Car Problem
Serendipity
Serendipity Posts: 6,975
edited November 2007 in The Clubhouse
So - I'm on my way to Lasareath's halloween party and right before we get to the Holland Tunnel to NJ the car overheats.
We pull over and when my dad opens the hood, the engine compartment is hot. Same with the vents inside the car - blowing hot air.
Wait 30 minutes with the hood open and slowly it's cooling off. Then once we decide to go again and while stuck in traffic the same thing happens.
Decided that I'm not going to make it to the party so we head back to Queens slowly with the fan turned to HI to cool the engine off. Finally I make it back home safely.
What could be wrong?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
«13
  • Shannon W.
    Shannon W. Posts: 568
    edited October 2007
    Stuck thermostat or the water pump went out. no biggie those are easy fix's/
    Shannon.
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited October 2007
    Not knowing the car, it sounds like the thermostat stuck.
  • ben62670
    ben62670 Posts: 15,969
    edited October 2007
    Fan clutch if it has a manual fan, or electric fan not turning on?
    Ben
  • Serendipity
    edited October 2007
    How do you determine if the thermostat is bad? I looked at the car and there is coolant in the reservoir, and also the electric fan is spinning.
    Aside from that, I don't know much about cars.
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2007
    What kind of car is it?
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2007
    How many fans does it have? I'm assuming only one, so if it's turning, that's good.
    And you have coolant in the reservoir, that's good. Once it's cooled off...MAKE SURE IT'S NOT HOT...take the cap off the radiator and make sure you can see coolant in there.
    I'm not sure how you could tell if the thermostat is stuck...
    ...nor how to tell if the water pump's not working...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Shannon W.
    edited October 2007
    Squeeze the top radiator hose when the car is hot if the hose feels like there is pressure on it then its not stuck but if you can collapse it and it feels empty then its stuck! also while the car is cooled off take the radiator cap and let the car run and shine a flashlight inside the radiator to see if you can see water circulating inside it. If you cant see any movement after the car warms up rule out the thermostat then you can almost bet its the water pump! Good luck if you need to I could pm you my Phone number to try and walk you though diagnosing this. Also I'm glad to try and help but doing it over the phone or just not being there is Tough..
    Shannon "RSP"
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • audiobliss
    edited October 2007
    I would say the radiator could also be plugged up.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    Frank Z wrote: »
    2000 Nissan Maxima.
  • Frank Z
    edited October 2007
    The least expensive thing to try first is the T-stat. Pick up a new one and a service amnual at your favorite parts store and get busy learnin'. Don't forget to grab some Right Stuff RTV, a new gasket, and some fresh anti-freeze.
    Don't drive it till ya fix it, you may warp the aluminum head.
  • Serendipity
    edited October 2007
    Frank Z wrote: »
    Thanks, I wanted to go to Lasareath's party but I didn't think it would be good to drive until it's fixed.
    P.S. to Lasareath - I'm sorry that I couldn't make it to your party.
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    I really don't know how many fans, but I do know that ONE of them works.
    I have coolant in the reservoir but it's over MAX. It's a little higher than before, but not by much. I don't ever recall it being so high though.
    Car is still cooling down.
  • audiobliss
    edited October 2007
    Well, if the coolant gets really hot, it expands, and it'll flow into the reservoir tank, so that's why it's so full.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    I can understand that. I remember the level used to rise after running the car, but it was never THIS high before.
  • opus
    opus Posts: 1,252
    edited October 2007
    How come I wasn't invited to Lasareath's party?
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • Serendipity
    edited October 2007
    Attached is a picture of the coolant level. It's much higher than I have ever seen before, and over the MAX mark.
    Does this tell you what's wrong?
  • audiobliss
    edited October 2007
    Yes. That your car overheated. Funny that. We already knew that.
    The coolant level has increased because it overheated. I don't think you can say anything else from that. It's just what happens.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    I was hoping that it would indicate/point to whatever was causing the problem.
    The only thing I know is that low coolant indicates a leak somewhere...
  • Serendipity
    edited October 2007
    Also, this is the fan that I said was working. Am I supposed to look for another fan?
  • audiobliss
    edited October 2007
    No, if there were another fan, it'd be right there right beside that one and very visible. If you only see one, there's only one. Some cars have one, some two, and some three. My Jeep has two.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    Nothing beside that one.
    So - from what I hear it could be a thermostat, water pump, or radiator hose?
    Just trying to narrow things down.
    Thanks for all your help so far!
  • sucks2beme
    sucks2beme Posts: 5,682
    edited October 2007
    I'm going with the thermostat too. My personal car expert is not here at the moment(son #1). He knows this stuff like nobody's business.
  • audiobliss
    edited October 2007
    From what I can see, it could be:
    thermostat
    water pump
    stopped up radiator
    I don't think a radiator hose would be the problem. Shannon was saying check the pressure in a radiator hose to check to see if the thermostat is working or not. The radiator hose is good if it's not leaking.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    I misunderstood what she said. Will check the pressure once the engine compartment has cooled down a bit.
    AFAIK, the radiator hose is not leaking.
  • audiobliss
    edited October 2007
    Yeah, probably not. If it were leaking, then you wouldn't have as much coolant, which means it would still have overheated, but I don't know if there would be enough coolant left to fill up the overflow reservoir like that. If no coolant's dripping, then you probably don't have a leak.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited October 2007
    Sounds like your car has a problem. My suggestion is to fix it.
  • audiobliss
    edited October 2007
    Yeah, and you're sober?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    That's a good thing, that there's no coolant leaking then.
    Rant: On a side note, first it's PC problems and then this. Everything's been going belly up around here and it's really frustrating.
  • audiobliss
    edited October 2007
    Just don't try listening to music. Next you'll blow those beautiful speakers Trey sweat so much over! :eek:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    I think we've established that already...
