my setup
1356711
    edited January 2008
    Beautiful, just beautiful!
    edited January 2008
    A tape measure and level -- the true test of an audiophile.
    "God grooves with tubes."
    edited January 2008
    In my experience with toe in, the R speaker should laser beam right past about an inch or two from your R ear, the same goes for the L speaker. That's just me.
    Looks like this would be a better sounding setup. Let your ears decide. If you can't place the sub where McLoki suggested, the setup that you have should do you justice until you can. Again, let your ears decide. It's your rig.
    edited January 2008
    Golden, nice indeed.
    edited January 2008
    Very nice.
    edited January 2008
    McLoki wrote: »
    For toe in - the inside edge of the speaker should be pointed at your ear on that side. (well start with that anyway and tweak from there....)
    I though the sub was ok where it was at, but to be honest, your best bet is to put some wood on your couch, set the sub on it (basically so the sub is firing into the wood rather than into the couch cushion), play some bass heavy music and crawl around on the floor till you find a place that the bass sounds good. Then switch positions wth the sub. Sounds really stupid, but it works pretty well.
    Michael
    sounds like a very good way to find the right spot for the sub! will get long interconnects and try it out!
    thx!
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
    edited January 2008
    cfrizz wrote: »
    :p
    thx!
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Early B. wrote: »
    :D
    the cement slab is not level! :(
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    treitz3 wrote: »
    it should be up and running this evening :):):)
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Sherardp/Face: thx!
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    system is running in 2 channel mode, i like it!
    the soundstage of the LSi15 is amazing (after tweeking it from 10pm to 8am!) :)
    the dswpro600 sub go deep
    need some ZzzZZzzzzz
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Very welcome, nice setup. After you listen to everything you can try tweaking it with a radioshack SPL meter later on.
    edited January 2008
    Keiko wrote: »
    Plenty of time for sleep when you're dead. Turn it up! Wake the dead! And an absolutely beautiful system slowcar. Njoy :)
    lol...
    thank you
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Sherardp wrote: »
    what is the SPL meter used for?
    btw i love the D-Sonic amp! had the sound cranked up to ear bleeding levels and they dont even warm up much :eek:
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Sound Pressure Level meter is used to measure a speakers output at a certain distance in decibels. or, it measures how loud your s*** is dude! cheers!:p
    My Rig
    Sony TAE 9000ES Preamp
    Sony TAN 9000ES Amp
    1 pr Polk RTA-15TL (mains)
    1 Polk CS-1000P (center)
    1 pr Klipsch WS-24 (rears)
    Velodyne FSX-12 (sub)
    Kimber ICs
    69" Widescreen Sony VPL-VW60 projection system
    edited January 2008
    Nice setup! I'm thinging of having the rears setup like your number 6 and 7. My rears will be 7 feet off the ground and 5 1/2 feet of seperation. Now thinking of LSi-7's to match the LSi-15's up front.
    edited January 2008
    The spl meter is used to calibrate all of your speakers for level output. So you would have them all set at reference level for a nice even sound.
    edited January 2008
    Dave38 wrote: »
    i have mine 6' off the ground and 7.5' apart...
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    cfrizz wrote: »
    i calibrated the system with the auto-setup using the supplied mic
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    nice setup. I always use that scene from HOUSE OF FLYING DAGGERS to demo my HT rig to guests :) The uncompressed PCM soundtrack is incredible
    edited January 2008
    The Double Yammies are very nice. So how about a little review. Hows that D-Sonic treating those LSis. Again your setup is very top notch indeed. Well planned out for sure.
    edited January 2008
    my freaking yamaha dvd-s2700 chewed up every disc i put in there! its history now...here is the damage...16 dvds and 23 cds. here is the worst 2
    Sony PS3 replaced the pos
    the soundstage/imaging is spectacular. i think the cause was the scratch/friction caused the spindle speed to become unstable and the data stream fed to the DAC was erratic on the yamaha...and still soundstage was great
    with the PS3...the imaging has pin point accuracy, so much more detail i did not hear on the yamaha.
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    you can resurface those cd's and dvd's with a bit of elbow grease. I usually start with 1000 grit wet sandpaper then step up to 2500. Next a cut polish followed by foam pad polishing glaze. Finally... wax. Yup, just like the clear coat on a car. Works wonderfully, especially on expensive video game discs.
    edited January 2008
    BeRad wrote: »
    i'm very dissapointed w/ the yamaha player :(
    at least there is hope to save all the damaged disc. i'll try it out.
    Thx!
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    If you have any questions, drop me a pm.
    edited January 2008
    BeRad wrote: »
    thx!
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    tried out some backlighting...8w flicker free tube
    turns out pretty good.
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    added a better surge protector and UPS
    my 7.(1x4) HT setup
    Buttkicker
    edited January 2008
    Very, Very nice. In all honesty, did you notice any difference with the better surge and adding the ups? (still deciding what to add to my system)
    Michael
Welcome!
Welcome!
