blown speakers?
56deuceXT
56deuceXT Posts: 7
edited November 2007 in Troubleshooting
hey guys after a night of watching Troy and 300 (bored before halloween party) the next morning i find that my speakers are playing at low volume..no bass or anything just low volume coming from the tweeter
they are a pair of Polk R30s (a few years old) and i never had any problems with them.
are they blown out? i've never blown out any of the speakers ive ever purchased (had some Sony shelf speakers, pair of infinity floorstanding that i use for my front speakers)
i used these as my front speakers b4 i had the infinities, then turnd these into rear speakers for surround. i duno what happend..maybe someone messed with my volume knob..
i have an onkyo receiver to let yall know.
any ideas, comments? TIA
-xavier
Post edited by 56deuceXT on
  • jakelm
    jakelm Posts: 4,081
    If you have any other speakers, try them on the channel where the problem is. If the other speaker works correctly then their is something wrong with the Polk's, not the reciever.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    56deuceXT wrote: »
    -xavier
    So the problem is in surround? I never heard of blowing a surround speaker, not if used in DD or DTS applications. Check surround level on Onkyo. Check for surround type on Onkyo (Pllx, DSP, etc)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • 56deuceXT
    56deuceXT Posts: 7
    jakelm wrote: »
    i checkd it by replacing them with my old sonys n they work fine :( so its ze speakers
    jakelm wrote: »
    dang i shoulda reread my post. while moving i decided to use my polks for fronts because i left the infinitys at home so ive been using my 2 R30s for the fronts, a small sony center, sony sub, 2 onkyo surrounds. my bad, sorry for not clarifying that :\
    n the listening mode i always use (cuz i dont have a decent dvd player) is the Dolby Pro Logic II Movie Mode
    thanks guys!
  • jakelm
    jakelm Posts: 4,081
    You should double check your bass management. Without it can and will damage speakers, of all shapes and sizes.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • 56deuceXT
    56deuceXT Posts: 7
    jakelm wrote: »
    bass management as in treble and bass on the receiver?
    the maximum level for bass n treble are 10 n -10 for each. i had the bass at 4 and treble at 3
    the onkyo receiver also asks if the front two speakers are large or small, i select large and the rest are large as well. i guess this allows for more bass to be put through the individual speakers instead of relying solely on the subwoofer. (im guessing)
    has any1 had this problem with a speaker? i can hear the sound outta the tweeters, but its not at its max power and without any bass whatsoever..
    any other ideas or suggestions?
  • danger boy
    danger boy Posts: 15,722
    do the R30's have jumpers in back where you connect the speaker wires? if they do.. maybe the jumper is loose or gone.. check that out and hopefully the bass will come back on .
    (jumpers are the metal plates that goes between the upper and lower speaker connectors)
    PolkFest 2012, who's going>?
  • 56deuceXT
    56deuceXT Posts: 7
    nah the jumpers are fine..i guess my speakers are out :(
    gonna be lookn for some newer floorstanding polks, any suggestions?
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    You can certainly get replacement tweeters for your speakers. Have you owned them less than five years?
    Regards, Ken
  • 56deuceXT
    56deuceXT Posts: 7
    i remember i bought them august of 2003.
    however, when i plugged the speakers in to try em out, the tweeters work (a lil bit) but the subs are totally out on each one.
    is there a place to repair/replace polk parts?
    i would PM you ken, but since i just joined i am unable to send PMs.
    thanks for the help guys
    -xavier
    F1nut Posts: 51,787
    Call 1-800-377-7655 on Monday.
  • 56deuceXT
    56deuceXT Posts: 7
    thanks! will do first thing on monday!
    -xavier
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    It sounds as though you are within the five year Polk warranty. If you read the warranty section of the owner's manual it will give you an address in San Diego. All you have to do is remove the damaged parts and send them to Polk with a copy of your sales receipt and they'll send you new ones. No muss no fuss!
    Cheers, Jed
  • 56deuceXT
    56deuceXT Posts: 7
    oh dear..i'm gonna have to rummage through my stuff.
    i pulld the subs out and i guess theres a date inside of there. it said 08 july 03..is that the manufacturing date or..i duno.
    i'm gonna have to go back home and find the receipt. thank you for all the suggestions n assistance :)
