H/K 347 and Adcom GFA 555...
Mauskar
Mauskar Posts: 104
edited March 2008 in Electronics
For those that have this combination, I know that the speakers should be set to "LARGE", but what should the Subwoofer setting be placed at?
Also what is a good crossover frequency between the fronts and the subwoofer with this combination?
Post edited by Mauskar on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    What speakers?
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited March 2008
  • ben62670
    edited March 2008
    For music set your sub at 40-60
    for HT go to 80
    Ben
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2008
    Yes, I'd set them to large. Setting the sub's xover will depend on how capable it is and how it sounds to you. I have my setup, large, LFE & mains, xover @ 60 and it seems to give me the flattest response.
    Experiment...perhaps you'll get a better response setting the sub to LFE only or with a higher crossover. What you want to avoid is cancellation in the bottom frequencies between the sub and mains. The only way you can tell is by running tones or sweeps and graphing it out (along with what sounds best to you).
    Good luck with the new amp. I really enjoyed my time with Fred's Adcom.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Mauskar
    Mauskar Posts: 104
    edited March 2008
    Yea im enjoying this amp alot. Problem is i have exams coming up!!! Such temptation!!!
  • ben62670
    edited March 2008
    Good point Ron. Play with speaker placement a bit. Even a few inches when corner loaded can make a big difference.
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited March 2008
    yea i will. my receiver has an issue that harman support is already aware of. Just wanted to see if the amp bypassed that issue, which was a volume fading in and out, which the amp does.
    Ben, your in FT. Lauderdale? Im in Miramar. Hi neighbor!
    Sag
  • ben62670
    edited March 2008
    Mauskar wrote: »
    Sag
    Hey neighbor. We should hook up before I move! Do a little cable swapping. I am in Oakland Park for the moment:eek:
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited March 2008
    Sounds kewl, possibly after exams!
