Speaker Wire - Newbie needs advice
sross17
sross17 Posts: 14
Hi guys,
I'm still a newbie and have received some pretty useful tips here before...need some more help if I may ask?
I just completed my speaker setup and am still using very old "cheap" speaker wire. I keep seeing that Blue Jeans has good speaker wire? I am planning to re-wire my HT system and want good enough speaker wire that I'm not "depleating" my system of it's potential. Here's what I have...
Yamaha HTR5940 Receiver
Denon 1930Ci DVD/SACD/DVDA
RT800 Front Mains (Bi-Wired currently)
Csi3 Center
DSW500 Sub
FXi A6 surround
My surround speakers are about 25 feet away from my receiver at the back of my family room. The fronts are only about 5 feet to each side of my receiver. In all, I will need close to 100 feet of speaker wire (wiring through walls).
Any suggestions of the kind of speaker wire I should use would be very helpful. Would like to keep it under $150.00 if possible.
Thanks guys!
Post edited by sross17 on
  • phuz
    phuz Posts: 2,372
    edited January 2008
  • sross17
    sross17 Posts: 14
    edited January 2008
    Thanks for the advice regarding signal cable. I have looked at what they have to offer and if I get their ultra speaker wire...I'm looking at about $140.00 just to wire my fronts. I still have 25 feet per speaker of wire needed for my rear surround speakers. I would love to afford these speaker wires, but unfortunately out of my budget. Should I be looking at their entry level wires?
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2008
    If you're on a budget, go bluejeans. Most manufactures use the same Belden wire that BJC sells for a lot less. May not look as pretty, but your wallet will.
  • marvda1
    marvda1 Posts: 4,945
    edited January 2008
    Puritan PSM156
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2008
    marvda1 wrote: »
    Why on earth would you want the positive lead to be twice the guage of the negative lead?
  • MikeC78
    edited January 2008
    WilliamM2 wrote: »
    :DGood question!
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    WilliamM2 wrote: »
    Some people cant stand to see wire there and unused.
    But honestly, it should be the other way around, for a better ground.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • WilliamM2
    edited January 2008
    jakelm wrote: »
    Since the signal is AC, I would think it would be best to have them the same gauge. Poor design in my opinion.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    WilliamM2 wrote: »
    Then just clip the green wire.....no the red....no the blue...cut it..cut it....:confused::confused:
    explodes into a million peices....:mad::eek:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • mojo_13
    mojo_13 Posts: 22
    edited January 2008
    I bought all my wire from monoprice.com and was very satisfied with it and at a great price. But I also agree if you can afford it bluejeans is the way to go.
  • marvda1
    edited January 2008
    that's why it's called diy, you have questions about how they do it all you have to do is try the way you think would sound the best, compare and use the best sounding method.
    Puritan PSM156
  • WilliamM2
    edited January 2008
    marvda1 wrote: »
    I'll just do it the way I always have. 12ga or 14ga speaker wire, put bananas on end, done.
    No point putting a fancy name on a poor design, and pretending it's something special.
  • marvda1
    edited January 2008
    why do you say it's a poor design? i'm sure the guy tried it more than one way and found his way to sound the best. the home depot orange extention cord diy speaker cable also has three wires and people configure it in different ways.
    and back to your "poor design", tara labs had a well regarded speaker ( the one with the tfa return) which consisted of a single cable for each positive and negative post and the + and - wires were different gauges. now did tara labs have a "poor design) ?
    Puritan PSM156
  • marvda1
    edited January 2008
    sorry sross17 for getting the thread off topic. let's get back on topic.
    if someone thinks it important enough, start a new thread on the topic.
    Puritan PSM156
  • WilliamM2
    edited January 2008
    marvda1 wrote: »
    The signal going to your speakers is AC, that means current flows both directions. Why would more resistance on one wire be considered a good design? If the lengths are short enough, I doubt it would matter much. But on longer lengths, I would never use 16ga, which is all that wire is on the negative side.
    I'm sure he tried it both ways, and then imagined his way sounded better.
    The real question is why go to all the bother? Buy real speaker wire and be done with it.
  • cambir
    cambir Posts: 1,046
    edited January 2008
    sross17 - go with the bluejeans...you won't be dissappointed. I just wired speakers in a zone 2 (60-70 feet from source) with their "12-white" wire and it sounds great.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
  • vonnie123
    vonnie123 Posts: 326
    edited January 2008
    Monster Z2 is nicely priced at 1.29 per foot/retail is $5 per foot. Just bought some myself and made a couple of cables with GLS Audio terminations.
    accessories4less.com
    good service/prompt shipping.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    WilliamM2 wrote: »
    Protons are bigger than electrons!:D
    F1nut Posts: 51,767
    edited January 2008
    Waaaaaaaaaaaaaaaaaaaaaa
  • sross17
    sross17 Posts: 14
    edited January 2008
    Thanks to all for your help. I was leaning toward the Blue Jeans cable...seemed right for my budget. I just purchased 100 feet and should have it by Friday.
    I must admit this hobby is worse than a drug (I'm hooked) :o - I couldn't help myself and just picked up a Panamax M5100 Power Conditioner as an added toy along with a few new CD's.
    Nickleback
    Nine Inch Nails - Downward Spiral (Hybrid SACD)
    Velvet Revolver
    Absolutely rocked out last night and pissed off my neighbor. Oops
    Thanks again!!
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    It'll only get worse...............
  • vonnie123
    edited January 2008
    Better, but more expensive!
  • mmadden28
    mmadden28 Posts: 4,283
    edited March 2008
    WilliamM2 wrote: »
    So what is the general consensus on what a 'longer length' is, with respect to when a certain guage wire should (or should not ) be used? Over 20'? 10? 50?
    ____________________
    Pool: Atrium 60's/45's
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    mmadden28 wrote: »
    The longer the length the higher the Ga needs to be to overcome resistance. Here is the bad part. Capacitance also increases. You lose some highs, and some detail. I have run 14 ga in wire lengths up to 35'. Not really a problem. Some would suggest 12ga. The rear sound tracks are usually capped off at upper levels knowing the limitations of long runs in movie theaters never mind home systems. Now SACD's like Dark Side of the Moon have extended highs all around. I still had no issues with the 14ga runs for the rears. I have tried a bunch of different cheap speaker wire, and have found the best bang for the buck for surrounds is the WalMart speaker cable in the automotive section. Not the A/V section. Save your money for the short runs in the front where it matters most. Try to match the center speakers cable to the mains. If you are using a receiver for amplification you are not going to see big differences with speaker cables. That being said I still recommend a decent set of cables for the front.
    Ben
    Ben
  • John K.
    John K. Posts: 822
    edited March 2008
    MM, there's no need to seek a "consensus" on the point of appropriate gauge for various lengths of run. This explanation of speaker wiring by a veteran audio professional is frequently cited and the table of suggested gauges can be used with confidence.
  • strang22
    strang22 Posts: 32
    edited March 2008
  • tinman67gz
    tinman67gz Posts: 15
    edited March 2008
    Of all the advice I saw here no one mentioned that you will need special cable for you in wall application. It will be sheilded to keep from picking up distortion from other electrical sources. Oh yeah, it's a code issue too.
  • WilliamM2
    edited March 2008
    tinman67gz wrote: »
    In wall cable is not shielded. It just has an outer jacket that is fire rated, and does not emit noxious fumes when burned.
  • ben62670
    edited March 2008
    WilliamM2 wrote: »
    Having been an electrician I fully agree. Kinda like Plenum rated cat5 cable.
    Ben
