Rm7200 Mounts
  • wallstreet
    wallstreet Posts: 1,405
    edited March 2003
    I think that's about the best you can do without ripping out the fireplace.
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    RMs are small, i still think you could put one on the mantle and maintain a high WAF
  • JoeCane
    JoeCane Posts: 11
    edited March 2003
    wallstreet: which one do you thinks is best?
    rs159: Isn't on mantle still too high? That is why I though of stands.
    TonyPTX: When you had your RM's up on the the ceiling like that were they the fronts or surrounds? How did it sound? OK?
  • mantis
    mantis Posts: 17,487
    edited March 2003
    Joe,
    your placement for that corner I still believe is from the ceiling.you can get a more open soundstage with the right angles.
    You know Inceiling speakers with adjustable tweeters would yield the cleanest Install.Believe it or not,they sound fantastic.
    Yes I am a Audio and Video Installer.Expert(Pro around here as been called)if you will.
    Dan
  • TonyPTX
    TonyPTX Posts: 545
    edited March 2003
    It was both. I had the fronts in the corner and the surrounds in the corner. It wasn't optimized but it "had to do" considering the placement of my equipment in the room. Honestly it didn't sound all that bad (speakers were about 10 ft from the listening spot) for satellite speakers (which is why I upgraded to some towers a month later while I still could).
    Damn....8 lines...I've gotta put my sig on a diet now....
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    Originally posted by mantis
    ...You know Inceiling speakers with adjustable tweeters would yield the cleanest Install.Believe it or not,they sound fantastic...
    How do they blend with standard centers? I havn't really demoed many in ceiling systems.
  • wallstreet
    edited March 2003
    if you want something slick, kef has some speakers that drop down from the ceiling when a signal is present.
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    If you can put the center where it is in the pic here then putting the right main on the mantle would be perfect. That's the reason I wanted a pic with the tv stand *open* - so I knew how and where the center went.
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    Ok then... here's the pic
