Well...I just blew it...SVS sub driver gone Bye Bye
13»
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    GV#27 wrote: »
    My comment about moving the sub away from the corner was just to make the near field measurement of the sub with out the rooms influence.When measurement is done put the sub back in its corner.
    I understood GV. If it is the sub or if it is the room, there is not much i can do about it. I cant move the sub from its location, and i cant change the dynamics of the room. Modification to the enclosure is my only choice.
    But its really not as bad as I am making it out to be. The sub does perform very well in its sealed inhabitat.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ShinAce
    ShinAce Posts: 1,194
    edited June 2008
    You can try undertuning, something like 15-16 Hz. You can also try partially stuffing the ports to see if that helps the peak at all.
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    ShinAce wrote: »
    I am cutting the box down to ~5.5ft^3, leaving it sealed, stuffing it heavily and buying the BDF Eq.
    I think that will solve almost every problem
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    Systems Posts: 14,872
    edited June 2008
    Like you I have WAF to consider so I'm limited to corner placement for my subs.Likewise I have found that sealed designs perform better in this location with tighter more detailed bass than ported designs.With the inevitable boost at low frequencies due too room gain corner loading a ported design "may" get you too much of a good thing.
    Yeah with your BFD you should l be able to get excellent in room response,it is a great tool.
    Testing
    Testing
    Testing
  • goingganzo
    goingganzo Posts: 2,793
    edited June 2008
    i say go big or go home.
    go with two of these http://www.soundsplinter.com/rlp18_subwoofer_information.html
    or 4 if you want to have sothing like my setup
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    The Tempest is plenty big enough....(for now)...as soon as the BDF comes in , I can smoth'n the FR responce and see how things "play" out. I think with using the BDF, I can also cut down the ft^3 of the enlcosure. Being it is sealed. More power would be needed, but right now my amp is only being used at 25%, So the headroom is there.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
