Protection for wireless networks
audiobliss
audiobliss Posts: 12,518
edited November 2007 in The Clubhouse
Wingnut's thread reminded me. We have a Linksys wireless router for internet connection, and we have NO protection, password, encryption, etc set up on it.
What kind of protection should we have setup, and how do I go about setting it up and making the other computers work with it?
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
«13
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    I'd use WPA or WPA2 at the minimum.
    Then follow up with MAC address filtering and turn off the Wireless Access Point SSID broadcast.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • audiobliss
    edited October 2007
    Well, unfortunately, that basically makes no sense to me. I'm computer literate, but I'm network illiterate. :(
    I JUST learned tonight about MAC addresses. Well, ok, I learned that they're in the NIC card and uniquely identify every computer; that's all I know about them. So you can specify which computers, via their MAC address, can connect to the wireless network? That's some pretty awesome security, right there.
    So, basically, I guess I need step-by-step instructions on this. Also, two computers are wired to the router; will any of these encryption settings affect those computers' access?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    1. Yes
    2. No
    The MAC address filtering limits the computers that can access the wireless router. Which is pretty safe, unless someone alters their MAC address to one of yours, which is possible but unlikely.
    The encryption settings also do not affect those computers' access.
  • shadowofnight
    shadowofnight Posts: 2,735
    edited October 2007
    appadv wrote: »
    +1......I also keep a few spare usb wireless adapters for guest's computers that is already enabled for my MAC address filtering....makes it a snap for them to log onto my network.
    The first rule of Fight Club is you don't talk about Fight Club
  • Serendipity
    edited October 2007
    That's a good idea. I never thought of it!
  • Refefer
    Refefer Posts: 1,280
    edited October 2007
    audiobliss wrote: »
    That's not security in the sense you are looking for: that just means the router refuses to allow network access to anyone that isn't on the party list. They can, however, view all the information going to and from your computer with no problems what so ever.
    WPA and preferably WPA2 is the right choice. It encrypts your traffic and makes it so baddies can't visit your bank account when you're logging around online.
    To do that should be pretty straight forward:
    1. Log into your router. You can do this by going to the web url http://192.168.1.1, unless you've changed your ip address. The password, unless you've changed it, is by default "admin". You'll want to change this as well.
    2. Goto the "Wireless" tab. From there, goto the "Wireless Security" tab.
    3. Change it to WPA2 Personal, and enter a password. You will need this password for every computer that wants to connect to the router, so don't forget it.
    4. Hit Apply settings, and voila! That part is done!
    5. If you're currently using a wireless connection, you'll probably have been booted at this point. You'll need to make a new profile for the wireless connection and inform it of your intention of using a password.
    6. Goto the "Administration" tab. Change your password and save.
    7. MAC address filtering is a pain, so I won't cover that right now. The most important part is done however: those who don't have the password for your wireless account won't be able to use it AND won't be able to snatch what you're saying out of the air as well.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • audiobliss
    edited October 2007
    Oh man. I can tell I have a BUNCH of reading to do to understand this stuff. WPA? WPA2? All I see is WEP on my setup screen.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2007
    Refefer wrote: »
    Oh wow, thanks! That makes so much sense! However, it seems as though this router doesn't have anything but WEP. It's several years old. :(
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Refefer
    edited October 2007
    audiobliss wrote: »
    That might be fixed through a firmware update for it. I'd check out linksys' website and see if they've added a more secure standard. The problem with WEP is that it can be cracked in a couple of minutes without any trouble, so is fairly useless.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • audiobliss
    edited October 2007
    I just saw a link to firmware on Linksys' website. Is it fairly straightforward to update it?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Refefer
    edited October 2007
    audiobliss wrote: »
    It should be. For mine, it was a simple matter of downloading a file to my computer and then select it via the linksys router and it did the rest. Then again, mine is a whole lot newer than yours by the sound of it so YMMV.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • polkatese
    polkatese Posts: 6,767
    edited October 2007
    WEP 128 bits 26 Hex digits encryptions should be strong enough, IMO, unless you live in a neighborhood full of prowling hackers :)
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • audiobliss
    edited October 2007
    Sweet, just upgraded it. :D
    Wow, the 'menu' (what do you call that) is MUCH different now!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Refefer
    edited October 2007
    polkatese wrote: »
    And it will take less than minute to crack it, so be warned if you do decided to use it.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • Refefer
    edited October 2007
    audiobliss wrote: »
    Does it give you the option for WPA2 at this point?
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • Strong Bad
    Strong Bad Posts: 4,277
    edited October 2007
    Audiobliss, what model router do you have?
    No excuses!
  • audiobliss
    edited October 2007
    When I go to set the security mode, the only options are WPA pre-shared key, WPA Radius, and WEP.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2007
    Strong Bad wrote: »
    Linksys BEFW11S4.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2007
    Refefer wrote: »
    Yeah, anyone in the know refers to WEP affectionately as... nothing. Even an amateur can download a simple program off the net and be looking at WEP-"encrypted" packets within minutes.
    WPA or better is where it's at. WPA2 is ideal, but not supported on many wireless cards yet.
  • Refefer
    edited October 2007
    audiobliss wrote: »
    WPA Preshared key is probably the route you want to go. Just make sure the passphrase you use isn't too easy.
    Make it word or two plus a number (i.e. "MotherLoveBone57")
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • shadowofnight
    edited October 2007
    Refefer wrote: »
    WEP just keeps the honest people honest is all....so it really keeps out MOST of the people within range of your wireless network ( Maybe a house or 2 on either side) . It would keep most out in a simple residential neighborhood.....of course what we were saying earlier is much better.
    WEP is kinda like locking your car while its outside...be easy to pop the window and hotwire it...a pro could do it in seconds....but most wont know what wires to cut and twist together :)
    WPA/MAC address filtering/and not broadcasting your SSID puts your car in the garage out of sight....puts a pit bull in the front seat ...and the owner is peeking through the glass with his .45 :)
  • audiobliss
    edited October 2007
    Refefer wrote: »
    Ok, I'll come up with something. Now, what about the group key renewal interval?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    Refefer wrote: »
    Good advice. I use something like ?mag/*ukc7nb0p9ua;ljhzzz!damn*XP*PC!98a4iu34?1ty!
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2007
    wepp is they way to go
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • shadowofnight
    edited October 2007
    appadv wrote: »
    Hahaha...damn
  • bobman1235
    edited October 2007
    appadv wrote: »
    Yup, find a randomizer somewhere, no real words. Then just store the code ona USB key so you can transfer it to any computers that need it in a snap.
  • Refefer
    edited October 2007
    audiobliss wrote: »
    You shouldn't need to tinker with that.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • audiobliss
    edited October 2007
    Should I just use something like this for the password?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    bobman1235 wrote: »
    Actually, there is a word hidden in there, I just assigned letters to numbers and characters, i.e. the end is "Serendipity"
  • avguytx
    avguytx Posts: 1,628
    edited October 2007
    Refefer wrote: »
    So that should work for pretty much any router no matter what the brand? I thought I'd check mine to see what settings are on it but it says "problem loading page" on Firefox and on IE, it kind of does the same thing but goes to some kind of search page.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
