up my own business."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
that is fooking insane. I must say, I like the way you think though. A guy who loves toys is definitely a pal of mine. Whats next? The only thing to throw at you is a sealed dedicated theater room with a projector.Shoot the jumper.....................BALLIN.............!!!!!
the house was built in 2006, its still settling and there are cracks around ceiling/walls...some bass hopefully will settle it quicker so i can patch up the cracks once and for all
my 7.(1x4) HT setup
Buttkicker
next...i got to decide which sub to keep
my 7.(1x4) HT setup
Buttkicker
keep both
The Conquest didn't last long...Are you going to sell it?
My money is on the Conquest, although the Danley looks mighty menacing.
I think the Danley would work better if you laid it horizontally underneath your TV.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Isn't Danley a pro- audio sub? I thought that stuff was more for out doors (concerts).
speakergeek wrote: »Isn't Danley a pro- audio sub? I thought that stuff was more for out doors (concerts).
Google is your friend....
Based on the first bulleted use, I think his home theater room should / would qualify as a house of worship....
I know Rich a little bit. We talk once in awhile. He told me recently that he was seriously downsizing, so I guess you got his Danley. Congrats. He also had an eD A7-900 and Conquest that he sold to another TX local not that long ago. I thought he had a pair of Growlers hooked up with the Danley, but I might be confusing him with another basshead.
I imagine, there's some seriously tactile impact with that sucker.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Heh, Rich sent me a couple of PMs this morning. He's subless now and ordered an Ultra for his upstairs (smaller) HT room. Coinkydink :eek:
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
my 7.(1x4) HT setup
Buttkicker
speakergeek wrote: »The Conquest didn't last long...Are you going to sell it?
i'm like the dts-20 more so far...i think conquest will go to new home......my 7.(1x4) HT setup
Buttkicker
when compared w/ the conquest, the danley is able to resolve midbass slightly better - i use the rebecca pigeons spanish harlem. the bass from the danley seems quicker, more accurate...maybe no as deep
i need to go from free standing tv/component stand to wall mounted to put sub under tv. but i dont know if the dry wall can take the weight of the cdp, 2 amps, powersupply and the bits and pieces - those weigh close to 200lbs. vibrations from the walls during those deep bass notes will be an issue if the shelf is wall mounted...cdp and bluray play will skip!...my 7.(1x4) HT setup
Buttkicker
i think it is....the attention to construction details is not as good as the conquestmy 7.(1x4) HT setup
Buttkicker
Ron Temple wrote: »I know Rich a little bit. We talk once in awhile. He told me recently that he was seriously downsizing, so I guess you got his Danley. Congrats. He also had an eD A7-900 and Conquest that he sold to another TX local not that long ago. I thought he had a pair of Growlers hooked up with the Danley, but I might be confusing him with another basshead.
yep, i stole the dts-20/amp combo from rich. the danley was in perfect condition and the amp..., still smells new! he was nice to give me a very nice interconnect and speaker cable too
one thing i found out about the dts-20 is the bass energy from the 2 square bass ports can be very directional. i aimed it parallel to the wall behind the tv and it was causing the tv screen to flex during heavy bass and making noise. so i just turned it to aim at the listening position and it feels good even when the buttkicker is off and no more screen noisemy 7.(1x4) HT setup
Buttkicker
Ron Temple wrote: »Heh, Rich sent me a couple of PMs this morning. He's subless now and ordered an Ultra for his upstairs (smaller) HT room. Coinkydink :eek:
:eek: more sub?? i need he needs a buttkicker too
i invited him to come over to audition my setup when he has time
actually, a svs cylinder sub upstairs of his house will be nice. i heard sami's cylinder sub on his upstairs ht room, the bass causes the wooden floor to move - feels so much better than buttkicker under a couch.my 7.(1x4) HT setup
Buttkicker
That is an insane subwoofer:eek:Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable -
Yo, Slow -- did you decide which sub you were gonna keep yet?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
What's the verdict? Which one is best?
i think i'm going to keep the danley....i've been in orlando since monday, will go back and play with it a little more and then decide
what i like about the danley so far...
-small foot print, so i can use the front door again
-i can aim "shockwaves"
from the 2 ports at me and that i notice causes less rattling in the room (wall, dlp screen, blinds....) yet still feel the same bass
-midbass is cleaner/more detailed for 2chmy 7.(1x4) HT setup
Buttkicker
Ever tried decoupling? Get yourself a gramma, should take care of a lot of those rattles. -
I would equate the rattling with more subsonic bass.
yep, both the conquest and the dts-20 - double stack of silicone rubber, harder layer (consistency of M+S tire) on floor side and softer layer (consistency slightly softer than r-compound tire) on sub side
the rattles come from the compression/rarefaction waves causing stuff to resonate...not from sub cabinet coupling to the groundmy 7.(1x4) HT setup
Buttkicker
