Tired of waiting for SVS to get my sub in stock...
13»
  • bykes
    bykes Posts: 132
    edited April 2008
    Well... I canceled my order. :(
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2008
    That's too bad. I agree SVS makes great subs, but I don't think I'd wait that much. Plenty of other options out there.
    SOPA
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2008
    Unfortunately, if your buying ID, most have a wait currently. You might be able to get a Valor by the end of the month or check local dealers for a used Velo SPL1200R. Also, if you can build a box the Rythmik Servo 12 kit is a stellar sub (in fact they might be offering a boxed version now too)... www.rythmikaudio.com
    edit: just checked they are not selling the finished units yet.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bykes
    bykes Posts: 132
    edited April 2008
    Thanks guys. Im most likely going to walk into the local tweeter and pick up a DSW for now. Maybe once the ID guys get over their supply issues Ill look back to them. I'm just tired of my incomplete setup.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2008
    Supply chain management is a pretty important issue when you are using JIT inventory mgt to drive a web direct business model. I don't blame you for being frustrated. I wouldn't of had that much patience.
    DKG999
  • danger boy
    danger boy Posts: 15,722
    edited April 2008
    how much longer were they tellling you you'd have to wait for your SVS sub?
    why such a big delay?
    PolkFest 2012, who's going>?
  • bykes
    bykes Posts: 132
    edited April 2008
    danger boy wrote: »
    They said they were expecting amps this week. But they told me that last week. So I'm done with SVS for now.
  • engtaz
    engtaz Posts: 7,669
    edited April 2008
    Get what you want, just don't settle on any sub. There are a lot of subs in this category.
    Good Luck,
    engtaz
    engtaz
  • bykes
    bykes Posts: 132
    edited April 2008
    Id love a velodyne SPL-1200R, but they are more than I'm willing to spend right now.
  • pearsall001
    pearsall001 Posts: 5,257
    edited April 2008
    bykes wrote: »
    I see you're located outside of Philly...where at exactly. I'm in Magnolia, NJ & you might want to check with Stephen at Quest for Sound in Bensalem. That's where I frequent (bought & sold a lot of gear there) & picked up my SPL-1200R. Stephen's a great guy to deal with & you'll really enjoy a visit to his place. What exactly is the budget you're working with? I just might have an SVS 25-31plus cylinder sub for sale shortly.
    http://www.questforsound.com/
  • bykes
    bykes Posts: 132
    edited April 2008
    Thanks, but I don't like the look of the cylinder subs.
  • danger boy
    edited April 2008
    get a used one till they have your SVS back in stock in a couple month's. that's better than going without one till then. although they don't come up for sale very often. look at Craigslist. that's where I got mine a couple years ago. Worked fine. but I decided to turbo power it by replacing the driver with a used SVS 12.2 driver..
    it's sweet.. total cost to me was like $225 for the Adire Audio subwoofer and a used SVS 12"
    it's big.. 22"x22"x22"
  • bykes
    bykes Posts: 132
    edited April 2008
    Well, I ended up picking up a Martin Loagan Abyss for now. Tweeter had them on clearance.
