Suggestions for good cheap 12AWG or better speaker wires?
It's not worth my time. This has been beat to death thousands of times over for years in other forums, I'm not going to waste my time trying to convince anybody.
Try using the search feature of Google.
TRY using what God gave you. .. . there is one on each side of your head. -
The popcorn is starting to smell good,, its almost done in the microwave.. damn...cant find my pillow..
That's about the best post of the last few in the thread
Mike Kozak wrote: »I bought these from an audio store where I live, expensive, but they do my Paradigm Mini Monitors justice. http://www.crutchfield.com/S-lgBijUTTQKs/App/Product/Item/Main.aspx?i=119U1K1010
Please get in touch with ben62670 before buying these. He might be able to make you some.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I have Monoprice, Monster, BJC, SignalCable, Goertz, and Ben's interconnects here. The only I/C use I use in my 2ch rig are Ben's, they have the best detail and bass of the bunch. As for my HT rig, it's mostly Signal, with a Goertz and BJC here and there. I've tried all of them in various parts of my rig and can tell you, you don't know what you're missing unless you try different cables. Monoprice cables are good if you like the sound of bed sheets thrown over your speakers, and Monster isn't a whole lot better.
As F1 said on another board, cables are a integral part of your rig. Think of them as a component just like anything else. Changing pre-amps or amps can change the sound of your rig, so why can't cables?
Some cables will sound alike, some will sound completely different, it's a matter of finding what works well with your system. If you're happy with your Monoprice cables, you're really missing out. And if you try something better(not monster), and not notice a difference, maybe the rest of your rig isn't up to snuff. `"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Ok, this is something i have to ask...
Unless one has an unlimited amount of cash or his own store, how can you test a bunch of different cables/speakers combinations? At which point do you say...hey, it's not the cables, it's my crappy speakers?
Are you saying SOME wires are better (regardless of which speakers you have)? If so, which ones are they?
I'm not trying to start an argument here, but i have read alot of forums the last few weeks to see which wires to buy and where. And i am getting alot of MONOPRICE suggestions.
Is it really worth the extra money to get better wires for Rti8, Rti4, CsiA6? ...or is monoprice fine?Rti8
CsiA6
Rti4
PSW505
Yamaha 6050 -
With my rti8s I like my AQ indigo cables the best. This after trying Monster, AR, Kimber4pr and AQ type 2. Don't be affraid to buy your cables used. That's what I did...for the most part. I have lying around an extra type 2 you could try for free. PM me.
That's nice of you Willow. Great suggestion on buying them used. They're already broken in, and if you don't like them, you shouldn't take much of a hit when you sell them."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Now I'll clarify that it's only 1 cable about 4ft long. But at least you can compare it to what you have.
PM sent! 4 feet doesn't matter for testing purposes...as long as i can hook it up to one of my Rti8.
Say i hookup both my fronts (at the same time) and use one with the AQ type 2 and the other with the cable i have on loan right now, would that harm anything?Rti8
CsiA6
Rti4
PSW505
Yamaha 6050 -
Won't harm a thing, but it will be a complete waste of time testing. Since the speakers are in different locations, they will have different room response and sound different regardless of cables.
Also, I assume your source is stereo, which means you will also have different signals going to each speaker, which will also sound different regardless of cables. Of course you may be able to switch to a mono setting, but then how would you hear the imaging, depth, and other magical qualities claimed of the cables. -
but it will be a complete waste of time testing. .
Why dont you let him decide instead of speaking for him....
No it won't harm anything. To be fair just be sure both 8s are the same distance from the receiver sit back and see if you can tell a difference. -
Who was speaking for him? Nice quote out of context. I quite clearly explained why testing with a different wire on each speakers is pointless. If you can't see why that is true, that's your problem. -
So test on the left, then test on the right.
Push your left cable in ,
pull your left cable out,
push your left cable in
and you shake it all about,
you do the cable pokey
and you turn yourself around,
thats what its all about....Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
A polkologist doing the pokey....Rti8
CsiA6
Rti4
PSW505
Yamaha 6050 -
Really? I can't find any documents right now, but it seems like I've read before that no one has ever put together a double blind test where listeners could figure out if they were listening to high priced speaker wire or a cheap electrical cord.
Or even more precisely, tests have been done where no one could pick out which was high priced "speaker cable" versus plain old stranded copper wires.
I have never heard anything with my eyes. Use your **** ears with a nice pair of cables, and your electrical cord. If you are doing this experiment with a **** system you may not hear any difference at all. Also if you take your head out of your **** you can hear much much better. This is coming from a guy who believed that cables did not make a difference. I thought these guys with their fancy cables spent too much time pickling their fingers in martini's showing off their fancy cables. I actually picked on them.
Thanks to a fellow Polkie bring over some cables, and me buying a used pair of IC's on Ebay I have seen the light, and my system sounds much better do to it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
... Use your **** ears ... take your head out of your **** you can hear much much better ...
Wow, you're a dick. -
take a look at this.
http://www.6moons.com/audioreviews/whitelightning/moonshine.htmlAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Wow, you're a dick.
Only sometimes:D
I was also picking on myself with those statements, because I once believed as you:;):pPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Only sometimes:D
Well I must say, I didn't say anything about IC cables in my messages. I know there are some really crappy IC cables out there - and if memory serves there is something about the low level signal going over an IC and impedance that can produce an rather noticeable difference between a well made IC and a crappy one.
I'm thinking IC as in the cable between the CD player and the pre-amp, the pre-amp and the amp, the turntable and the pre-amp, etc. -
I too was like ben cept the dick part;) it was not until I hooked up my diamondbacks that I noticed what good cables can do.
Yes
I think that good IC's are more important than speakers cables. When you have a good amplified signal then good speaker cables can really make a nice system shine. Thats why I mentioned the IC's. Sound always starts from a source. If the source sucks (like an 80's tape deck) then nothing after it is going to make it sound good. So then speaker cables would make no difference at all.
Ben -
Yes
Ben
Hmm, my late 80's Nakamichi tape deck sounds pretty darn good
Nakamichi does make some pretty awsome stuff. I have a sub amp for my car. It is only rated at 220 watts. It hits hard, and is nice and quiet.
About where do you live? Maybe a fellow Polkie could invite you over for some comparisons. Not all of us are Dicks:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Asheville, NC
Asheville, NC
Well hopefully someone from that area will see ya, and you can have a get together.
Ben -
I can't believe this thread is still kicking.
