Firefox 3
    billbillw Posts: 7,733
    edited June 2008
    appadv wrote: »
    Maybe it's my antivirus, which is Norton. Reason being I was able to install it on another PC fine without any problems. That PC didn't have Norton, but I think I will install an antivirus sometime in the near future.
    Norton will Eff up just about everything. Get rid of it and go with AVG.
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2008
    billbillw wrote: »
    Even if I still have a subscription remaining on Norton?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Face
    Face Posts: 14,340
    edited June 2008
    Norton is a resource hog. One of the best things I ever did for my computer was get rid of it.
    It can't hurt to un-install it and try something else, such as AVG. And if you don't like it, you can always go back for the remainder of your subscription.
  • Serendipity
    edited June 2008
    I always used Norton in the past.
    Maybe that's why I have more computer problems than anyone you know?
    edited June 2008
    appadv wrote: »
    That wouldn't surprise me. I used to have Norton AV and their Utilities. They had a system scan/repair application that usually made more problems than it solved.
    Since I went with 64bit windows (and was forced to find something other than Norton), I haven't had a single computer problem to speak of. That was in 2006.
    The only Norton app that I still use is Ghost for backups.
  • MikeC78
    MikeC78 Posts: 2,315
    edited June 2008
    I use Avast 4.8 and Spybot, both were free and work great.
  • janmike
    janmike Posts: 6,146
    edited June 2008
    Ever since I loaded Firefox the web sites that would not load with IE now load. I deleted the old IE, reloaded it and they still would not load. There were only about 4 or 5, but it was annoying (Expedia, some MSN, Weather Network....).
    Both the wife and I agree that loading Firefox was a huge increase in performance. Looks like it is here to stay. Thanks for the head up.
    Michael ;)
    NORTH of 60°
