what subwoofer should i get?
  • Kinetic
    Kinetic Posts: 437
    edited October 2007
    I also was thinking in change my DB 6500 for the SR6500 but i dont think those fit my car..
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited October 2007
    Would they fit with a little modification? None of the speakers in my car were direct replacements, I had to make MDF mounts to get them to fit. The front OEM speaker mounts could not hold the mids, and rear speaker mount were made for 5 1/4" speakers. I now have 6 3/4" speakers all around.
    I would seriouly look into trying to get those SR's to fit. They are a very nice sounding set of speakers.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Kinetic
    Kinetic Posts: 437
    edited October 2007
    it seems like they are..
    i would buy the SR Sub first, and maybe for the next year at least one set of SR6500, those are pretty expensive, but those are on my next mods.
    i will put some pics of my car when i put the sub and new amp.
    Z
    Polk Audio SR 6500
    G35
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited October 2007
    1 set of SRs is all u need.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    edited October 2007
    and the SR6500 are better than the Infinity kappa perfect, and the focal?
    here in mexico all the people in SQ buy focal, but those are french and i dont like french products also are too expensive and too big for my accord
    Z
    Polk Audio SR 6500
    G35
  • eloplayspolo
    edited October 2007
    kappa are closer to the polk momos, but i ended up getting the momos because i heard better things about them, i like them :), Focal i hear good things about also though, its a polk forum, go polk ;)
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Greg Peters
    Greg Peters Posts: 605
    edited October 2007
    Kinetic wrote: »
    I'd take SRs over anything offered by Infinity. As a former Infinity owner, I'm glad I got rid of them. Focal makes some very nice speakers, and I won't knock the product- I like them. Focals can have some issues when installed in certain ways that make the high frequency response a little bit harsh, so you have to take that into consideration when mounting the tweeters. I'll just say that the SRs have a much smoother sound in the high frequency department yet still have a lot of detail, and that was the deal-maker for me.
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2007
    The SR's will smoke anything in the Infinity line.
    As for the Focals, if you compare the SR's to a comparable line of Focals like the K2P then the SR's are just as good. Neither are really better IMO.
    The Focals have punchier midbass but are a little too bright for my tastes. The SR's lack the punch but have good energy in the midbass but the upper midrange and highs are so smooth and natural and thats the sound I prefer so Id take the SR's.
    Best to listen to them both as theyre both excellent speakers and see which ones appeal best to what you like to hear and the type of music you listen to most.
  • Kinetic
    Kinetic Posts: 437
    edited November 2007
    MacLeod wrote: »
    Woow that means that those worth any dollar you spend...
    i listen a lot of classical, jazz and electronic music (trance and psico).
    i will start to save money for those SRs at least for the front ones..
    Z
    Polk Audio SR 6500
    G35
  • strang22
    strang22 Posts: 32
    edited March 2008
    mm104 is a good model
