Sda/srs
dustradio
Speakers Seem To Be Lacking In The Sda Area Please Assist.
Post edited by dustradio on
..and yet you still want top dollar for them?
Somebody help this guy. He's been very nice._________________________________________________
We'll get right on that. I loooooooove helping people who insult at every corner and simply come here to hock their goods. Hold on Dusty help is on the way...:rolleyes:"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Is the cable plugged in?? What distance apart do you have them? The sda sound effect is not as loud as the stereo. Are any of the drivers frozen or scratchy sounding?
engtazengtaz
YES THEY ARE PLACED AS RECOMMENDED, CABLE PLUGED IN, DRIVERS SEEM TO SOUND FINE. MIGHT BE MY ROOM OR MY EARS AS WE GET OLDER. JUST SEEMS LIKE THEY HAD MORE EXTENSION WHEN NEW. THOUGHT THIS WAS A DIRECT THREAD TO POLK TECHNICIANS (ie those nasty comments)
BDT
THEY ARE NOT FOR SALE, IN FACT I SOLD THEM TO ME! -
I Was Thinking It May Be the Old Caps In The Cross Overs, Reasearch Shows The Sonic Caps Seem Be A Great Replacement. My Problem Is That I Would Not Stop There I Would Go With Thier Recommended Solder, Silver Wire And Rewire The Entire Speaker Getting Rid Of Those Old Crimps, Big Job, I Wonder If It Is Worth It to hard wire the speaker?
Shouldn't be a big job for a EE with a PhD! Let us know how it works out.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
well i a kind of a perfectionist so it will be a big job! not a tech but do HAVE nasa high reliability solder skills. biggest thing is the time coherance between slight differances in wire length with a higher velocity rating.
i like the ignore feature on this forum.
PolkFest 2012, who's going>?
Yes ... We can tell ...... well i a kind of a perfectionist ...
Seems like you have cloudy bits in your input / output overlays ... -
Let's try to help Max out and maybe he'll have more appreciation for his SDA's and have time to work on his communication skills!DKG999
You have got to be kidding me.......
The first rule of Fight Club is you don't talk about Fight Club -
Well it might happen!DKG999
I'm sure you will be able to hear the time coherance [sic] differances [sic] between 6" of 16g wire and 12" of 16g wire. :rolleyes:"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
well with 12 drivers a side i am sure the wire measurments had a tolerance, but silver wire is differant. the signal is much faster and i dont know if mathew and his design team calculated this. thats why i am here, its suppossed to be a direct link to technical support. thanks for those supporting me in this thread.
Well, at least he's humble...;) -
Are these the one's you are selling?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Are you hearing anything out of the SDA drivers? Are you 2 channel listening or HT? Redoing the crossovers is alway a great benefit. I am not jumping into the cabling arguments. Changing out the caps and resistors is a good idea and using silver solder and installing new binding post helps.
engtazengtaz
yes sda drivers are working fine although i wish they were louder. 2 channel stereo only. what benfit did you see from redoing the crossovers? new binding posts are a great idea. thank you for that tip!
Have you ever actually looked inside the speakers ? Have you noticed that they use clip on speaker connections that barely connect well when NEW...much less 20 years down the road.
Before you start talking about calculating speaker wire measurements ...silver wire...etc....go in and clean up the connections you already have and use a pair of needle nosed pliers to tighten them all up before clipping them back onto the speakers....you will gain more from that ( Maybe even fix your poorly imaging SDA's ...it's VERY possible you are having drivers dropping out of the mix from poor/oxidized/loose connections ) then reinventing the wheel.The first rule of Fight Club is you don't talk about Fight Club -
mmmmmmmmmmmm............ good tip
I Was Thinking It May Be the Old Caps In The Cross Overs, Reasearch Shows The Sonic Caps Seem Be A Great Replacement. My Problem Is That I Would Not Stop There I Woul Go With Thier Recommended Solder Silver Wire And Rewire The Entire Speaker Getting Rid Of Those Old Crimps, Big Job, I Wonder If It Is Worth It?
The crossover upgrades have a solid Polkie following and some great posts of the user comments, pictures and reviews, are found with the search function on the website. I wouldn't waste your time on rewiring the speakers and put more effort into the x-over rebuild.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
so you dont think getting rid of all those crimp connection with a solid silver wire would benifit? thanks for your support
The signal is weak, please adjust your tin foil.Political Correctness'.........defined
President of Club Polk -
Nope.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Had to quote this. Ladies and Gentlemen, Dorokusai is recommending an SDA crossover rebuild. :eek::p_________________________________________________
Keep in mind, I wouldn't do it unless I was extremely bored. I think that enough members have found positive results with the upgrade to validate it being worth some thought. If you want to hot rod your SDA's, by all means, knock yourself out.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I know. I've done it twice already, and it's definitely worth it._________________________________________________
sounds fun! perhaps i will hot rod them. what gains did you see ricardo?
