what about Car Sound Deadners?
Kinetic
Kinetic Posts: 437
edited December 2007 in Car Subwoofer Talk
i have dynamat becouse its easy to find it here in mexico, but its too expensive, so i was looking for some options on ebay and i found some real bargains, but are these good options?
i found this..
http://cgi.ebay.com/100-FatMat-Xtreme-Car-Sound-Deadener-Dynamat-Roller_W0QQitemZ110199463022QQihZ001QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq Feet for $130
This
http://cgi.ebay.com/100-sq-ft-EXTREME-deadener-w-Dynamat-roller_W0QQitemZ200174694812QQihZ010QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq feet for $135
and this
http://cgi.ebay.com/100-Ft-80-Mil-Rattle-Trap-Deadener-Dynamat-Roller_W0QQitemZ110199455592QQihZ001QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq feet for $210
also i heard here about "second skin" but i couldnt find it on ebay..
whats the best for the money?
i have the impression that all of those are the same..
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Post edited by Kinetic on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited November 2007
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • MacLeod
    MacLeod Posts: 14,358
    Dynamat Extreme is the best stuff but like you said, its kinda pricey.
    Raammatt is my second choice. Very close to the Dynamat in performance but an **** ton cheaper.
    http://raamaudio.com/cgi-bin/index.cgi
  • Greg Peters
    Greg Peters Posts: 605
    http://www.secondskinaudio.com/
    I used to use Dynamat Xtreme, but have since gone with Second Skin's Damplifier Pro...seems to be better quality at a lower price. Both are top notch quality-wise- I have both Xtreme and Damp Pro in my current car.
    Second Skin does sell direct (unless they have an arrangement with their dealer network like in Canada not to), and is well worth looking into.
    http://www.sounddeadenershowdown.com/ Some good reading.
  • Kinetic
    Kinetic Posts: 437
    this defenitly gives me another perspective.
    i have a lot to read and learn, but thanks for giving me the right direction.
    i love this forum
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    Z
    Polk Audio SR 6500
    G35
  • MacLeod
    Thats a pretty good deal. That is about $150 off retail, and Amazon.com aint no Ebay type dealer so it should be on the up and up.
  • Installer4life
    Installer4life Posts: 256
    Dynamat is one of the best and I recommend it highly. One web site that offers low price alternatives is EDESIGNAUDIO.com. Give them a look. They have some for around $1.00 per square foot. I have used it but its Dynamat for me from here on out.
  • Chwnn255
    Chwnn255 Posts: 24
    Anybody ever use FatMat? I got just 50 sq ft roll off ebay for $39.00.
    http://www.fatmat.com/
    If it's not as good as the Xtreme or SecondSkin than I'll just give it to my installer for some labor trade off and go with Dynamat Xtreme.
    Questions:
    1. Is the DynaXorb or SecondSkin's speaker backwave product worth the money? Why not just do a layer or two of Xtreme?
    2. How many Sq Ft would you all estimate I would need for an '03 Yukon XL... 4 doors? Do I need to do anything else? All my sound is up front even the sub (in the console...Stealthbox)
    3. Any tricks of the trade for a Noob?
    Quote: "When faced with dating/marrying looks or money... go for the money!" Money defienitely won't buy you happiness but it'll let you take care of your troubles in style. :)
  • MacLeod
    The Dynaxorbs aint a bad idea and do work in theory and I do use them but they are damn expensive. Not really worth the money if you ask me.
  • GLN305
    GLN305 Posts: 96
    I just got done today deadening my doors with Second SKin Damplifier Pro and it is easy to work with and made my doors sound really solid. I normally use asphalt based deadeners, but I think I'm hooked on Second SKin stuff now.
