H/K 347 and Adcom GFA 555...
Mauskar
For those that have this combination, I know that the speakers should be set to "LARGE", but what should the Subwoofer setting be placed at?
Also what is a good crossover frequency between the fronts and the subwoofer with this combination?
Post edited by Mauskar on
What speakers?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
RTi10's...
For music set your sub at 40-60
for HT go to 80Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yes, I'd set them to large. Setting the sub's xover will depend on how capable it is and how it sounds to you. I have my setup, large, LFE & mains, xover @ 60 and it seems to give me the flattest response.
Experiment...perhaps you'll get a better response setting the sub to LFE only or with a higher crossover. What you want to avoid is cancellation in the bottom frequencies between the sub and mains. The only way you can tell is by running tones or sweeps and graphing it out (along with what sounds best to you).
Good luck with the new amp. I really enjoyed my time with Fred's Adcom.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Yea im enjoying this amp alot. Problem is i have exams coming up!!! Such temptation!!!
Good point Ron. Play with speaker placement a bit. Even a few inches when corner loaded can make a big difference.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
yea i will. my receiver has an issue that harman support is already aware of. Just wanted to see if the amp bypassed that issue, which was a volume fading in and out, which the amp does.
Ben, your in FT. Lauderdale? Im in Miramar. Hi neighbor!
Sag -
Sag
Hey neighbor. We should hook up before I move! Do a little cable swapping. I am in Oakland Park for the moment:eek:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Sounds kewl, possibly after exams!
