QUICK!Handy Guys, I Need Some Help.
wingnut4772
wingnut4772 Posts: 7,519
edited June 2008 in The Clubhouse
My (for the lack of a better word I'll call him Painter :mad:) is almost done with my room but I have a problem. The wall where he pulled down cabinets had some drywall damage from the tear down. So he did a little joint compound action to smooth out the divots. BUT now when the wall is painted these compunded spots are flat where I need them to have the same sheen as the rest of the wall. It's so important because a ton of light will be focused on this wall. What can I ( meaning He) do to get the sheen consistent?
(You can see the flat spots in the photo near the picture on the right (inside) and a couple of other spots.)
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
«13
  • bikezappa
    bikezappa Posts: 2,463
    edited June 2008
    I have matched the texture of the wall with joint compound and a wet sponge.
    apply joint compound, ley dry a little and apply sponge and pull it directly away from wall do this until it matches the texture of the original wall.
    let dry and paint
  • strider
    strider Posts: 2,568
    edited June 2008
    +1 to above. It may take a couple of attempts to match it well, but definitely your best option.
    Wristwatch--->Crisco
  • amulford
    amulford Posts: 5,020
    edited June 2008
    I hate when that happens, but it always does. You have sand those spots baby **** smooth then proceed to scuff the entire wall with a rough sand paper, like 60 grit, VERY well. Then you have to start all over with the finish, ie a good primer and al least 2 finish coats. Tint the primer and the finish coats will cover quicker.
    Good luck...
  • wingnut4772
    edited June 2008
    Crap. This needs to be finished today. I don't have time to do the whole wall. Do you really think some more compound and the sponge will work?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • ND13
    ND13 Posts: 7,601
    edited June 2008
    Cover it up with a HUGE Ace Frehley poster,.....the one with his smoking space boots.:D:D:p
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Rivrrat
    Rivrrat Posts: 2,101
    edited June 2008
    Are you talking the texture or the paint?
    If it's texture, it'll need to be texture matched. If the paint has flatter gloss spots where the now patches are, the patches will need to be primed, something a painter should've known.
    I learned about priming sheetrock and joint compound the hard way. :rolleyes:
    My equipment sig felt inadequate and deleted itself.
  • wingnut4772
    edited June 2008
    ND13 wrote: »
    Wow! Problem solved! Thanks!:D Actually, the art will end up covering a big portion BUT..not enough. I may have to go larger with the art work. Here's my alternative. I had counted them out because the scale was too large but....
    Keep in mind they are just sitting on the bed for an idea, not hung yet.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Rivrrat
    edited June 2008
    Looking at the pic, I'd say the patches need to be redone, sanded and then primed.
    My wife threw some contractors doing insurance work out of our house for simillar issues.
  • wingnut4772
    edited June 2008
    Rivrrat wrote: »
    Texture. It was all painted new with this color. I thought that it was just that the compound was absorbing the paint differently or something.....
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • TroyD
    TroyD Posts: 13,124
    edited June 2008
    Yeah, suck it up and do it right......I'd rather take the extra time and have it done right than get a nasty surprise when I eventually moved the pictures.
    BDT
  • amulford
    edited June 2008
    Darla, the underlying coats of paint have a different surface finish than the cover. The paint develops a shell. Unless you do the whole wall, you will still have the same problem.
    As far as it getting done today, it can be done, it'll just be a long day. Sorry ,but it B's like that sometimes...
  • wingnut4772
    edited June 2008
    My 'painter' just showed up and said it just needed another coat. I called my real painter (who was unavailable over the weekend) and he said he would try to come by tomorrow to fix it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • janmike
    janmike Posts: 6,146
    edited June 2008
    Good luck Darla. Hope things work out.
    Michael ;)
    NORTH of 60°
  • Early B.
    Early B. Posts: 7,900
    edited June 2008
    Wing --
    Paying these painters to do it right is eating into your profit, huh?
    It's tough to rely on other "professionals" when your business and image are on the line.
    It's a hard lesson, but if you're gonna take on small jobs like this one, you gotta do all of the work yourself.
