Anthem Amp 1---blowing power fuse
george daniel
:mad:Left it on last nite,, this morning --no power,,blown fuse,, replace fuse,,,power on,,blows fuse,,, unhooked pre,,, power on,, blows fuse,,I'm thinking power supply? I checked the terminals,wires,etc. Nope,, no crossed terminal connections,,etc,, anyone have any trouble shooting hints/shortcuts,, as amp/power supplies are certainly not my expertise. Thanks in advance---george
Post edited by george daniel on
is it hooked up to your newly acquired Carvers? If so, try another set of speakers and see if it does it again,Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
negative,, it's connected to taylos monitorsis it hooked up to your newly acquired Carvers? If so, try another set of speakers and see if it does it again,JC approves....he told me so. (F-1 nut) -
FWIW,,one of the EL 34's was waaaaay out of bias range,,,replaced the fuse,,rebiased,,,AND improved the ventilation,,so far so good.:)JC approves....he told me so. (F-1 nut)
