Protection for wireless networks
Ok, I'm sorry for being so dense, but how the heck do I install the new driver on the wireless desktop? It says that this driver update does allow for WPA, but I can't figure out how to install it!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
audiobliss wrote: »Ok, I'm sorry for being so dense, but how the heck do I install the new driver on the wireless desktop? It says that this driver update does allow for WPA, but I can't figure out how to install it!
What files did you download? Usually it comes with an installer.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Try uninstalling the old driver or use the "Update Driver" button in Hardware Manager.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Well, it has a SetUp 'icon' when I open the containing folder, but when I double-click it nothing happens.What files did you download? Usually it comes with an installer.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I would try that, but there are so many stinking files in this folder, I'd have NO clue what I would say is the new driver.Try uninstalling the old driver or use the "Update Driver" button in Hardware Manager.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Don't you guys hate being so PC literate? lolRichard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
To find your hub you could do this... RUN type in cmd at >type ipconfig the gateway IP is your hub address.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I'm going to close out this helpdesk ticket now and note the problem for these incidents as being...
ID 10 T
PEBKAC
MUAHAHAHAHAHA!
John, your forum computer guy.No excuses! -
OK, help please!
I couldn't figure out how to update the driver for the wireless desktop, so I just decided to go WEP. I set it up at the router for WEP, came up with a 10digit key, and set all that info on the wireless desktop. No go.
So then I went back to what it was: SSID Broadcast enabled, Wireless Security disabled.
Still no go.
Well, Mom's not happy with no wireless, so how the heck do I get this thing working again?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
SOmetimes the drivers get confused when you go back and forth between security methods.
Find the list of wireless networks, delete the one corresponding to your network, and then re-add it with the WEP.If you will it, dude, it is no dream. -
Ok...can't believe I didn't think of that...I'll try that. Should I have the SSID broadcast enabled while setting it up? Or can I do it with it disabled?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
i only run MAC filtering as anyone who could spoof a MAC could easily crack your encryption with backtrack2.. Also limit your ip's in the dhcp sever to a very small number.
Ok. I deleted the listed network, rebooted, then added it using the SSID, WEP, and the "WEP Key 1".
Then in the list of networks it's crossed out and unavailable. What am I doing wrong?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Ok, finally got it working. Had to turn the SSID broadcasting on, connect, then enter key. If I turn off SSID broadcasting now, will it be able to connect to the network next time the wireless desktop is rebooted?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
should be.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
It should, though I'll behonest, I never shut off SSID broadcasting. Just too much of a hassle when trying to get others on my network.If you will it, dude, it is no dream.
Ok, I'll just leave it on, then.
Thanks to everyone!!!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
If you think shutting off SSID broadcasting will protect you, guess again. I was scanning my network (SSID broadcast off) with a laptop and my network was picked up right away. However, it took about an hour to decipher the SSID. I use WPA. Turning off SSID broadcast will bore an attacker to go look for easier prey like 64 bit WEP with SSID broadcast on (you can be owned in 11 min).
If you're truly paranoid, use WPA2, MAC filtering, SSID broadcast off, and change your password monthly (or weekly). WPA can be cracked but I haven't tried it yet. From what I've read, it takes a very, very, very long time so if you change your password frequently, the attacker has to start over. You have to really piss somebody off for them to take the time to attack your WPA or WPA2 encryption considering there's so many network out there still using WEP. -
fatchowmein wrote: »If you think shutting off SSID broadcasting will protect you, guess again. ... I use WPA. Turning off SSID broadcast will bore an attacker to go look for easier prey like 64 bit WEP with SSID broadcast on (you can be owned in 11 min).
I agree 100%. All I am worried about is a 12-year-old on a rainy afternoon with a laptop and no games to play.
But I must agree with bobman, although I DO keep my SSID broadcasting off, it could sometimes be painful when you need to add a friend's laptop in a hurry. What I found works the best, is turning SSID on just of a quick minute long enough for a new PC to select my SSID, and enter the WPA password. Then you can use the same laptop to connect and turn SSID broadcast off. Over the years this only did not work once in my experience.
So well saidshadowofnight wrote: »WPA/MAC address filtering/and not broadcasting your SSID puts your car in the garage out of sight....puts a pit bull in the front seat ...and the owner is peeking through the glass with his .45
VSchneider wrote: »What I found works the best, is turning SSID on just of a quick minute long enough for a new PC to select my SSID, and enter the WPA password. Then you can use the same laptop to connect and turn SSID broadcast off.
Are you sure you need to turn SSID on? I believe you merely need to manually enter the SSID, encryption type, channel, and password. We've done this on my wife's laptop, xbox 360 (I later returned the wireless adapter), iPaq, and my desktop pc.
