what about Car Sound Deadners?
Kinetic
i have dynamat becouse its easy to find it here in mexico, but its too expensive, so i was looking for some options on ebay and i found some real bargains, but are these good options?
i found this..
http://cgi.ebay.com/100-FatMat-Xtreme-Car-Sound-Deadener-Dynamat-Roller_W0QQitemZ110199463022QQihZ001QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq Feet for $130
This
http://cgi.ebay.com/100-sq-ft-EXTREME-deadener-w-Dynamat-roller_W0QQitemZ200174694812QQihZ010QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq feet for $135
and this
http://cgi.ebay.com/100-Ft-80-Mil-Rattle-Trap-Deadener-Dynamat-Roller_W0QQitemZ110199455592QQihZ001QQcategoryZ67760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
100 Sq feet for $210
also i heard here about "second skin" but i couldnt find it on ebay..
whats the best for the money?
i have the impression that all of those are the same..
i found this..
This
and this
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
Dynamat Extreme is the best stuff but like you said, its kinda pricey.
Raammatt is my second choice. Very close to the Dynamat in performance but an **** ton cheaper.
http://raamaudio.com/cgi-bin/index.cgipolkaudio sound quality competitor since 2005
http://www.secondskinaudio.com/
I used to use Dynamat Xtreme, but have since gone with Second Skin's Damplifier Pro...seems to be better quality at a lower price. Both are top notch quality-wise- I have both Xtreme and Damp Pro in my current car.
Second Skin does sell direct (unless they have an arrangement with their dealer network like in Canada not to), and is well worth looking into.
http://www.sounddeadenershowdown.com/ Some good reading. -
this defenitly gives me another perspective.
i have a lot to read and learn, but thanks for giving me the right direction.
i love this forumZ
Polk Audio SR 6500
G35
KnuKonceptz MKS Kable -
ei guys look what i found...
http://www.amazon.com/gp/product/B00020CB2S/ref=wl_it_dp?ie=UTF8&coliid=I1D4VSDUT66NVH&colid=342JBC2O6LVDS
it seems to be an exelent option.Z
Polk Audio SR 6500
G35
Thats a pretty good deal. That is about $150 off retail, and Amazon.com aint no Ebay type dealer so it should be on the up and up.polkaudio sound quality competitor since 2005
Dynamat is one of the best and I recommend it highly. One web site that offers low price alternatives is EDESIGNAUDIO.com. Give them a look. They have some for around $1.00 per square foot. I have used it but its Dynamat for me from here on out.
Anybody ever use FatMat? I got just 50 sq ft roll off ebay for $39.00.
http://www.fatmat.com/
If it's not as good as the Xtreme or SecondSkin than I'll just give it to my installer for some labor trade off and go with Dynamat Xtreme.
Questions:
1. Is the DynaXorb or SecondSkin's speaker backwave product worth the money? Why not just do a layer or two of Xtreme?
2. How many Sq Ft would you all estimate I would need for an '03 Yukon XL... 4 doors? Do I need to do anything else? All my sound is up front even the sub (in the console...Stealthbox)
3. Any tricks of the trade for a Noob?
Quote: "When faced with dating/marrying looks or money... go for the money!" Money defienitely won't buy you happiness but it'll let you take care of your troubles in style. -
The Dynaxorbs aint a bad idea and do work in theory and I do use them but they are damn expensive. Not really worth the money if you ask me.polkaudio sound quality competitor since 2005
I just got done today deadening my doors with Second SKin Damplifier Pro and it is easy to work with and made my doors sound really solid. I normally use asphalt based deadeners, but I think I'm hooked on Second SKin stuff now.