    "God grooves with tubes."
  • demaples
    demaples Posts: 266
    edited June 2008
    Hey there, another way to fix it is go to your local Home Depot or Lowes, go to the paint section and either ask or look for "spray on texture". It comes with several tips for different textures.
    Dennis
    Hitachi 50" Plasma full HD 1080--Onkyo 805 AVR
    Rotel RMB-1077 amp--Polk LSic center
    Polk LSi25 fronts--Polk LSi 15 rears
    Genesis G-2800 sides--Polk PSW 650 sub
    APC H15 power conditioner--Netgear digital media player
    Napster external hardrive--Linksys Wireless G router
    Samsung DVD--Blue Jeans wires
  • bikezappa
    edited June 2008
    Crap. This needs to be finished today. I don't have time to so the whole wall. Do you really think some more compound and the sponge will work?
    yes i have done it successfully. you need to feather it. also the dark coat will show up any defects much more.
    it's trail and error
    billbillw Posts: 7,474
    edited June 2008
    Sounds like the underlying problem was that the painters did not put a coat of primer on top of the joint compound. I've seen this many times. The joint compound is much more porous than the normal sheet rock and it drys out the paint faster.
    I always put a coat of Zinwell primer on the spackle/ joint compound before painting. You will almost always need 2 coats of paint on top of the primer, but it eventually has the same texture.
  • Rivrrat
    edited June 2008
    That could be, and if it is, the patch spots will need to be primed.
  • wingnut4772
    edited June 2008
    Early B. wrote: »
    Wing --
    Unfortunately, there is no profit. I am doing it as a favor for the friend who has let me stay with her.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    edited June 2008
    I called the 'painter' again and he says he swears he will fix it so we will see. Anyway, I hope the real deal can come go over his mistakes.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Jstas
    Jstas Posts: 14,977
    edited June 2008
    I think you need one of these.
    Not only will it take care of that wall, it'll adjust the attitude of your 'painter' too! Like Alton Brown says, it's a multi-tasker!
    HIWAFH!
    Expert Moron Extraordinaire
  • wingnut4772
    edited June 2008
    I told him to pick up some 'Killz' primer and he insisted he didn't need it and he would fix it. I just went back there to see what he had done and it's horible. A drippy mess. What an ****.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Jstas
    Jstas Posts: 14,977
    edited June 2008
    Maybe you didn't see my post?
    Here it is again, just to be sure.
    Jstas wrote: »
    HIWAFH!
    It does wonders for motivation.
  • wingnut4772
    edited June 2008
    Jstas wrote: »
    Well if he wants to get paid he will do it right. The problem is I don't think he's capable. I will find out how much my guy will charge to fix it and deduct it.
    Here is his updated attempt at 'fixing it'.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Jstas
    Jstas Posts: 14,977
    edited June 2008
    He just smeared more paint on!
    We Todd Did.
  • wingnut4772
    edited June 2008
    Jstas wrote: »
    We Todd Did.
    Exactly. I just called him and told him it was horrible and to use primer. So if he primes and repaints the whole wall it should be fixed then?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Jstas
    Jstas Posts: 14,977
    edited June 2008
    Like what was already said, those compounded spots gotta be sanded smooth and as level with the surrounding wall as possible. Then it's gotta get roughed up a bit so the paint will stick. Otherwise, the giant smooth spots are going to reflect the light differently and on a dark wall like that, they will stand out.
    Honestly if it was me, I wouldn't have used joint compound unless there was a hole in the wall. If it was just some missing paper, I would have oversprayed with a sandable primer, blocked it down and then done the whole wall in primer and then two color coats.
  • demaples
    demaples Posts: 266
    edited June 2008
    Wow, that is a horrible job. Not sure if he knows how to fix it from the looks of that.
  • wingnut4772
    edited June 2008
    Jstas wrote: »
    Well what are you waiting for? Get over here!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Jstas
    Jstas Posts: 14,977
    edited June 2008
    I should. It's probably cooler in Miami right now.
    My poor black truck is melting in the parking lot!
