Mantis need your input
Dwain
Dwain Posts: 13
edited February 2003 in Flea Market
I just purchase the CSI40 and i know you have gone over the mantis wiring before. Can you help me out?
Denon 3802 receiver
Denon DvD 1600 progressive scan
CSI40 center
RT1000 fronts
RT28i surrounds
FX300i Rear back surrounds
Velodyne CHT 10 sub
Velodyne CHT 12 sub
Mitsibishi 27" tele
Monster cables/ 10 ga speaker wire
Post edited by Dwain on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    I doesn't apply to your speaker. You can ACTUALLY bi-wire it. How about that?
    Cheers,
    Rooster
  • Dwain
    Dwain Posts: 13
    Maybe i should re-phrase my question. I know you can bi-wire it but the instructions are a little vague on how to do it
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Take two lengths of speaker wire.
    Take the + from each and twist them together and stuff them into a banana plug and stick it into the Speaker A + in the receiver. Repeat for the negative side.
    Remove the brass jumper strap on the 40.
    Connect the two + and the two - to the same respective terminals on the 40. Use of banana plugs here is optional.
    Or, buy "bi-wire" wire and it's all pre-done.
    SVS
  • larrykwiat
    larrykwiat Posts: 44
    can someone explain what benefit bi-wiring will bring....sorry for being so stupid....thanks
  • TroyD
    TroyD Posts: 13,124
    Don't be sorry and you aren't stupid, hombre. Do a search in the archived on biwiring or biwire.....there are TONS of threads about it......
    BDT
  • mantis
    mantis Posts: 17,637
    Dwain,
    sorry I missed this thead.I'll give you some tips on what I would use if I owned your system.I used to own a system close to what you own.
    I'll start with bi wiring.As noted by another,equal lengths of equal wire to the speaker, remove the jumpers,positive to posite and negitive to negitive on the amp side....meaning both runs from the same amp channel.
    The easiest way to get the job done is to purchase bi wire premade cables.
    Here's what I would buy.
    Monstercable MCX Bi wires in the length you need.
    Monsterlock ends of your choice.Bananas are most popular and work.
    If your wallet is deep, go for monstercable M1.4s bi wires and monsterlocks.They cost alot more then the MCX series but perfomance is night and day.
    I would wire the front 3 in the same wire you choose.
    As Troy stated,get your search on and read all about bi wiring in here.It's been one hell of a running topic.
    Need more help????E mail me direct.
    Dmantis20@aol.com
    Dan
