110wpc to 100wpc will I be see a difference?
Dannieboiz
Right now, I'm power my RTi speakers with a Denon AVR-3802. I'm looking to buy a receiver with HDMI switching. The only one in the right price range is some of the AVR-2106 or similar, which only have 100wpc do u think it'll make a big difference?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Onkyo TX-SR875
Velodyne DPS-12
Post edited by Dannieboiz on
You will not hear a difference of 10 watts on solid state amps.
Venom -
doubt those numbers are legit anyway.....too many variables to know if you will notice a difference.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
I'm more concern of going from a 3802 and downgrading to a low end denon just for HDMI. The 3802 has been extremely solid, I would not want to sacrafice anything of it. If I can find a 3806 that would be golden but I need to spend under $500 for a used one.
Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
MartinLogan Dynamo 10 -
Find a model with the features you need/want with preouts and go with a 200wpc power amp, then you'll hear the Rtis sing.Shoot the jumper.....................BALLIN.............!!!!!
You would more here the difference in the preamp than in the power amp between the two recievers.
Now if it was a 100watt power amp you were comparing to a 110 watt AVR - I would say yes, you will hear a difference - but AVR to AVR no (in the power anyway).
Check the authorized refurb denon dealers for good prices (you need to go to the denon site to find them). Not sure when denon added the HDMI, but if you wait untill the next model comes out, you can find the older one for a better price.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
Ditto....best bet...can always add the amp later if funds are an issueThe first rule of Fight Club is you don't talk about Fight Club -
You surely won't see any difference, probably won't hear any difference either (wink) Chris
You won't probably be very happy if sound is important. The amplifier in the 3800 series products is much beefier than the lower end stuff. It's kind of like the first "real" Denon.
MarkSystem:
VPI Scout/Benz Ace
Sutherland PH2000
Arcam CD72
Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
Audioprism Mantissa w/Reference PS
Parasound HCA750 (temporary)
Audiovector M1 Signatures
Kimber 4TC x 2
