Sda/srs
dustradio
dustradio Posts: 78
edited February 2008 in Troubleshooting
Speakers Seem To Be Lacking In The Sda Area Please Assist.
Post edited by dustradio on
«13
  • TroyD
    TroyD Posts: 13,124
    ..and yet you still want top dollar for them?
    BDT
  • Ricardo
    Ricardo Posts: 10,634
    Somebody help this guy. He's been very nice.
    SOPA
    heiney9 Posts: 25,497
    Ricardo wrote: »
    We'll get right on that. I loooooooove helping people who insult at every corner and simply come here to hock their goods. Hold on Dusty help is on the way...:rolleyes:
  • engtaz
    engtaz Posts: 7,669
    Is the cable plugged in?? What distance apart do you have them? The sda sound effect is not as loud as the stereo. Are any of the drivers frozen or scratchy sounding?
    engtaz
    engtaz
  • dustradio
    dustradio Posts: 78
    YES THEY ARE PLACED AS RECOMMENDED, CABLE PLUGED IN, DRIVERS SEEM TO SOUND FINE. MIGHT BE MY ROOM OR MY EARS AS WE GET OLDER. JUST SEEMS LIKE THEY HAD MORE EXTENSION WHEN NEW. THOUGHT THIS WAS A DIRECT THREAD TO POLK TECHNICIANS (ie those nasty comments)
  • dustradio
    dustradio Posts: 78
    TroyD wrote: »
    BDT
    THEY ARE NOT FOR SALE, IN FACT I SOLD THEM TO ME!
  • dustradio
    dustradio Posts: 78
    I Was Thinking It May Be the Old Caps In The Cross Overs, Reasearch Shows The Sonic Caps Seem Be A Great Replacement. My Problem Is That I Would Not Stop There I Would Go With Thier Recommended Solder, Silver Wire And Rewire The Entire Speaker Getting Rid Of Those Old Crimps, Big Job, I Wonder If It Is Worth It to hard wire the speaker?
  • dkg999
    dkg999 Posts: 5,647
    Shouldn't be a big job for a EE with a PhD! Let us know how it works out.
    DKG999
  • dustradio
    dustradio Posts: 78
    well i a kind of a perfectionist so it will be a big job! not a tech but do HAVE nasa high reliability solder skills. biggest thing is the time coherance between slight differances in wire length with a higher velocity rating.
  • danger boy
    danger boy Posts: 15,722
    i like the ignore feature on this forum. :)
    PolkFest 2012, who's going>?
  • PolkWannabie
    PolkWannabie Posts: 2,763
    dustradio wrote: »
    ... well i a kind of a perfectionist ...
    Yes ... We can tell ...
    Seems like you have cloudy bits in your input / output overlays ...
  • dkg999
    dkg999 Posts: 5,647
    Let's try to help Max out and maybe he'll have more appreciation for his SDA's and have time to work on his communication skills!
    DKG999
  • shadowofnight
    shadowofnight Posts: 2,735
    You have got to be kidding me.......
    The first rule of Fight Club is you don't talk about Fight Club
  • dkg999
    dkg999 Posts: 5,647
    Well it might happen!
    DKG999
    dustradio wrote: »
    I'm sure you will be able to hear the time coherance [sic] differances [sic] between 6" of 16g wire and 12" of 16g wire. :rolleyes:
  • dustradio
    dustradio Posts: 78
    well with 12 drivers a side i am sure the wire measurments had a tolerance, but silver wire is differant. the signal is much faster and i dont know if mathew and his design team calculated this. thats why i am here, its suppossed to be a direct link to technical support. thanks for those supporting me in this thread.
  • zingo
    zingo Posts: 11,258
    dustradio wrote: »
    Well, at least he's humble...;)
    treitz3 Posts: 20,119
    Are these the one's you are selling?
  • engtaz
    engtaz Posts: 7,669
    Are you hearing anything out of the SDA drivers? Are you 2 channel listening or HT? Redoing the crossovers is alway a great benefit. I am not jumping into the cabling arguments. Changing out the caps and resistors is a good idea and using silver solder and installing new binding post helps.
    engtaz
    engtaz
  • dustradio
    dustradio Posts: 78
    yes sda drivers are working fine although i wish they were louder. 2 channel stereo only. what benfit did you see from redoing the crossovers? new binding posts are a great idea. thank you for that tip!
  • shadowofnight
    dustradio wrote: »
    Have you ever actually looked inside the speakers ? Have you noticed that they use clip on speaker connections that barely connect well when NEW...much less 20 years down the road.
    Before you start talking about calculating speaker wire measurements ...silver wire...etc....go in and clean up the connections you already have and use a pair of needle nosed pliers to tighten them all up before clipping them back onto the speakers....you will gain more from that ( Maybe even fix your poorly imaging SDA's ...it's VERY possible you are having drivers dropping out of the mix from poor/oxidized/loose connections ) then reinventing the wheel.
  • dustradio
    dustradio Posts: 78
    mmmmmmmmmmmm............ good tip
  • dorokusai
    dorokusai Posts: 25,576
    dustradio wrote: »
    I Was Thinking It May Be the Old Caps In The Cross Overs, Reasearch Shows The Sonic Caps Seem Be A Great Replacement. My Problem Is That I Would Not Stop There I Woul Go With Thier Recommended Solder Silver Wire And Rewire The Entire Speaker Getting Rid Of Those Old Crimps, Big Job, I Wonder If It Is Worth It?
    The crossover upgrades have a solid Polkie following and some great posts of the user comments, pictures and reviews, are found with the search function on the website. I wouldn't waste your time on rewiring the speakers and put more effort into the x-over rebuild.
  • dustradio
    dustradio Posts: 78
    so you dont think getting rid of all those crimp connection with a solid silver wire would benifit? thanks for your support
    F1nut Posts: 52,000
    The signal is weak, please adjust your tin foil.
  • dorokusai
    dustradio wrote: »
    Nope.
  • Ricardo
    dorokusai wrote: »
    Had to quote this. Ladies and Gentlemen, Dorokusai is recommending an SDA crossover rebuild. :eek::p
    SOPA
  • dorokusai
    Keep in mind, I wouldn't do it unless I was extremely bored. I think that enough members have found positive results with the upgrade to validate it being worth some thought. If you want to hot rod your SDA's, by all means, knock yourself out.
  • Ricardo
    I know. I've done it twice already, and it's definitely worth it.
    SOPA
  • dustradio
    dustradio Posts: 78
    sounds fun! perhaps i will hot rod them. what gains did you see ricardo?
