Anthem Amp 1---blowing power fuse
george daniel
george daniel Posts: 12,096
edited April 2008 in Troubleshooting
:mad:Left it on last nite,, this morning --no power,,blown fuse,, replace fuse,,,power on,,blows fuse,,, unhooked pre,,, power on,, blows fuse,,I'm thinking power supply? I checked the terminals,wires,etc. Nope,, no crossed terminal connections,,etc,, anyone have any trouble shooting hints/shortcuts,, as amp/power supplies are certainly not my expertise. Thanks in advance---george
Post edited by george daniel on
  • hoosier21
    hoosier21 Posts: 4,420
    edited April 2008
    is it hooked up to your newly acquired Carvers? If so, try another set of speakers and see if it does it again,
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • george daniel
    edited April 2008
    hoosier21 wrote: »
    negative,, it's connected to taylos monitors
  • george daniel
    edited April 2008
    FWIW,,one of the EL 34's was waaaaay out of bias range,,,replaced the fuse,,rebiased,,,AND improved the ventilation,,so far so good.:)
