110wpc to 100wpc will I be see a difference?
Dannieboiz
Dannieboiz Posts: 242
edited December 2007 in Electronics
Right now, I'm power my RTi speakers with a Denon AVR-3802. I'm looking to buy a receiver with HDMI switching. The only one in the right price range is some of the AVR-2106 or similar, which only have 100wpc do u think it'll make a big difference?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • venomclan
    venomclan Posts: 2,467
    edited November 2007
    You will not hear a difference of 10 watts on solid state amps.
    Venom
  • Midnite Mick
    Midnite Mick Posts: 1,591
    doubt those numbers are legit anyway.....too many variables to know if you will notice a difference.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Dannieboiz
    I'm more concern of going from a 3802 and downgrading to a low end denon just for HDMI. The 3802 has been extremely solid, I would not want to sacrafice anything of it. If I can find a 3806 that would be golden but I need to spend under $500 for a used one. :(
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Sherardp
    Sherardp Posts: 8,038
    Find a model with the features you need/want with preouts and go with a 200wpc power amp, then you'll hear the Rtis sing.
  • McLoki
    McLoki Posts: 5,231
    You would more here the difference in the preamp than in the power amp between the two recievers.
    Now if it was a 100watt power amp you were comparing to a 110 watt AVR - I would say yes, you will hear a difference - but AVR to AVR no (in the power anyway).
    Michael
  • Pablo
    Pablo Posts: 723
    Check the authorized refurb denon dealers for good prices (you need to go to the denon site to find them). Not sure when denon added the HDMI, but if you wait untill the next model comes out, you can find the older one for a better price.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • shadowofnight
    shadowofnight Posts: 2,735
    Sherardp wrote: »
    Ditto....best bet...can always add the amp later if funds are an issue
    The first rule of Fight Club is you don't talk about Fight Club
  • vonnie123
    vonnie123 Posts: 326
    Never downgrade :eek:
  • wz2p7j
    wz2p7j Posts: 840
    You surely won't see any difference, probably won't hear any difference either (wink) Chris
  • Spacedeckman
    Spacedeckman Posts: 96
    You won't probably be very happy if sound is important. The amplifier in the 3800 series products is much beefier than the lower end stuff. It's kind of like the first "real" Denon.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
